Welcome to the North American Subaru Impreza Owners Club Monday July 23, 2018
Old 02-05-2005, 11:38 PM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Unhappy need help with hid wires - was working
Ok I got my setup working and desided to change the connections to the ballast and solder the connections and heat shrink it. So I did all that and turned on the lights and one did not work. So i pull the light and ballast and checked it on the other side. it worked just find. I resoldered the connections and tested it with a multi meter. tall tests show good. 12v and 0.01 ohms for the gound. Yet i plug it in again and it wont work. pulled the harness and changed sides of the car. see if it was just something strange. does not work on that side idther. I dont get this. both ballasts and bulbs work find. getting voltage and ground yet no light. can you please help?
thanx
hybrid gti 2 is offline   Reply With Quote
Old 02-06-2005, 12:12 AM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
suggestions?
Old 02-06-2005, 02:00 AM   #3
pityr
Member#: 31719
check hte connection between whatever you were sildering and the ballast? the wores might have power but is the power being sent to the ballast?
sounds like you have a bad connection somewhere. triple/quadruple check them all.
pityr is offline   Reply With Quote
need help with HID installation... devasta Newbies & FAQs 7 08-30-2009 11:57 PM
Need help with HIDs audigy-187 Electrical & Lighting 4 12-12-2007 04:54 PM
Need Help with HID Hksueprman Off-Topic 2 09-27-2005 02:24 PM
need help with hid wrxmania Electrical & Lighting 1 12-09-2004 12:48 AM
Need help with one wire for turbo timer dman918 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-22-2002 05:01 PM
