Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Old 08-03-2012, 06:39 PM   #51
SG02WRX
Member#: 151814
2014 WRX SWP
Here was my former set-up.
17x9 +38 Work CR KAI
245-40-17 S.Drive
With Tein SSP Coilovers.
No Rubbing on any of the corners.
The only had to roll the rear flat, fronts no need for rolling.
You should be fine with just rears rolled. If you plan to go lower on coilovers the fronts will need to be rolled as well.
Good luck. One more suggestion is once you put the wheels on get it professional aligned, and you should be good.
SG02WRX is offline   Reply With Quote
Old 08-03-2012, 08:06 PM   #52
sc00by4life
Member#: 97135
Originally Posted by brett192
Lol I'm not buying used tires. I am buying them brand new from Canadian Tire. Just a bit more expensive than online but I won't have to deal with shipping. General G-Max are on sale for 25% off until next thursday.
Never said anything about used, only that local tire chains have very limited options.
sc00by4life is online now   Reply With Quote
Old 08-04-2012, 03:32 PM   #53
m4r10
Member#: 41877
02 wrx
245-40-17 S.Drive
Did you have to mess with your camber to not rub? Don't wanna go too far from factory settings
m4r10 is offline   Reply With Quote
Old 08-05-2012, 12:44 AM   #54
BoomWrx
Member#: 327371
2007 WRX
BLEEEK with some sparkles
I run 18x9 rota g forces et38 with 235/40 and I am fairly low (tucked) and I had to roll the rears, used a bat and out great. and semi rolled the fronts. I run -2 camber all around and only rub in the back over BIG bumps and if I go to fast up my driveway because of the curb. Rolling the fenders is pretty easy, just takes patience.
BoomWrx is offline   Reply With Quote
Old 08-05-2012, 11:13 PM   #55
m4r10
Member#: 41877
02 wrx
I'm not taking any chances. My '02 looks mint with fresh body work now.
SG02WRX, are those Rota Torque knockoffs? just kidding. Looking good.
Old 08-06-2012, 05:44 PM   #56
sonic_wrx189
Member#: 207905
2005 forester xt
silverf
Originally Posted by m4r10
Oh yeah? Does they ever rub after rolling your rear fenders now?
No sir. No rubbing here.
sonic_wrx189 is offline   Reply With Quote
Old 08-06-2012, 06:10 PM   #57
SG02WRX
Member#: 151814
2014 WRX SWP
Yes, I did and you will have to also. Like I mention before make a appointment with your local performance shop that does alignment, they'll give you the optimal settings to reduce tire/camber wear, and avoid rubbing.
Old 08-14-2012, 12:11 AM   #58
Foska Oats
Member#: 144081
2003 WRX
At the end of the day it will be what you are comfortable with
Foska Oats is offline   Reply With Quote
Old 07-17-2019, 01:32 PM   #59
J_Star
Member#: 479465
2003 Wrx
Originally Posted by sc00by4life View Post
235 Feds are square on a 9" wheel.
You can also properly fit 9" wheels with proper tires and the right offset.
What do you mean by square?? is that good or bad??
J_Star is offline   Reply With Quote
Old 07-17-2019, 04:18 PM   #60
Mach V Dan
Member#: 12029
Holy thread resurrection, Batman.
Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
