Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 11-15-2018, 12:36 PM   #901
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Originally Posted by maperformance View Post
Nice curve for a street car. How do you like the header so far?
Absolutely love it. May get it ceramic coated while my motor is out this winter.
Turpid Porpoise is online now   Reply With Quote
Old 11-20-2018, 08:01 PM   #902
yakoob
Member#: 326670
2006 WRX Wagon
Default 2006 WRX Wagon
Facility: Drift Office
Type of Dyno: Dynojet
Baseline #'s: 203 awhp @ 5500rpm & 239 awtq @ 3750rpm
Boost: ~18.5 psi
Fuel: 92 octane
Target AFR: ~12
SAE Corrections: uncorrected, Smoothing: 5
Peak HP at RPM: 250 @ 4850rpm
Peak Torque at RPM: 283 @ 2750rpm
Mods:
SPT Short Ram Air Intake
AEM Fuel Pump
APS Cast Iron Down Pipe
APS High Flow Cat
APS Full 3" Exhaust
ACT Heavy Duty Performance Street Clutch SB5-HDSS
Notes: This was about 6 years ago, clutch was put in after the fact. Might start back up with the upgrades soon.
yakoob is offline   Reply With Quote
Old 11-26-2018, 07:00 PM   #903
anarekist
Member#: 468117
2017 WRX
DMG
2017 WRX
Facility: Phatbotti Anaheim, CA
Type of Dyno: Mustang Dynamometer MD-AWD-500
Baseline #'s: unknown
Boost: ~18.5 psi
Fuel: flexfuel, tune for e50
Peak HP at RPM: 366 ~ 6000rpm
Peak Torque at RPM: 349 ~ 4500rpm
Mods:
Mishimoto Silicone intake hoses (stock box) aFe s-dry panel filter
TurboXS hybrid BPV (full recirculation)
Grimmspeed EBCS
ProcessWest Charge Pipe + Verticooler + hoodscoop shroud
IBRC full TGV Delete ( polished + heat rejection coating )
removed intake port plates
Torque Solutions EGR Delete
TurboXS 3" catted J-Pipe + ETS 3" Quite Cat-back
DW300C fuel pump
Cobb Flex Fuel Sensor Kit
crawford AOS
Tuned Nov 19, 2018
anarekist is offline   Reply With Quote
Old 11-27-2018, 07:38 PM   #904
Stija
Member#: 492861
18 WRX Stg 2 tuned
So a quick question for anarekist, is run 3 also on 18.5 psi? (I may not understand how a dual gas tune works so that’s why I am asking if the question is an obvious yes. Lol.)
I am wondering because I am single fuel e tuned by Ron on 91oct too with same mods but with 20psi+ boost, so I’m trying to gauge what my whp would be.
Stija is offline   Reply With Quote
Old 11-27-2018, 08:07 PM   #905
anarekist
Member#: 468117
2017 WRX
DMG
Originally Posted by Stija View Post
So a quick question for anarekist, is run 3 also on 18.5 psi? (I may not understand how a dual gas tune works so thatís why I am asking if the question is an obvious yes. Lol.)
I am wondering because I am single fuel e tuned by Ron on 91oct too with same mods but with 20psi+ boost, so Iím trying to gauge what my whp would be.
the runs are backwards i guess. he first did the 91 tune then did the e50 tune. rons said max boost will move around according to the weather, etc. i hit 19/20 on warmer days, been cold lately so most it will do is 18psi at the moment.
with cobb flexfuel sensor it reads your ethanol content of your fuel. so ron sets the max timing it will ever have on my car, and that's on e50. so basically there's a flex fuel table that will tell it how much fueling to do per ethanol content and the timing etc. not too familiar to be honest.
i think you will have around the same HP.
i've looked at the other dynos and ist more or less the same. he said most people with my mods get 280 on 91oct and i might be able to do something to get rid of the HP slump in the 4500k-5500k range maybe with an intake and going catless, ooooor new turbo . but im not worried right now im pretty satisfied.
Old 11-27-2018, 08:57 PM   #906
Stija
Member#: 492861
18 WRX Stg 2 tuned
My car moves really nicely, I’m impressed. Now I will just have to wait and see how it will behave in high Arizona temps. To me really a larger intercooler was a necessity as well as performance add on, at least that was the excuse.
