03-25-2008, 08:31 PM | #1 |
Member#: 122375
NESIC
Vehicle:03.7 I own 2 of them White & Black |
Power all the way to 8000RPM!!!
Someone who knows Turbos answer this question, what turbo(s) can make power all the way to 8000RPM or higher?
03-25-2008, 08:33 PM | #2 |
Member#: 102140
South East
Vehicle:2016 Single Speed or Death |
it has nothing to do with your turbo, it has to do with your motor, specifically your cams/valves/retainers.
some camshafts can give more low end grunt, some get more mid, and some give better top end. |
03-25-2008, 08:50 PM | #3 |
Member#: 122375
NESIC
i know this but at the same time, sometimes turbos stop making at a certain RPM
03-25-2008, 09:01 PM | #4 |
Member#: 157002
South East
Vehicle:2011 Street Mod STI 11.4 @ 127 |
There are so many variables that play into this it's going to be hard for you to get a straight answer, tbh. What motor is this turbo going on?
03-25-2008, 09:02 PM | #5 |
Member#: 102140
South East
external wastegate + big turbo. but it won't spool ever till high RPMs.
8k rpms you will need upgraded valvetrain to rev that high |
03-25-2008, 09:13 PM | #6 |
Member#: 122375
NESIC
03-25-2008, 09:33 PM | #7 |
Member#: 99102
South East
Vehicle:17 BMW M2 Long Beach Blue 6MT |
^dont forget oil pump... a jdm 12mm would do nicely...
03-25-2008, 09:34 PM | #8 |
Member#: 143941
NESIC
Vehicle:04 STI JBP 07 LIMITED #602/ 06 BUSA |
Just from what I have seen, pretty sure anything 35R or bigger with the right engine to push it there would be the answer.
03-25-2008, 09:56 PM | #9 | |
Member#: 114527
Vehicle:2004 STi WRB |
http://cybrina.mine.nu/MR2_Docs/comp..._flow_maps.htm |
03-26-2008, 04:57 AM | #10 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
lot's of headwork and a 35r.
or an S2000. pick one. |
03-26-2008, 06:23 AM | #11 |
Member#: 126696
SWIC
Vehicle:2002 Fatbody bugeye 03 R1 09 Raptor 700R |
03-26-2008, 10:26 AM | #12 |
Member#: 115223
Vehicle:2005 Subaru STI silver |
FP green or bigger should work... but you may not be happy w/ the green on a built block. What are you going to be using the car for 1/4 mile, auto-x, etc? If your planning to be running more then 20 psi and or meth/race gas you may want to go bigger 30r+.
03-26-2008, 12:14 PM | #13 |
Member#: 134036
BAIC
Vehicle:2007 STi Limited Satin White Pearl |
Don't forget an intake manifold. The super-long WRX and STI intake runners, coupled with the tiny plenum volume, makes high-RPM power even more difficult to achieve.
03-26-2008, 08:29 PM | #14 |
Member#: 162942
Vehicle:2006 STi Black&Gold Stage 2 |
A turbo out of a deisel
03-26-2008, 10:33 PM | #15 |
Member#: 123491
South East
Vehicle:2022 WRX WR BLUE |
03-27-2008, 08:35 AM | #16 |
Member#: 95840
NWIC
03-27-2008, 12:31 PM | #17 |
Member#: 60142
Vehicle:2011 WRX Grey |
03-27-2008, 05:32 PM | #18 |
Member#: 95840
NWIC
03-27-2008, 06:37 PM | #19 |
Member#: 21445
Vehicle:08 STI silver |
03-28-2008, 08:56 AM | #20 |
Member#: 95840
NWIC
03-28-2008, 10:43 AM | #21 | |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
3076 is the next turbo to go on my car |
03-28-2008, 11:04 AM | #22 |
Member#: 64572
TXIC
Vehicle:9310 supra, c63 white, matte silver |
03-28-2008, 11:30 AM | #23 | ||
Member#: 148681
Vehicle:TBD Looking for STI Back in the Game! |
Still running stock heads, I will see how well the GT30R works on upcoming install and tune. I run a Cosworth 12mm High Flow Oil Pump with cross drilled crank thats been balanced as well. Quote:
We all know that once the power starts dropping theres no sense to keep pushing it. To consistently and safely (in USDM Subbies) rev to 8000RPM's you will need to have a built SB/cams/P&P heads/full valve train upgrade. Last edited by 4ST-AIR; 03-28-2008 at 11:37 AM. |
03-28-2008, 11:35 AM | #24 |
Member#: 99102
South East
^^so could you put that oil pump sti, and spin it to 8k with stock valvetrain, heads, shortblock?
03-28-2008, 11:39 AM | #25 |
Member#: 148681
WTB: 2005 STI Center console (from the AC controls all the way to the armrest) | 1FSTREX | Private 'Wanted' Classifieds | 1 | 08-31-2006 04:46 PM |
Pedophilia goes all the way to the top! | Mr.Tickles | Political Playground - Chaotic Neutral Edition | 14 | 03-15-2005 12:28 PM |
I think I'm going all the way to the dark side | MattSEG | Off-Topic | 21 | 10-24-2004 04:13 AM |
Do I have to remove the IC all the way to install Oil Temp in Front Gallery? | Irishman | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 10-11-2004 10:27 AM |
Grinding noise with clutch all the way to the floor | TrogDorWrx | Transmission (AT/MT) & Driveline | 4 | 07-31-2004 02:25 PM |
