Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 06-18-2006, 12:10 PM   #1
Stealth_RS
Member#: 95677
2004 WRX
Default MY HI-beams are stuck on the ON pisition!!
for some reason I can not turn off my hi beams even if I move the swicth to off they still stay on!!! and yes my fogs are OFF too so it sucks!!
anybody has any ideas even with my headlights off the lue signal in the cluster stays on with my DRL!!
Stealth_RS is offline   Reply With Quote
Old 06-18-2006, 12:12 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Are your lights stock? If not how are they modded?
Old 06-18-2006, 12:23 PM   #3
Stealth_RS
Member#: 95677
2004 WRX
completely stock !! other than HID wanabee bulbs and they are 55/60W
Old 06-18-2006, 12:33 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Check those wannabe bulbs, they may have damaged your harnesses/connectors due to excessive heat (yes even the stock wattage ones can do this). If that is what happened you'll need to buy new connectors w/wire pigtails and splice them in place of the damaged ones.
And after that don't use those bulbs any more, use OEM or equivalent quality and avoid the aftermarket blue-coated ones.
Old 06-18-2006, 12:54 PM   #5
Stealth_RS
Member#: 95677
2004 WRX
ok well i doubt that might be it because it happened when i was going to use my signal light and pushed it into hi-beams by mistake!
Old 06-18-2006, 02:10 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
If moving the control stalk back and forth doesn't work, it's probably a problem with the switching mechanism in that stalk.
Old 06-18-2006, 03:17 PM   #7
Stealth_RS
Member#: 95677
2004 WRX
maybe i broke it or sumthing
Old 06-20-2006, 05:21 PM   #8
Stealth_RS
Member#: 95677
2004 WRX
still have no idea!! help
Old 06-20-2006, 10:59 PM   #9
davis10
Member#: 70011
crappy bulbs, that sucks for people driving by you just kidding probably should fix it
davis10 is offline   Reply With Quote
Old 06-20-2006, 11:45 PM   #10
Handsdown
Member#: 29355
chances are if it happened when you operated the stalk, and you know that it was your hitting it that brought about the change, it's more than likely the stalk. take the steering wheel cover off and poke around or just take it to a dealership... might want to get those ricer bulbs out first though.
Handsdown is offline   Reply With Quote
Hypothesis: Many Otters are stuck inside the bodies of 15 year olds jms Off-Topic 29 07-15-2009 06:12 PM
New "whine" while driving and now my reverse lights are stuck on! Feign Transmission (AT/MT) & Driveline 6 11-28-2006 09:39 AM
My parking lights are STUCK ON!!! femsubychick Electrical & Lighting 2 02-05-2005 10:49 PM
Hey everyone say hi to "SilverBoosted" stuck at work on this snowy Saturday,...... 944 turbo guy General Community 2 12-06-2003 01:35 PM
who says all us brits are stuck in the mud? ptholt Member's Car Gallery 2 07-23-2001 06:09 PM