Old 11-28-2018, 08:27 AM   #907
mrmk1v
Member#: 489857
2018 STI
Facility: YimiSport Tuning
Boost: ~18.8 PSI
Fuel: 91 Octane
Baseline Numbers: Unknown
Mods: AEM Cold Air Intake
Invidia Catted Downpipe
HKS Super Turbo Exhaust Ti-Tip
Grimmspeed EBCS
305 WHP @ 5821 RPM
342 WTQ @ 3623 RPM
mrmk1v is offline   Reply With Quote
Old 11-29-2018, 12:14 AM   #908
anotherwrxincolorado
Member#: 494604
Default 2019 Wrx
2019 WRX
Facility: MOFAB - Parker CO
Type of Dyno: DynoJet
Baseline N/A
Boost: 18psi ~
Fuel: 91 Octane
Target AFR: Unknown
SAE Corrections: Unknown
Peak HP at RPM: 303 @ 5500
Peak Torque at RPM: 328 @ 3750
Mods:
COBB Accessport - Mofab ProTune
COBB J-Pipe Resonated
COBB SF Intake
COBB EBCS
anotherwrxincolorado is offline   Reply With Quote
Old 11-30-2018, 03:17 PM   #909
Blowby
Member#: 122684
2006 WRB WRX w/ VF39
molested by a drunkmann
2006 WRX tr
Facility: Emerald Coast Motorsports
Type of Dyno: Dynocom
Tuner: Drunkmann Tuning
Baseline # Unknown
Boost: 20 psi
Fuel: 93 octane
Target AFR: 11:4's
Peak HP at RPM: 354.4 5850 rpm
Peak Torque at RPM: 325.7 5650 rpm
Mods:
Vf39
Gimmick silicone inlet
Custom short ram
Grimmspeed up pipe x/ 44mm EWG
Grimmspeed MBC
KS Tech TGV delete kit
KS Tech Air pump delete plates
DW 750cc injectors
Tanabe Concept G "blue" TBE
Walbro 255
APS 525 FMIC w/ turbosmart raceport BOV
Speed Density tuned
Blowby is offline   Reply With Quote
Old 12-01-2018, 01:45 AM   #910
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Um, I'd find another tuner, or you have a mechanical issue (exhaust leak, inlet choke, something). A 2.5, especially with AVCS, with a VF39 should never be that laggy.
Shoot, pretty sure my old EJ205 with a VF39 had a quicker spool than that.
Old 12-03-2018, 11:30 AM   #911
Blowby
Member#: 122684
Tune is solid...been on that same tune for a short of a decade with zero issues. In all honesty I would be more inclined to that dyno being off as the shop just moved and they recalibrated from when it was at the old shop. Hell, maybe it's due to having a small turbo on a huge fmic. Maybe even it's because the engine and the turbo both have 130K+ miles on them. Who knows...I know I still daily drive the car without worries on it blowing up.
Old 12-03-2018, 01:00 PM   #912
JamesEub
Member#: 373837
Yep, my 2.0L with a VF39 hit full boost (18psi) at 3800 rpm on a mustang dyno with the typical supporting mods
JamesEub is offline   Reply With Quote
Old 12-04-2018, 07:43 AM   #913
veritasaequitas
Member#: 333964
2005 sti
aspen white
Car: 2005 STI
Altitude: sea level
Tuner: Dave
Transmission: Stock 6 Speed
Gear: 4th
Peak hp at rpm: 408 @ ~6,000
Peak tq at rpm: 419 @ ~4,700
Target boost: 23
Fuel: X98
Mods:
IAG Stage 3 + shortblock
Headgames pocket port
aermotoive fuel rails
id1300's
walboro 450lph hardwired
perrin silicone turbo inlet
IAG billet tgv deletes
AEM IAT sensor converted for Speed density
AEM map sensor
ETS TMIC
FP Blue
3 inch cold air intake
COBB Flex Fuel
Invidia catless bellmouth
Invidia g200
Tomei expreme uel
grimmspeed external wastegate up pipe
Tial mvs 38mm ewg
Spec 2+ clutch
AEM streetlight flywheel
Grimmspeed EBCS
IAG AOS
veritasaequitas is offline   Reply With Quote
Old 12-07-2018, 06:41 PM   #914
dhernandez
Member#: 316022
2006 WRX
Car: 2016 STi
Tuner: Engine Logics
Trans: Stock 6 SPD
Peak hp: 263.1
Peak tq: 290
Fuel: 93 Oct
Mods: Cobb SF intake
Cobb Downpipe
Borla catback
Aem 340 fuel pump
Really though it would do better than that. I never got to do a baseline but figured it was close to 250.
dhernandez is offline   Reply With Quote
Old 12-15-2018, 01:03 PM   #915
Tmack2425
Member#: 493909
2017 WRX FA20DIT stock Block stock Turbo E65
380 WHP!!
370 TQ!!
My IG: (24.tmac) to see dyno paper and car.
