Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 09-12-2013, 05:28 PM   #226
Android287
Member#: 180861
2005 IAG Closed Deck
Larry's Power built heads
He does have a point the 5 speed is lighter if you have to move it...
Android287 is offline   Reply With Quote
Old 09-12-2013, 08:14 PM   #227
2011rex18
Member#: 321728
2011 WRX Limited
Originally Posted by Jive Turkey View Post
i've got a brilliant idea, put the stuff into the bug, ditch the 2.0L and 5-speed. BOOM no pallets needed to move
Lmao as always jive chimes in with the comedy!
2011rex18 is offline   Reply With Quote
Old 09-13-2013, 09:01 AM   #228
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That actually would have been way easier. The 6 speed really isn't bad, but the full long block is terribly heavy and awkward to carry. We didn't have a pallet jack so we had to carry it all over to the truck and then set it on a pallet already in the truck. This made things waaay more difficult. If we had a pallet jack it wouldn't have been hard at all. Basically ended up carrying it 30+ ft two times vs. carrying it 1ft one time.
But it appears everything made it OK. The motor and tranny were strapped to a pallet for the drive across town and nothing looked like it moved around when we got there. All of my garage stuff ended up being a TON of stuff. It was a lot of work and took up a huge chunk of space in my new garage. But I'm still able to fit 3 cars in the garage, so that's a plus.
xluben is offline   Reply With Quote
Old 09-13-2013, 11:07 AM   #229
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
New garage. Already full of junk. Needs insulation, drywall, and a lot of storage space (shelves) to open up some more working room.
Fortunately it can still fit 3 cars
Old 09-13-2013, 11:12 AM   #230
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Wow, congratulations on the upgrade. You should check out garagejournal.com. Lots of really cool builds on all budgets to check out and draw inspiration from.
bicycle_wreck is offline   Reply With Quote
Old 09-13-2013, 11:19 AM   #231
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Congrats on the move that's a nice looking garage. I'm very jealous. My 1 car garage is completely useless since it's full of mine and my wife's junk and a giant oil tank.
atf78 is offline   Reply With Quote
Old 09-13-2013, 11:36 AM   #232
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks! I'll have to look into that. I mainly just want more outlets, insulation, and some DIY shelving for storage. Oh, and a heater. I think it should be pretty easy, but I don't even know where to begin on the wiring, so that holds up everything else.
It's really nice to be able to park 3 cars in the garage, but the free space around the cars is actually way down from the old garage. The old garage was only a 2 car, but it was 6 feet deeper than the new one! Overall area only went 520ft^2 to 618ft^2 (so definitely not a 50% increase like you would think when going from 2 cars to 3 cars).
And the old garage had full height shelving along the entire back wall. The storage was great, and the extra deep garage made for a lot more room to work. The third stall in the new garage barely has enough room to walk around the car, especially with the workbench there. I definitely need to add some shelves eventually.
Another really nice thing is the higher ceilings. The old garage was low (8ft?) and had an even lower spot right above the car. You couldn't jack the car up very high with the hood open or it would hit the ceiling. I think this garage is 9ft? I'm not positive, but it's a lot higher than the old one. High enough that it's tempting to put in a lift
Here's a shot of the garage without all the junk. It looks way bigger than it really is.
Old 09-16-2013, 09:43 PM   #233
toph
Member#: 78640
19 Tundra
04 STi
If you are thinking about a lift (I have one in my home garage) look into an Atlas, I paid $1495 for my 2-post. Picked it up in the back of a 1500 GMC Sierra and installed in 4 hours with one other person. Makes everything much easier. 9FT should be high enough as well.
toph is offline   Reply With Quote
Old 09-16-2013, 09:49 PM   #234
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'm guessing that's probably this one:
http://www.gregsmithequipment.com/Atlas-BP8000
I'll have to actually measure my ceiling to see if it would it. It's just rafters now, so I'm sure I could make a cutout in the ceiling if I'm only off by a couple inches. What are the trade off's with the base plate design? Is it just less load capacity because nothing is stabilizing the top of the posts?
Old 09-16-2013, 10:03 PM   #235
projectQWKSLVR
Member#: 285270
03 WRX
I have the open top design, still has a 5ton capacity. It's made by AMPRO in Mass. It doesn't mind the 67 Chevelle, or my friends 7 passenger Suburban. I've measured post to post a few times to see if anything has moved, after 6years there's been no variation or less than a 32nd of an inch anyway. :-)
projectQWKSLVR is offline   Reply With Quote
Old 09-16-2013, 10:25 PM   #236
toph
Member#: 78640
19 Tundra
04 STi
I lied I got the 9KBP. Guess it was $1595 not $1495. The cable over the top doesn't actually add any structural integrity (that's what they told me atleast), just no hump to get over. My STi is pretty low and I have no issues getting over it. I do have to put it on 4 1.25" boards to get the lift arms under it though. I needed the base plate one because I have a cutout from an apartment above the garage that juts out about 3FT into the bay with the lift. This was the only one that could fit underneath that. You need 4" thick concrete at a minimum. Install was very straightforward and easy, although drilling 12 holes through concrete was tiring. Only part that I didn't know what to do was the wiring, my dad had no issue doing it and he's not an electrician by any means.
