Welcome to the North American Subaru Impreza Owners Club Wednesday August 21, 2019
Old 12-10-2018, 07:10 PM   #1
futureforester1
Member#: 494576
Default Best battery +2015 WRX?
Help? What battery should I get - Deka AGM or Costco Interstate Flooded Lead Acid battery? I hear that a modification is required with the AGM due to the voltage issues with the alternator?
futureforester1 is offline   Reply With Quote
Old 12-10-2018, 07:14 PM   #2
rich3389
Member#: 207322
Both will serve you well.
rich3389 is offline   Reply With Quote
Old 12-19-2018, 01:37 AM   #3
dictoresno
Member#: 139816
2019 Impreza
I've only used and trusted interstate. I recently had one finally give up after 7 years of ownership since new...two years longer than its rated lifespan.
dictoresno is offline   Reply With Quote
Old 12-19-2018, 09:35 AM   #4
pacmantravis
Member#: 435634
2015 WRX
I have an Optima Red top in mine -- Picked it over the yellow top for cold cranking capability.
pacmantravis is offline   Reply With Quote
Old 12-19-2018, 12:29 PM   #5
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/05 GTO
"Best" anything will always be subjective depending on one's individual priorities and needs. For me it was an AGM with lots of cranking capacity and a good warranty so the '15 got a Bosch group 35 AGM. My GTO has one as well, and if/when the Red Top in the '02 finally poops out (coming up on 11 years) it will be time for #3.
Old 06-25-2019, 11:21 PM   #6
achaurey
Member#: 503617
2016 WRX 6MT Limited
Default Tomioka battery - TR-B1500
Has anyone used a Tomioka racing battery? Considering the TR-B1500 for my 16 WRX. On paper it seems much better than stock at 465 CCA and 15 lbs.
https://www.tomiokaracing.com/collec...weight-battery
https://www.tomiokaracing.com/produc...m-mounting-kit
achaurey is offline   Reply With Quote
