Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Old 10-05-2009, 01:20 PM   #1
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
Default lock nut for tie rod stuck (adjusting toe). Fix?
the front lock nut that tightens the tie rod to keep it from coming out/moving is stuck so I can't lock the alignment in place. I've tried PB and some heat to no avail and the control arms are now getting a little rounded from the 13mm slipping. Any ideas?
stock 04 wrx arms btw...
xcdhridr is offline   Reply With Quote
Old 10-05-2009, 01:32 PM   #2
PARANOID56
Member#: 22035
2014 Brocoma DCab
71 FJ40, 13 DRZ400SM
i cant think of what you are talking about, so a pic might help. however, are you sure its 13mm? i cant think of any bolts on our car that is 13mm, only 12 and 14. also, make sure you are using 6pt sockets so you dont round off bolts.
PARANOID56 is offline   Reply With Quote
Old 10-05-2009, 02:11 PM   #3
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
crap. I said control arm but meant tie rod in the original...
I'm talking about the nut where it says loosen in this pic
Old 10-05-2009, 02:13 PM   #4
[email protected]
Member#: 67
1999 Outlasting
the competition.
have you tried going the other direction? one side is RHD the other is LHD, if i'm not mistaken
T
Old 10-05-2009, 02:26 PM   #5
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
yup. tried both. It unscrewed from the outer tie rod assembly so I can move the whole unit. I just can't tighten the nut against the inner assembly.
Old 10-05-2009, 02:38 PM   #6
grippgoat
Member#: 62182
2005 STI
Originally Posted by xcdhridr View Post
yup. tried both. It unscrewed from the inner tie rod assembly so I can move the whole unit. I just can't tighten the nut against the inner assembly.
Sounds like you need some coffee.
Do you mean you can't tighten the nut against the outer tie rod?
Are you trying to say that when you put a 13mm (you might try 1/2", but I don't think that fits on my tie rod) on the tie rod, and a 19mm on the lock nut, you can't make the lock nut move on the tie rod? For me, the lock nut is finger loose once I un-jam it from the outer tie rod.
EDIT: Or, are you saying that you can't get the lock nut to un-jam from the outer tie rod? There should be flats for a 19mm or 3/4" wrench on the outer tie rod. So you put one 19mm / 3/4" on the jam nut, and one on the outer tie rod, and make SUPER sure you're turning the right way for which side of the car you're on. It can be tricky to get leverage under there.
-Mike
grippgoat is offline   Reply With Quote
Old 10-05-2009, 02:46 PM   #7
MasterKwan
Member#: 98961
2003 WRX
I had to replace an outer tie rod because the lock nut wouldn't turn. The fact you actually unscrewed the inner tie rod from the rack is scary. That's not supposed to happen ever. It suggests the inner tie rod was replaced at some point and not installed properly/tight enough.
Old 10-05-2009, 03:51 PM   #8
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
yes. coffee needed... asap
I meant outer tie rod.
Old 10-05-2009, 04:42 PM   #9
classicaddict
Member#: 220619
04 wrx wagon
you need heat.......im not talking some heat from a sissy propane. you need an acetylene torch and get just one side of the nut red hot so it expands enough to loosen whatever is seizing the nut to the tie rod.
classicaddict is offline   Reply With Quote
Old 10-05-2009, 05:08 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
nah....propane will do the job
heat it up...put the wrench on and whack it with a hammer and all good
Old 10-05-2009, 05:15 PM   #11
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
I only have access to sissy propane... =(.
I might try lots of heat, a hammer, and 2-3 wrenches when I get home. It's stuck on both sides. dammit
Old 10-05-2009, 08:00 PM   #12
classicaddict
Member#: 220619
04 wrx wagon
if propane is all you have that will work it will just take a bit of time. but you need to hold that torch on there for a long time, till it gets red hot. hold the inner tie rod with vice grips and get a nice LONG wrench for the lock nut. once you break it free get your pb blaster ready and spray it on and work the lock nut back and forth so the blaster will get under the lock nut and you can spin it with just your fingers.
dont use a hammer. you could slip and mess up the threads, then your screwed. shouldnt need a hammer for anything.
