Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 12-19-2013, 12:40 PM   #526
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by WRXt4cy View Post
Ahh - so what did you do with the heads in regards to AVCS? Just running without or did you do something else?
Your ECU supports the CarBerry rom which has some pretty cool features like speed density, LC w/ boost, FFS, etc.
If you ever miss a gear your engine is going to be like
Running non-AVCS with the CarBerry ROM on speed density. The ignition cut LC is pretty crazy. Seems to be pretty hard on things though I'll try not to miss a gear....
xluben is offline   Reply With Quote
Old 12-19-2013, 12:52 PM   #527
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Haha, yeah spark cut is probably not good for much longevity. I tried it on a friend's car when I was tuning with the CarBerry rom and it was pretty violent. Here's a launch with spark cut and building about 25 psi. Pretty much just roasted the tires and smoked the clutch
Fuel cut LC with boost works really well though. Did you experiment with LC timing/fueling to build boost?
How come you aren't using the FFS feature with this rom?
WRXt4cy is offline   Reply With Quote
Old 12-19-2013, 02:02 PM   #528
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
http://www.youtube.com/watch?v=gYzLjKxM0fc
One of the NF guys has a GC with a 6266 and ignition cut LC set up. Shoots lots of flames and is really loud. I got to take it down the strip and it basically just builds full boost instantly.
Nuke has had some good luck playing with timing and fueling along with the fuel cut LC and gotten some decent boost off the line. That is what is used for the Speeding Bullet STI that ran in the 9's.
I didn't think FFS worked with DBC? How does it reduce the rev's when the gas is all the way to the floor. Isn't the throttle just staying wide open? Never really looked into it before I guess.
Old 12-19-2013, 02:10 PM   #529
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Now that I think about it, I did mention FFS to Nuke and he said that hardware changes were needed. I just looked it up and it just looks like wiring in the clutch switch a little differently. I'm not sure I completely understand it, but it doesn't look too complex. I might have to explore this option in the future.
Old 12-19-2013, 02:24 PM   #530
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Yup, you got it!
Its not about reducing revs by closing the throttle, its about cutting fuel for a split second so you can complete the shift without the revs climbing. You want the throttle to say open so your manifold stays pressurized, the bypass stays closed and the turbo stays spooled. If the no-lift conditions are met, for example, throttle > 70, and the clutch switch is triggered then the ECU cuts fuel down to the rpm that it calculates the next gear to come in at to be rev matched. Think of it like dynamic rolling launch control that sits at the rpm where the next gear comes in. When you shift fast its perfectly seemless, if you shift slow for some reason, the ecu holds the revs until you lift the clutch.
Old 12-19-2013, 02:33 PM   #531
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
So it works just like the COBB FFS on the newer cars? I always thought that closed the throttle to drop the revs. If the only thing that is missing is the clutch signal, that's simple enough. Doesn't the ECU already see this, or is cruise control a completely separate entity on these cars? What I read it wasn't really clear on what ECU input it needs to be tied into?
Old 12-19-2013, 02:43 PM   #532
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
makes sense. if it closed throttle it would result in less boost(zero?) and it wouldn't be as beneficial.
SenorDucK is offline   Reply With Quote
Old 12-19-2013, 02:54 PM   #533
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Nope! It works the same way where it cuts fuel to drop the revs and lets the throttle stay open.
This thread has the info about wiring up the clutch switch. I wonder if this is only needed on certain years (maybe 02-03?) because the car I tuned was an 05 WRX running an 02 ECU and I believe it was cutting fuel on FFS without any wiring mods. The owner shifts quicker than anyone I know so perhaps it just seemed like it was cutting. I can't tell looking back at his logs and we didn't give it fair test with a slow shift. I'll have him try a slow shift and let me know if it cuts or not.
I need a few things for my wife's 02 and then its getting this rom so I'll be able to try it out on there and see what needed for FFS.
Old 12-19-2013, 03:01 PM   #534
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, I guess I had made a wrong assumption. What you're saying makes sense. You want the throttle to stay open, that's the point. I was looking at that thread, but it wasn't real clear what the ECU "input" is supposed to be.
