Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Old 11-27-2006, 09:18 PM   #1
Feign
Member#: 68604
06 STi
Default New "whine" while driving and now my reverse lights are stuck on!
Not sure where to start or what questions to ask.
I seem to have developed a whine while driving under normal, sane conditions. I only recently realized that this was the case, I'm not sure what I've done to provoke this. It is pseudo-high-pitched and does "respond" more when I am on the gas.
Second, my reverse lights are now on like I am in reverse...all the time. Again, no known cause, no weird ass shifts or general stupidity. I don't know how long they've been on.
However, I did make one thread in this sub-forum just after getting the car about slipping the clutch a bit while in second gear, if one cares enough to search my created threads. But no other odd behavior, just two oil changes and new tires back in June. Help!
Feign is offline   Reply With Quote
Old 11-27-2006, 09:52 PM   #2
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
reverse light switch frozen in place?? --> probably the cause of that problem, although I don't know what could be causing the whine, what type of gear oil do you use?
Force is offline   Reply With Quote
Old 11-27-2006, 09:57 PM   #3
Feign
Member#: 68604
06 STi
It's never been changed AFAIK. Just over 64k miles on it...
I'm going to check out the reverse and neutral switches now...I did some searching and that does seem to be the issue.
They are constantly on when the ignition is live.
Old 11-27-2006, 10:03 PM   #4
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
at 64K miles, new gearbox oil wouldn't hurt. I just put in some Valvoline 75W90 in last week, and my car shifts like butter now.
You've probably seen this but i'll just put this up in case others are having a similar problem.
http://forums.nasioc.com/forums/show....php?t=1135319
Good luck with the whine/reverse light problem, keep me posted if everything works out for you.
Old 11-27-2006, 10:29 PM   #5
Feign
Member#: 68604
06 STi
Yeah, that's on my to-do list.
The lights didn't come on when I went out to move it, but I pulled it into the garage and fiddled with the connectors anyway. I didn't touch a thing before pulling it in!
Old 11-28-2006, 02:12 AM   #6
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I remember when on my NA Legacy the reverse lights came on, but I think that was due to an electrical short in the switch cos I did ford some fairly deep water not long before. Might as well just d/c the connectors in the meantime til a solution is found, primarily for safety reasons.
As for the whining sound, lord knows. perhaps the two are related, because it seems that they are. I'm not sure. All the manual Subaru 'boxes I've heard whine, so I can't really say much on that at all.
i_c_the_light is offline   Reply With Quote
Old 11-28-2006, 09:39 AM   #7
Feign
Member#: 68604
06 STi
Well, I was thinking...since I've had the car I haven't really driven with the windows fully closed (smoker and unseasonable weather) on a regular basis. Maybe it's just my overactive imagination thinking something is wrong since I'm not 100% used to how the car sounds.
The car's great otherwise...no sputters, pops, clangs, et cetera. Drives smooth, same power, no hesitation or the like.
Hood popped open while driving and check engine light came on. Flat4Wagon Newbies & FAQs 20 03-12-2010 03:19 PM
? running lights are stuck on subi14 Newbies & FAQs 12 02-01-2008 02:41 AM
MY HI-beams are stuck on the ON pisition!! Stealth_RS Electrical & Lighting 9 06-20-2006 11:45 PM
My parking lights are STUCK ON!!! femsubychick Electrical & Lighting 2 02-05-2005 10:49 PM
05 sti, reset my battery and now my parking lights don't flash when arming alram coil222 Electrical & Lighting 1 05-30-2004 03:59 AM