Old 10-05-2009, 09:39 PM   #13
grippgoat
Member#: 62182
2005 STI
Don't use your fingers until it cools off.
And if you're putting a 13mm on the inner tie rod, you're doing it wrong. Make sure you're using two 19mm, one on the outer tie rod, and one on the jam nut. And quadruple check that you really are turning it the correct direction.
And don't tighten it so much when you're done.
-Mike
Old 10-05-2009, 11:21 PM   #14
beanbeanbean
Member#: 132935
02 rwx
round
"big metal pipe" does it for me everytime and it's pretty strange to get Lhd\rhd jam nuts unless it is dual jam nuts like on the rear of an impalla
(and i hope you didn't mean left hand drive? but reverse threaded or left hand thread?)
beanbeanbean is offline   Reply With Quote
Old 10-05-2009, 11:35 PM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I don't believe they are left hand threaded. In fact, I'm pretty sure of it or all the RCA kits would need a left hand outer tie rod, and I'd be getting TONS of questions on it.
OP - heat and a candle. Get that puppy hot, and then press a candle up to the threads to "wick" some wax up under the nut.
Old 10-05-2009, 11:37 PM   #16
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
got one side free. Passanger side is still good and stuck.
I used 2 13's and the torch on the drivers side for success.
You only need two 19's if your breaking the lock nut/tie rod free, otherwise you need 13's to adjust the in/out.
I didn't get the nut red hot when doing it. I heated it for a good two-3 minutes before trying anything and still no luck. I don't think I can get it red hot with the propane (or should I just let it soak in the heat for 5+minutes?)
PITA!. I gotta get something worked out before thursday. Friday I'm due for practice runs for the rally championships.
Old 10-06-2009, 01:09 AM   #17
classicaddict
Member#: 220619
04 wrx wagon
-Mike
both sides are lefty loosey righty tighty. putting a 19mm on the outer tie rod to loosen a seized jam nut will do absolutely nothing but turn the inner tie rod. you need to hold the inner rod steady.
not a bad idea, but once i get the nut hot enough and freed up i just walk it bach and forth with the wrench then and put a nice thin coat of anti seize on the threads, then walk it some more to work the grease up under the nut.
Old 10-06-2009, 04:35 PM   #18
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
Woot!!! went home during lunch. check the bolt and it moved!!!! I'm betting that all the heat last night while working on it just expanded the rod/tie as well so I couldn't move it. I let it soak in the pb blaster overnight (again!) and voila! Still will likely need a new tie rod in the future, but this one has had 20 plus alignments done to it...
Old 10-06-2009, 04:46 PM   #19
jamal
Member#: 71875
I got so frustrated once I swapped out the entire rack. Well plus the extra one I had was a little bit quicker.
jamal is offline   Reply With Quote
Old 10-07-2009, 12:02 AM   #20
jasonrmorrow
Member#: 161907
2002 WRX Sedan
Man this is a confusing thread. You are doing it right, lots of heat, I understand what you mean about the jamb nut backing off the outer tie rod and taking the inner tie rod with it.
Nothing scary or broken just a seized jamb nut. Glad you got it loose. Channel lock makes a pair of pliers with a curved jaw, they are a slip joint plier and the harder you push the tighter it grabs, I use them a lot on inner tie rods to break loose the jamb nut.
Also if you use heat don't adjust and then tighten it all down right away. The alignment changes a bit as the parts cool down. Thats why we charge an extra .5hr when we have to heat parts to align.
jasonrmorrow is offline   Reply With Quote
Help. Can't adjust toe - tie rod stuck leecea Brakes, Steering & Suspension 4 05-18-2009 09:23 AM
manual for tie rod replacement maciek Legacy Forum 3 01-25-2006 02:33 PM
suggestions for tie rod install romoranger Brakes, Steering & Suspension 7 06-21-2003 01:58 PM
Locking nuts for P7s BlackBeastie Brakes, Steering & Suspension 0 01-23-2002 02:05 PM
