Welcome to the North American Subaru Impreza Owners Club Friday August 7, 2020
Old 06-27-2019, 11:29 AM   #1
Johnny_Ringo
Member#: 501207
2012 WRX 5 DOOR
Default 2012 WRX no crank, no click, no start
So I've searched the forums and other resources, not finding much that lines up with my issue. TokyoTexan had a post that was close but that was a ground issue that I've already checked off.
2012 WRX, just dropped the engine back in after rebuild and no joy.
When key is turned to on position, IP lights up, gauges sweep, radio, AC, lights all work.
Once I push in the clutch and turn to start, everything immediately cuts off.
Starter does NOT crank, and no click from solenoid.
This is keeping me from being able to read any codes with scanner or the AP.
Weird thing is, when I jump the starter and bypass ignition, the starter will crank, so seems like ignition relay or fusible link (not sure where that is).
Checked all fuses in the top section of driver side engine bay box, all are getting continuity.
Side note, car started without electrical issues prior to engine pull---pulled and rebuilt due to suspected rod bearing failure.
Did everything in the garage, so everything has been in a controlled environment (no possible issue from dealer or mechanic).
So my question to all of you that are smarter than I am:
Where is the fusible link on a '12 WRX?
Does this sound like right track to go down?
Any other ideas as to why above symptoms would occur?
Thanks for any input.
Johnny_Ringo is offline   Reply With Quote
Old 06-28-2019, 01:32 AM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
No possible issue from a legit mechanic, because you screwed it up all on your own?
Ok then.
Two things come to mind - something important didn't get plugged in - engine harness, something, or your immobilizer doesn't like your key anymore. Try a different key.
CosmoTheCat is offline   Reply With Quote
Old 07-08-2019, 09:17 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
The fact everything dies when you put a big load on it, sorta sounds like a loose or poor connection.
I would check battery connections and big grounds from engine to chassis and battery.
Fusible link is just a "fuse" built into a wire, either good or open.
Try another key, see if any difference. There is a whole thread about setting them back up in a section near the top of the main page on this forum.
Old 07-08-2019, 09:48 AM   #4
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Make sure the female spade terminal connector is attached to the starter solenoid. Check all your grounds.
Turpid Porpoise is offline   Reply With Quote
Old 07-11-2019, 08:20 AM   #5
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
As far as I know, there are no fusible links used in your model car, just normal fuses. From what you stated about the trouble and assuming that the power to the ignition switch is good and the grounding is okay it would mean there is a bad connection to power either at the ignition switch START position, or in the same wiring position after the switch.
Old 07-16-2019, 09:49 PM   #6
ascendr
Member#: 462136
02 Bugeye
Symptoms sound like voltage drop /weak battery. Get yourself a volt meter, you should have 12v at the starter/solenoid even when you turn the key to start pos., if it's lower might just need a new battery. Did you try starting it with a charger that has a high amp start mode?
ascendr is offline   Reply With Quote