I had FFS set up on my 2011. If you shift slow it's very obvious and works extremely well. You can FFS at a pretty leisurely rate and it still keeps boost up (unlike lift shifting). If you shift fast you can't really tell the difference either way. Even without the software set up you can't tell when you're in the car. You do see the needle jump in the videos, but it's not obvious when actually in the car.
Old 12-19-2013, 03:25 PM   #535
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Yeah... there isn't very much info on wiring this up but I bet you could PM the guy that created this rom. Going off the rom itself, it had a few different inputs you can select for the clutch switch activation input but the only one you probably want to use is called the TID switch. It has something to do with do with auto-tranny logic but I don't know what exactly. Obviously you don't need that. The input says "E1" at the ecu.
If/When I do this, I'll be trying the method with the diodes in order to keep cruise control working and I'll figure out which pin is E1 and connect to that and see if I can log the clutch switch input before I try a FFS with it.
Old 12-19-2013, 03:30 PM   #536
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
If you can figure out the pin, that would be all I need (assuming I can find the clutch switch). I would probably just snip the wires since cruise control isn't a big deal to me. It seems like it would be pretty quick and painless if you know what wire to splice into.
You should be able to test it pretty easily without actually doing a FFS. Just get up to speed, push in the clutch, and then go WOT. If it goes all the way to redline, then it's not working. If it bounces at your FFS RPM then you're good.
I had to test FFS a bunch of times when we were trying to get it to work on my 2011 on open source. I think my car was the first that got the tinywrx FFS patch working (on the 2011 ROM). It took a few revisions before it would work right.
Old 01-09-2014, 09:28 PM   #537
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Time for a new BOV.
Old 01-09-2014, 10:54 PM   #538
ehawthorne521
Member#: 149686
2002 My name is Evan
and I am an Autoholic
Very nice, I am excited for my BOV to get here too. Why are you replacing it? And is that a new intercooler underneath?
ehawthorne521 is offline   Reply With Quote
Old 01-10-2014, 09:06 AM   #539
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I had put on a TurboSmart Dual Port, but I'm swapping to a TurboXS BOV for fitment reasons. The TurboSmart will be for sale once it's off the car.
Old 01-10-2014, 11:24 AM   #540
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
Looking good
IMPORTIMAGE is offline   Reply With Quote
Old 01-10-2014, 12:27 PM   #541
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
More photos of new parts:
Old 01-10-2014, 02:24 PM   #542
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
Should've known when you said "fitment reasons" Haha. car is awesome man, keep at it!
thatsilverwrx is offline   Reply With Quote
Old 01-10-2014, 02:41 PM   #543
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Haha, yeah. I wanted to avoid adapters and going to a 100% VTA BOV reduces a bit of complexity as well. Unfortunately the BOV doesn't fit onto the fitting on the pipe. I think it's due to the powdercoat, so I'll probably just have to sand that off. Possibly a little more than that, I'm not sure yet.
Old 01-10-2014, 03:26 PM   #544
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
Very nice. That thing is bonkers fast.
Does the DCCD box handle pulling the handbrake properly to prevent center diff explosions?
evilspoons is offline   Reply With Quote
Old 01-10-2014, 03:43 PM   #545
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks!
Yes, it is wired into the handbrake to open the center diff when the brake is engaged.
Old 01-10-2014, 04:06 PM   #546
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Header and gate to go.
Zee Biker is offline   Reply With Quote
Old 01-10-2014, 04:12 PM   #547
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, I wouldn't mind that. So expensive though. I have to convince myself I shouldn't just ditch the stock location setup instead. But I'm thinking I will stay stock location for this summer at least. Just not sure if I'll shell out for the header and EWG though.
Old 01-10-2014, 05:44 PM   #548
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
What brought you to swap to the FMIC over the GS TMIC? Also, what brand is the new setup?
Old 01-10-2014, 05:49 PM   #549
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Honestly because I hate working on TMIC setups. Lol. FMIC is just so much easier. I really have no idea if the GrimmSpeed TMIC was close to maxing out but I imagine the FMIC will do better especially in avoiding heat soak. It is a "TurboXS" FMIC kit (hence the switch to a TurboXS BOV).
Old 01-11-2014, 10:18 AM   #550
blk05wrx
Member#: 180559
2016 WRX STi Limited
I hope this means you'll fit a scoop less hood. That would be a nice sleeper look.
blk05wrx is offline   Reply With Quote
