03-24-2009, 10:21 PM | #26 | ||
Member#: 28685
Vehicle:2004 FXT 4EAT very STi'd |
03-24-2009, 10:48 PM | #27 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
for the usage you are talking about, the stock rods shouldn't have an issue. You aren't living at high rpms, so much as visiting the edge of 8k if needed.
That video was sweet!! wish they had plugged the head's oil feed though, so they could have flogged it to failure. Making the oil slick was also a definate dickhead move though. |
03-25-2009, 12:48 AM | #28 | |
Member#: 173241
TXIC
Vehicle:2002 s256 twinscroll now with one more gear |
what allows the jdm stis to run so good at higher rpms??? are their cams that good? |
03-25-2009, 12:53 AM | #29 |
Member#: 173241
TXIC
i thought it was pretty sweet, makes you wonder how spark and air and fuel get in there that quick
03-25-2009, 01:21 AM | #30 |
Member#: 191491
NESIC
Vehicle:2011 Forester |
Ever seen a high revving glow engine, these things go in excess of 50,000 rpm's. Not quite the same when your talking about something that displaces a few cc and is a simple 2 stroke, but they are still increadible and can put out around 1 hp per cc. Thats the same power/volume of a top fuel dragster, but this is naturally aspirated, runs on fuel that is about 5-25% nitro instead of 90%, and doesn't need to be rebuilt every time you play with it!
http://www.youtube.com/watch?v=VPmwx...eature=related |
03-25-2009, 07:47 AM | #31 | |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Our EJ25D has seen it's way to 8125 on many occassions, but it's never there longer than 1 whole second. It's still running stock RS valve springs and bottom end. So for short bursts up there and beyond, I think the plan is solid as is. Tracking it, is different, where g loads are generated much longer, effecting the oiling.
Jay Quote:
03-25-2009, 11:08 AM | #32 | ||
Member#: 33782
03-25-2009, 12:36 PM | #33 |
Member#: 5218
Yeah, I know.......but rules are rules. That's why I keep (well, kept) a supply of "spares" just in case. Turns "disaster" into an "inconvenience". If we ever decide to prep that car for Targa, it'll be one of the first things addressed......
Jay PS: Micah, this is the same car I brought to the subie challenge in Richmond....way-way back when. |
03-25-2009, 01:19 PM | #34 |
Member#: 33782
oh jeebus...back after hurrican Isabelle. Wasn't it Cloverleaf mall?
That wasn't but maybe a year after I had my wrx swap done in my white 4-door (otherwise stock) L [/threadjacking] |
03-25-2009, 11:39 PM | #35 |
Member#: 5218
^^^Precisely! Thems was the good ol days!!!!
Ontopic...... uh, I don't remember what I was gonna say..... Jay |
03-26-2009, 12:35 AM | #36 |
Member#: 95109
The bottom line is no one here can tell you if its going to last. I've hit 8000rpms on a bone stock 2.0 that I didn't care about a bunch of times.
03-26-2009, 02:33 AM | #37 | |
Member#: 20474
Japanparts replies
This is achieved by using: a nitrided, cross-drilled crank, blueprinted + balanced engine assembly, big-port heads, aggressive cams + ECU remap I'm sure there are other tricks up STi's sleeve for the Spec C's + Type RA-R's, but that's basically what the differences are GW Japanparts.com * Since 1996 * Last edited by japanparts; 03-27-2009 at 12:28 AM. |
Power all the way to 8000RPM!!! | wrx03.4wz | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 61 | 12-24-2009 12:52 PM |
Engine oil loss when high Rev to 8000rpm | joekerk | Built Motor Discussion | 9 | 07-21-2008 11:57 PM |
is reving to redline bad? | Veloxity | Newbies & FAQs | 33 | 05-10-2008 11:18 AM |
The car reved to redline would not stop then the motor blew?? WTF | mrtrex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 18 | 03-15-2008 03:04 AM |
reving to like 8000RPM,no rev limiter... possible? | Go_Rex_Go | Newbies & FAQs | 21 | 08-17-2006 09:15 AM |