Old 09-17-2013, 12:07 AM   #237
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here is a video of the VF39 @ 20psi on E85:
Sorry for the terrible quality. Windows Movie Maker is causing the videos to become extremely dark recently. I'm not sure what happened, but it looks pretty terrible. Same camera and same computer is being used.
Here is an updated Virtual Dyno plot:
This a pretty basic 20psi E85 tune with the VF39 and stock 2.0L. 50-100mph time and Virtual Dyno power numbers both show a small gain over the VF39 on pump gas. Not too drastic, but enough to be noticeable. Didn't quite hit 300WHP, but it still pulls well and is strong all the way to redline.
50-100mph is 8.6 seconds
287WHP on Virtual Dyno (Dynojet)
Engine:
  • Stock 2.0L with 185k Miles
Intake/Exhaust/Fuel:
  • GrimmSpeed CrossPipe
  • GrimmSpeed Uppipe
  • GrimmSpeed Downpipe
  • Perrin CatBack Exhaust
  • IHI VF39 (STI) Turbo
  • GrimmSpeed Gaskets
  • GrimmSpeed TMIC w/Gold Tape
  • GrimmSpeed TMIC Splitter
  • GrimmSpeed Y-Pipe Kit
  • GrimmSpeed MBC
  • 05 STI Fuel Pump Hanger
  • Walbro 255 Fuel Pump
  • Modded 2011 WRX Injectors (1000cc)
Old 09-17-2013, 10:48 AM   #238
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Updated first post(s) with info and links!
Old 09-17-2013, 11:45 AM   #239
raanster
Member#: 351467
2002 Impreza WRX
Sedona Red Pearl
I can't wait to get some income to start my project. Keep the updates coming. Love what you've done so far
raanster is offline   Reply With Quote
Old 09-17-2013, 12:32 PM   #240
enjoilife1991
Member#: 322400
03 WRX 360whp
Man That 2.0 motor is really holding you back.
enjoilife1991 is offline   Reply With Quote
Old 09-17-2013, 12:35 PM   #241
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Ben,
I have the Bendpak XPR-10, I'm very happy with it! I did have to cut out the insulation due to the height, my barn is around 11ft. I need to box it in this fall.
jester8798 is offline   Reply With Quote
Old 09-17-2013, 01:26 PM   #242
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks!
Yeah, it definitely is....
Originally Posted by jester8798 View Post
Ben,
I don't have that much height and I definitely don't need that much lift. A Subaru is the biggest car I plan to ever have on it, so I don't need anything too heavy duty.
Old 09-17-2013, 07:44 PM   #243
tgtrefz
Member#: 255232
2011 WRX Sedan Ltd
Spark Silver Metallic
aaaand i'm already behind. Can't wait to see what you do.
tgtrefz is offline   Reply With Quote
Old 09-17-2013, 10:42 PM   #244
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Agreed, I don't have anything near the max load of the lift but I liked having the cross bar at the top. Regardless, they're awesome if you have the space and your concrete is thick enough. Good luck!
Old 09-18-2013, 12:28 AM   #245
Jdub.csu
Member#: 283784
2015 MUSTANG GT PP
GUARD
We have a used 12000lb 4 post for sale at the shop! Has rolling jacks too in the center. But that is overkill for you lol.... Beyond overkill
Jdub.csu is offline   Reply With Quote
Old 09-18-2013, 12:31 AM   #246
ohno76
Member#: 347576
2004 Impreza wrx wag
Default Stealth
Nice pics
ohno76 is offline   Reply With Quote
Old 09-18-2013, 08:49 AM   #247
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's a ways off if I ever do it. I would want to wire, insulate, heat the garage before doing a lift. I don't know the thickness of the concrete, but I wouldn't be surprised if I needed to have new sections poured to mount the lift.
I definitely don't want a 4 post.
Originally Posted by ohno76 View Post
Nice pics
Thanks.
Old 09-20-2013, 10:57 PM   #248
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Haven't checked in on this in a while. Very nice progress. You wasted no time putting some better power down. Love the build and the direction it's heading!
Curious, did you ever look into the GC chassis? You liked how light the bugeye was, GC coupe is even lighter
JSchell1309 is offline   Reply With Quote
Old 09-23-2013, 10:17 AM   #249
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, I got to drive a GC at the track and my helmet hit the headliner. I'm not a tall guy either. I just thought it would be too small. Maybe it was just the seat position or something. I'm hoping to drop the weight on the Bugeye a bit. Still won't be as light as a comparably set up GC, but it should be a lot lighter than my 2011 was.
Old 09-23-2013, 10:20 AM   #250
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I had a little help from my brother and a friend and pulled the motor out on Friday. All went pretty smoothly/easily. It was pretty late so we called it quits after the motor was out. Still need to pull the tranny. Waiting on a few small parts to be able to put the new stuff in anyways. Sorry for the terrible cell phone pictures.
