Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Old 02-26-2003, 03:27 AM   #1
dingo dave
Member#: 33177
2000 Impreza RS coup
white
Question OK, do we really need "Subaru coolant" for radiator?
I jsut got my 2000 RS with 48,000 miles & thought I'g take it to the only freakin' sub dealer in the county to get the car a good checking out and my wallet a good lessening of it's contents.
I dropped about $290 on various things, and it occurs to me that the radiator has never been flushed, so I ask how much that cost, since in the manual it says to use only "subaru" coolant. Joe Service Manager says it would cost me $100 to flush and fill radiator!?!?!?!
I say hell no and take it to an all asian repair shop (1st time there) and they do it for $35 with brand X...can't remeber what brand, but I could find out if it really matter. I assume it was a quality, industry standard brand.
So what's up with the "Subaru" coolant???? Is it needed?
dingo dave is offline   Reply With Quote
Old 02-26-2003, 04:37 AM   #2
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
I have never heard of needing special coolant. Mine sure doesn't have Subaru coolant, and it seems to work just fine. I wouldn't worry about it too much.
-Wes
RebelINS is offline   Reply With Quote
Old 02-26-2003, 05:21 AM   #3
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Supposedly it's formulated to prevent any reaction w/ the aluminum block material that would cause mineral build-up in the longterm.
Honestly, it's probably just Prestone or some other brand re-labelled. I just figure for a coupla bucks more, why the hell not? Just do the flush yourself so you don't get killed by dealer labor charges.
US2JDM is offline   Reply With Quote
Old 02-26-2003, 10:19 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
You're fine. They say that to make more money
Eric SS is offline   Reply With Quote
Old 02-26-2003, 10:37 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
not even CLOSE in consistency. Even when it's already cut with distilled water it's still 3 times thicker then Prestone or any aftermarket coolant. All i reccomend is using factory coolant in all vehicles.
Jeremy
Old 02-26-2003, 01:28 PM   #6
Siper2
Member#: 1134
2015 Outback H-6
HndaTch627,
Maybe so, but sometimes you need to fill up when you're not at the dealer. How much do they charge for a jug of that stuff at Subaru? I get this creepin' feeling that it's like $20, and that's pretty steep for coolant. Dropping Prestone into my radiator has never caused any problems.
So what's the argument? Seriously, I want to know.
-S2-
Siper2 is offline   Reply With Quote
Old 02-26-2003, 03:02 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Old 02-26-2003, 03:18 PM   #8
dingo dave
Member#: 33177
white
Last time I was told to specifically get a part from the dealer it was my oil filter. I paid six bucks apiece for 4 filters, got home, and saw a big Puralator/Subaru stamp on all four filters.
If all the Subaru coolant is going to do is protect radiator down to (-)x degrees then I should be fine with prestone, etc, (since I live in TX).
Unless the sub coolant has more benefits than protecting at lower temps I don't think I'll mess with it. Please correct me if i'm wrong.
Also, I heard it's ok to pour coolant into toilet? Is this true???? The only reason I took it to a shop to get it flushed is becasue the only place that takes radioator coolant around here is 20 minutes away and only open from noon-4 PM on weekdays(Environmental Collection Center).
Old 02-26-2003, 03:23 PM   #9
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
A gallon of Subaru coolant at full list price is $12.36, so you won't get killed in price for it at a local dealership. If it comes in a one gallon jug, I don't care who told you it was premixed, it's not . The text on the jug is as follows:
(Insert poison control junk here)... The product contains ethylene glycol, dietheyle glycol, and inorganic/organic acid salts. Do not store in open or unlabelled containers.
It then goes on to "performance":
Subaru Long Life coolant is an ethylene glycol base product for long-lasting aluminum and all other component's protection. Subaru Long Life Coolant has been developed to provide corrosion and rust protection of all cooling system components. Requires no additional corrosion inhibitors. A 50/50 mixture of Subaru Long Life Coolant and water is recommended for year round protection.
As for the freeze protection:
50/50 Mix:
Freezing Point -34 deg F
Boiling Point 265 deg F
70/30 Mix:
Freezing Point -84 deg F
Boiling Point 276 deg F
Brian
http://www.subaruwrxparts.com
http://www.wrxstiparts.com
http://www.subarubajaparts.com
Old 02-26-2003, 05:11 PM   #10
Siper2
Member#: 1134
2015 Outback H-6
So Brian do you basically agree that I ought to use Subaru stuff?
