Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 06-01-2006, 09:34 AM   #1
greysave
Member#: 62395
2005 STI
Default Should I keep the samco or go for the aps turbo inlet
Just like the title say should I keep the Samco or go with the aps turbo inlet? Has anyone ever heard of the samco turbo inlet closing? I will be running between 25 - 28 lbs of boost. What do you guys think?
greysave is offline   Reply With Quote
Old 06-01-2006, 10:35 AM   #2
herewegoagain
Member#: 107778
2006 Legacy GT Sedan
Obsidian Black
Just from personal experience and preference, I would always go with pipes over hoses. Just a bit trickier to fit since they don't budge. Don't have to worry about them closing, ripping, etc. And what happens if you want to add a vacuum port to a hose? You can't.
herewegoagain is offline   Reply With Quote
Old 06-01-2006, 11:19 AM   #3
greysave
Member#: 62395
2005 STI
Thanks for the info, I was already leaning that way. It just helps confirm what I was thinking.
Old 06-01-2006, 11:30 AM   #4
traction issuez
Member#: 86559
2005 RS Wagon
you can add vaccum port to a hose, fyi. but i would sugguest adding a a hundred bucks for the aps inlet for a sure fire way and just for realiablity reasons.
port for hoses (http://www.atpturbo.com/Merchant2/me...egory_Code=BCS)
traction issuez is offline   Reply With Quote
Old 06-01-2006, 07:22 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
In light of the fact that installing the APS pipe requires taking off and putting back on the intake manifold (4 hour+ job), I'd just stay with the Samco hose. The Samco hose is quite stiff already because it's 5 ply silicon (unlike some of the other hoses on the market).
-Geoff
Gruppe-S is offline   Reply With Quote
? for 3" aps turbo inlet people adWRXi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-17-2009 05:51 PM
keep the vf39 or go for the 34,30 BlueBudda Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-04-2007 11:02 PM
Should I stay with Subaru? Or go to the dark side (ACURA TL)? DJxRad North West Impreza Club Forum -- NWIC 31 07-16-2005 03:20 PM
should I buy an accessport or go for looks? Blizwinter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 11-05-2004 01:31 PM
OK, changed my mind again. should I get a Z28 or spring for the SS? Eric SS Off-Topic 56 04-29-2003 09:02 AM