Altitude: sea level
Tuner: Mikey Botti (@stimikey)
Transmission: 17' STI 6 speed W/ DCCD Pro Controller
Gear: 4th
Peak HP at rpm: 380 @ ~5700
Peak TQ at rpm: 370 @ ~5100
Target boost: 22
Fuel: E65
Mods:
IAG EGR delete
Pernnin TGV delete
Grimspeed 3 EBC
Mishimoto FMIC
Cobb flex fuel kit
Dw65c fuel pump
Cobb Big SF CAI
3" high flow cat 1320 DP & Mid
STI transmission & Dif
DCCD pro controller
Brembo Brakes
Megan Racing rear control arms
Coilovers
Tmack2425 is offline   Reply With Quote
Old 12-26-2018, 05:31 PM   #916
Zcypot
Member#: 372777
2014 WRX Sedan Lmtd
Default 2014 WRX 1.5xtr
Facility: Church Automotive
Type of Dynopack
Baseline #'s: 243 awhp @ 5514rpm & 280 awtq @ 3405rpm(cobb OTS intake map)
Boost: ~23 psi
Fuel: E85 (79%)
Target AFR: 10
SAE Corrections:
Peak HP at RPM: 410 @ 5745rpm
Peak Torque at RPM: 449 @ 4249rpm
Mods:
Stock TGVs
Stock inlet
Stock Block
Forged internals
Crawford Air oil separator Black Street
Blouch Dominator 1.5XT-R 10cm hotside
Process West Verticooler
Grimspeed 3-port EBC
Cobb intake
Cobb FlexFuel
Full Killer B oil Kit
IDs 1700cc w/ DW300C
4bar MAP sensor
Transmission
Act stage 2
Moore’s performance blastplates for 5 speed
Exhaust
Killer B Motorsport 4-1 Holy Header w\ uppipe
Invidia Downpipe no cat
Vibrant ultra quite 3" resonator
Single exit Dynomax Ultra Flo 3"
Dyno Sheet
Pretty conservative tune, running nice and rich for safety. Tuner limited torque to 450, I kinda wanted to shoot for 470ish but a broken car is a boring car.
Zcypot is offline   Reply With Quote
Old 01-01-2019, 12:43 AM   #917
kayfunlite
Member#: 416655
Car: 2008 STI
Trans: Stock
Dyno: Mustang dyno
Peak hp: 276
Peak tq: 338
Fuel: 93 Oct
https://imgur.com/LODmIjw
Mods: Stage 2 built short block with Wiseco Piston kit and K1 connecting rods
Invidia N1 Exhaust
IAG AOS
Air pump block off plate
TGV deletes
Tomei turbo inlet
Killer B oil pickup
Killer B oil baffle windage tray
ARP head stud kit
P&L AVCS line kit
kayfunlite is offline   Reply With Quote
Old 01-12-2019, 12:52 AM   #918
WryWRX
Member#: 70294
2018 WRX
Dark Gray Metallic
Just got ProTuned today at Snail Performance AZ.
2018 WRX
Mustang Dyno @ Snail Performance, Phoenix, AZ
Stock turbo, tranny, intake, & exhaust
Mods:
Process West TMIC w/ charge pipe
TGV & EGR Delete
Grimmspeed EBCS
IAG AOS
Cobb AP + Pro Tune for 91 oct
305 whp
306 wtq
WryWRX is offline   Reply With Quote
Old 01-12-2019, 11:59 AM   #919
Stija
Member#: 492861
18 WRX Stg 2 tuned
2018 WRX
Mods:
TGV & EGR Delete
Grimmspeed EBCS
IAG AOS
305 whp
306 wtq
Nice numbers. I am in AZ as well and stage 2 also, what part of the valley and what color?
Old 01-12-2019, 03:48 PM   #920
WryWRX
Member#: 70294
2018 WRX
Dark Gray Metallic
Thanks. FYI Taylor over there was great to work with. I'm in Central Phoenix near 51 and Glendale Ave and it's the Dark Grey Metallic (looks great with the Performance package wheels!).
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-03-2016 12:43 AM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 11:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 03:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 03:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 06:40 PM