Your working at Exeter can't have any bearing on your decision.
Damn the man.
Old 02-26-2003, 07:01 PM   #11
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Read my post
Legacy777 is offline   Reply With Quote
Old 02-26-2003, 07:41 PM   #12
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
I won't tell you what I pay for it . In all seriousness though, other than it being perhaps a pain to go to the dealership and pick up, there's no real reason not to use it IMHO. It may be twice what other antifreeze costs, but Subaru makes coolant for the cars for a reason, and it wasn't to get $12 out of people. They made it because the wanted a coolant with certain life expectancy, freeze/boil characteristics, and corrosion inhibitors. If they could have used something cheaper (costs less I should say), and off the shelf with the properties they wanted, that you can get at any Autozone or PepBoys, don't you think they would have ?
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.deniedmywarranty.org
Old 02-26-2003, 10:05 PM   #13
yamahito
Member#: 31908
1999 Impreza RS
Rally Blue
Buy only the Subaru coolant. It is silicate free coolant which is less corosive on your engine internals. If you use dex-cool the mixture of the old and the new dex-cool will coagulate and gunk up on everything. Everyone talks about getting ripped off by buying this....OKaaaaay. Most mods are $200-$800 and they're worried about $5. Anyway, after researching all the posts about coolant on NASIOC thats what I found. Hope this makes your decision easier.
yamahito is offline   Reply With Quote
Old 02-27-2003, 02:23 AM   #14
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Yes, in fact in cold weather climate areas you are supposed to use anti-freese to keep your pipes from freezing in the winter. My family has a cabin up in the Sierra mountains, and we always use anti-freeze in all the sinks/toilets or the pipes will completely freeze up.
Old 02-27-2003, 01:53 PM   #15
Siper2
Member#: 1134
2015 Outback H-6
Well... I've never had to fill up my reservoir more than maybe a little bit here or there, at which time I used Prestone or whatever I had on me. The major fillups were always done at the dealership I assume, and I think flushes were done at 30k and 60k services.
Guess I'll buy some SOA stuff.
Old 02-27-2003, 02:26 PM   #16
subiewrx
Member#: 22123
2002 WRX Wagon
Sedona Red
Hmmm. The bottle of Zerex Extreme I have in the basement (ok, now it's on my desk) has the following info on it:
50/50 Mix: -34F Freeze, 265F Boil
Its patented extended life formula is phosphate and silicate free and helps protect engines from rust and corrosion for 5 years or 150,000 miles
Protects all cooling system metals, including aluminum
Oh - regarding antifreeze disposal: be careful if you are on a septic system; the antifreeze can kill the bacteria.
From http://www.epa.gov/grtlakes/seahome/...e/antifrze.htm
The major components of antifreeze can be broken down by organisms in a sewage treatment plant. If your home is connected to a sanitary or municipal sewer system, household quantities of antifreeze can be flushed down the drain with plenty of water. The solution is not so easy for those homes with a septic tank because antifreeze can overwhelm the organisms in your septic system, causing damage to the system. If your wastewater goes into a septic tank, very small amounts over a period of time can be flushed with plenty of water. Better yet, ask a friend, relative, or neighbor who is hooked up to the sanitary sewer system to use their drain to dispose of your household quantity of used antifreeze. Do not pour antifreeze into storm sewer openings, sinkholes, or abandoned wells where they will directly pollute the water.
subiewrx is offline   Reply With Quote
Old 02-27-2003, 07:40 PM   #17
cvalle-sd
Member#: 420
2001 Cr-V
If you live in a warm climate, will distilled water and hy-per lube or water wetter provide enough corrosion protection?
I'm thinking no...
cvalle-sd is offline   Reply With Quote
Do we REALLY need a new thread for every youtube video clip? CandyO Off-Topic 4647 Today 05:54 PM
do we really need to use a T-T or not? veightkiller Vancouver Impreza Club Forum -- VIC 13 01-16-2005 07:56 PM
Do we really need to run the engine during daytime? sabelt Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 09-16-2004 06:36 PM
do we really need guns? SpeedShift Political Playground - Chaotic Neutral Edition 265 08-21-2003 02:09 PM
