Welcome to the North American Subaru Impreza Owners Club Wednesday August 5, 2020
Old 10-19-2008, 03:37 PM   #1
sorrowfulkiller
Member#: 170439
I <3 Lamp
Default Can't get tie rod lock nut loose
Anyone have any idea how I could get my pass side tie rod lock nut loose? and if I'm looking at the nut from the rotor side I would turn it clockwise correct?
sorrowfulkiller is offline   Reply With Quote
Old 10-19-2008, 05:53 PM   #2
MasterKwan
Member#: 98961
2003 WRX
I ended up having to replace the inner tie rod to get mine loose. I took it in for alignment and the alignment shop couldn't get it loose either. You should be able to look at the threads to see. I don't remember either side being reverse threaded.
Old 10-19-2008, 06:50 PM   #3
Mojambo
Member#: 102581
2006 STI-USDM
SGM
I always add some anti sieze on those threads. I do my own alignments and realized that this is the key!
Mojambo is offline   Reply With Quote
Tie-Rod Jam Nut Size? SiFuSpEc Brakes, Steering & Suspension 7 06-21-2019 01:41 PM
Bad/loose inner tie rod idioteque1025 Brakes, Steering & Suspension 4 06-06-2010 10:12 AM
lock nut for tie rod stuck (adjusting toe). Fix? xcdhridr Brakes, Steering & Suspension 19 10-07-2009 12:02 AM
McGards lug nuts... can I get 4 non-locking nuts locally? Hokie-wrx wagon Mid Atlantic Impreza Club -- MAIC 0 08-11-2006 03:39 PM
Where to get black wheel lock nuts ? zeroFX Vancouver Impreza Club Forum -- VIC 26 01-24-2005 09:26 PM
