03-21-2009, 04:32 PM | #1 |
Member#: 206199
Vehicle:2004 WRX WRB |
lookin to start a hybrid build maybe
start off by saying sorry if this is already on here and most of the hybrid builds have different mods so i figured i just start one with my mods
my mods are full exhaust header up pipe TBE and Fender CA and a zoom stage one clutch my questions are i have a 2004 wrx with blown rings or sumthin along those lines i have the chance to get a 06 sti long block. would it be better to run the sti motor(my concern is trans). or build a hybrid motor? i kinda wanna build the hybrid motor. i know i need sti HG water pump or will the wrx one work (its new). timing belt and tensioner or will the WRX one work (new also). as for turbo i wanted to run the stock tdo4 with maybe a pound or 2 over stock boost and a tune by 555. anything else i may need advice anything to help me out a little here thanks James
03-21-2009, 04:56 PM | #2 |
Member#: 85036
Vehicle:2013 PBP sti ltd 05 LGT 35r 30psi..busted |
regardless of it being a hybrid or a full sti longblock, the 2.5 bottom end is going to make a lot more torque, and it is only a matter of time when the 5 speed goes. A lot has to do with your driving style too! If you can get an sti longblock, with all the harnesses, ecu, and dash for a good deal (and can afford it) then that is the better route.
P.S. I hate to be the one saying this, but you need to search, this has been covered and done so many times. DK |
03-21-2009, 05:05 PM | #3 |
Member#: 206199
y dash? and ya im sorry i spent like 2 hours reading and what not but most of the other poster were like i wanna make 300 400 500 hp im not lookin to do that so i figured id post one
03-21-2009, 05:26 PM | #4 |
Member#: 163445
Vehicle:l33t ******* [email protected] |
Hybrids tend to be problematic.. Not a bad Idea but personally I would pickup some used 257 heads and just do the longblock....
-Jerod |
03-21-2009, 05:52 PM | #5 |
Member#: 189660
Vehicle:'02 WRX Element Tuning Race Team |
If you do the full LB, will the WRX harness work? Or by running the 257 heads do you automatically need the STI harness?
03-21-2009, 08:02 PM | #6 |
Member#: 163445
I think there are a few differences. mainly AVCS... I would just pickup a top engine harness either new or used and then do the couple of wires for the AVCS from the enginebay to the ecu... I think there may also be a company that makes a harness or conversion for this...
-jerod |
03-21-2009, 08:11 PM | #7 |
Member#: 189660
Ah, good info. What if I don't want to run AVCS? I know you have to plug the holes on the intake cams.
03-21-2009, 08:15 PM | #8 |
Member#: 163445
No biggy then - you could probably run a 2.0 ecu as well then...
-Jerod |
03-21-2009, 09:01 PM | #9 |
Member#: 189660
Sounds good.
After doing more research, all you need to do is:
Am I missing anything? |
03-21-2009, 09:05 PM | #10 |
Member#: 163445
Sounds about right... I'm not 100% positive though..
I'd consider running 264 non avcs cams - kelford or such... I'd also run a td06-20g with an 8cm2 turbine housing. You'll have early boost - a good amount of power and those cams will really compliment it... -Jerod |
03-21-2009, 09:35 PM | #11 |
Member#: 189660
Right now, I'm trying to save money wherever possible. I'm not making a crazy build, similar to the OP. Just a reliable DD re-using my DB small 16g.
03-22-2009, 12:24 AM | #12 |
Member#: 163445
Why not stick with the 205? It has more potential than alot give it credit for..
-Jerod |
03-22-2009, 12:36 AM | #13 |
Member#: 189660
Honestly, I don't feel like rebuilding it. I don't have the time to take the motor apart, and start from scratch. I'm on a budget and I have time constraints. Plus, getting the 257 now helps with my plans for the future when I have more time and money to make a beast. But for now, a stockish STI SB/LB or Hybrid build will do
03-22-2009, 01:17 PM | #14 |
Member#: 206199
if i do the long block will my water pump and all the accessory's work on the sti or do i need "sti" accessorys
03-22-2009, 01:40 PM | #15 |
Member#: 163445
There were some revisions - but yes I do think they will... I know PS pump - ac - alternator will forsure.
-Jerod |
03-23-2009, 01:26 AM | #16 |
Member#: 206199
ok thanks
03-23-2009, 07:02 AM | #17 | |
Member#: 12811
South East
Vehicle:2002 2.5l Wrx 517whp/516wtq (Stage pi) |
If you get a long block all you have to do is [*]Drill &Tap location for WRX cam sensor on EJ257 If you have the avcs oil lines hooked up you shouldn't block holes on the intake cams. I know for sure the intake cam gear on the 04 sti has a point for the cam sensor to pick up a signal from. Other years may have it as well but I always use an 04 gear when I swap in a long block. |
03-23-2009, 09:54 PM | #18 |
Member#: 156619
Vehicle:2004 WRX 2.5 hybrid FP EVOIII 16g |
hybrid
well i just finished up my hybrid build this weekend, i have to say so far so good, my mod list is a bit more than what you have but, i have to say it was good build for my budget i spent around 3200, im running a map for my utec delta till breakin is over then its down to turbo xs for the tuning!! so in all if no problems occur i will have about 3700 buck in the whole build, i have about 150 miles on it so far and i cant complain one bit!!
modd list b4 hybrid swap Megan racing uppipe and header sr*s turbo back greddy profect spec B Electronic boost controller FP Evo III 16g 255lhp Utec delta Spec stage 2 clutch kit Modds for hybrid swap ej257 shortblock Modd Wrx injectors by witch hunter TGV deletes (done myself) Group-n sti motor mounts Also i did all my Labor myself which saved me about 2000 bucks but it was well worth it!!! |
03-24-2009, 01:40 PM | #19 |
Member#: 206199
sweet well my car is for sale on ebay it ends sonday if it dont sell i am gunna start the build the only problem is its gotta be done by april 20 so i can go to school if it sells imma go buy some cheap good on gas car. been look at 2003 SER spec v any1 hear anything about them
03-26-2009, 02:29 AM | #20 |
Member#: 206199
nothing on the spec v ???
Similar Threads | ||||
2.0 to 2.5 hybrid build question | mvcsk8r | Built Motor Discussion | 3 | 07-27-2014 08:30 PM |
Lookin to start a build soon.. advice or opions plz | wiseyZ32 | Built Motor Discussion | 1 | 10-11-2009 06:09 PM |
Funky WRX > STI via RS Block Hybrid build to save cash - CAN I DO THIS? | Fongers | Built Motor Discussion | 24 | 12-28-2008 08:41 PM |
lookin to start a meet in westlake | boardertj | Southern California Impreza Club Forum -- SCIC | 8 | 09-15-2004 07:06 PM |
I want to build a rally car... but I don't know where to start. | majglow | Motorsports | 25 | 04-24-2002 12:55 PM |
