Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2018
Old 01-17-2018, 05:07 PM   #1
DieselClown
Member#: 36135
2005 WRX
Question *Pls look at this pic* smoking from turbo
It's an 05 WRX and it started smoking after getting up to temp. I see oil on the hotside area. Does anybody know what could the cause be?
IMG_3355 by dieselclown, on Flickr
DieselClown is offline   Reply With Quote
Old 01-17-2018, 05:59 PM   #2
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
That is right where the oil feed line is. The gaskets for that banjo bolt must have failed. Replace them and torque them to spec. That is where I would start.
PSolbergfan is offline   Reply With Quote
Old 01-17-2018, 07:26 PM   #3
DieselClown
Member#: 36135
2005 WRX
Thanks! Do you where can I find these gaskets?
Old 01-17-2018, 07:51 PM   #4
DieselClown
Member#: 36135
2005 WRX
if the banjo bolt is the one right on top with the little pipe running out of it, then that may be it. I just turned it on and saw oil dripping out of that bolt.
EDIT: i found a pic, oil it coming out from right under the bolt circled on the left.
Do i just get the OEM bolt and then remove and install and torque? What spec is it supposed to be? I have a vf39 if that makes a difference.
https://www.rallysportdirect.com/par...lt-with-screen
Old 01-18-2018, 12:30 PM   #5
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You don't need a new banjo bolt.
Appears you need NEW copper gaskets that go on either side of the banjo bolt.
Is / was the bolt loose? It may just need to be tightened.
I don't remember what size the copper gasket is, but you can pull one and take it to a good hardware store and buy new ones.
Old 01-19-2018, 05:41 AM   #6
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
You can get the gaskets at your local Subaru dealer parts department.
Old 01-19-2018, 12:01 PM   #7
86Dreams
Member#: 385256
02 WRX S204 swap
86Dreams is online now   Reply With Quote
Old 01-19-2018, 08:30 PM   #8
DieselClown
Member#: 36135
2005 WRX
Originally Posted by 86Dreams View Post
thanks! does it matter that mine is a vf39 turbo and not the td04?
Old 01-19-2018, 11:47 PM   #9
WRXRgr
Member#: 54942
2004 WRX
The copper washers just need to fit the bolt.
If you get the bolt off and check the washer,
another possible source is Harbor Freight--
https://www.harborfreight.com/80-pie...ent-67526.html
Possible, as I don't know the size of that bolt.
WRXRgr is offline   Reply With Quote
Old 01-22-2018, 08:59 AM   #10
Samurai Jack
Member#: 21145
2002 Enemy of Aku
No. You just need the right size copper gasket to fit the bolt / fitting.
Not too big, not too small, but juuuusstt right
Hardware stores, auto part stores, Dealer
Old 01-22-2018, 01:39 PM   #11
jkenna860
Member#: 369375
2002 Subaru WRX
Sedona Red Pearl
Could also use some Verneir calipers to get the OD and ID of the copper washer and then just order some from McMaster Carr. Thats the cheapest route and you can order more than you need so that you have extras
jkenna860 is offline   Reply With Quote
Old 01-22-2018, 01:52 PM   #12
Samurai Jack
Member#: 21145
2002 Enemy of Aku
There is a thread over in the Brake section.
Someone posted a link to copper gaskets on Amazon.
Somewhere between $8 and $9 for 50 copper gaskets, all same size.
18 cents per gasket is pretty cheap.
You just need to know what size gasket you need.
Old 01-22-2018, 05:40 PM   #13
head83
Member#: 80636
I am having the same issue of smoke in that region and trying to ID the source. Please let us know what the final resolution to this was.
head83 is offline   Reply With Quote
Old 01-22-2018, 09:39 PM   #14
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Hybrid Swapped WRB
Default *Pls look at this pic* smoking from turbo
other common smoke in the turbo area cause is the turbo drain back oil tube
as well as the power steering lines failing where they turn from rubber to steel line
Also valve cover gaskets like to leak onto the up pipe and smoke really a lot going on over there
Valarius Starchaser is offline   Reply With Quote
Old 01-23-2018, 09:07 AM   #15
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You are going to have to clean up the area and look around for possible sources for your leak.
That includes reaching everything from both on top and below the motor.
Clean everything up as best you can, then run the car for a short period, or take car for a short run, and then re-check.
as well as the power steering lines failing where they turn from river to steel line
I HOPE you meant RUBBER, not river
Damn, I hate the automatic spell checker/corrector
