Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 01-23-2018, 02:53 PM   #1
cmiovino
Member#: 134005
2004 WRX Premium
Default 4EAT/Diffs Plan
2004 WRX used for autocross exclusively (Stage 2, 136k). Minimal commuting, maybe 2-3 times a month. Vehicle sees approximately 20-25 events per season and also a few drives to events 3 hours away.
I'm currently running Subaru ATF-HP, fluid and filter were changed about 35k ago. Front and rear diffs are running Extra-S. All this was changed about 4-5 years ago.
Plans:
- Subaru ATF-HP for the tranny, new external filter, same washer as the oil.
- 3 quarts Motul Gear 300 (75w90) for the front/rear diff. No rear diff washer, front diff has a separate part number.
Process:
- Drain and fill for the ATF. Buying at least 8 quarts and doing this method twice. Changing the filter after the final time. Check fluid level when warm and running.
- Rear diff seems easiest. Drain and fill until it comes out (approx 0.8 quarts). Purchased a pump to help get the fluid in.
- Front diff, T-70 bit purchased. Drain, new washer, fill via dipstick (1.2 quarts).
Anything I'm missing? Comments on process or oil used?
Old 01-25-2018, 12:52 AM   #2
Drew's Rex
Member#: 151422
2005 Impreza T
I would get an trans cooler if anything. Cooling system in the subie is not the greatest. Maybe upgrade the radiator.
Drew's Rex is offline   Reply With Quote
Old 01-25-2018, 10:57 AM   #3
cmiovino
Member#: 134005
2004 WRX Premium
Radiator is already upgraded to a Koyo unit. Point taken on the trans cooler.
Old 02-18-2018, 11:35 AM   #4
Wussman24
Member#: 157283
2003 2.5RS
Rattl'd white
Did i miss something or do you already have a trans cooler. Ifyou have upgraded your radiator, what did you hook your transmission lines to? The stock radiator has a trans cooler at the bottom and you lose that with any aluminum upgrade.
Wussman24 is offline   Reply With Quote
Old 02-20-2018, 09:45 AM   #5
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
there is no aftermarket full aluminum rads for AT subarus that have the trans cooler built in.
there are only OEM replacements. if you bought a Koyo Alum rad, you have no trans cooler. you will need to install an external cooler.
Titter is offline   Reply With Quote
Old 02-20-2018, 11:32 AM   #6
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Are you sure about that?
https://www.rallysportdirect.com/par...c-transmission
This Koyo has the provision for the AT cooler built in
Old 02-21-2018, 08:17 AM   #7
cmiovino
Member#: 134005
2004 WRX Premium
Bingo, this is the exact one I used.
Old 02-21-2018, 09:52 AM   #8
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
yes im sure. thats an OEM replacement, not a full aluminum.
mishimoto also makes one.
noone makes a full aluminum AT rad. i looked for months.
but glad the OP has a cooler installed . i didnt know koyo made oem replacements. i only thought they did full aluminum.
Old 02-21-2018, 11:02 AM   #9
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Sorry, you DID say full aluminum.
Old 02-21-2018, 07:44 PM   #10
jamal
Member#: 71875
You could probably use this one and run the trans lines to it instead of setting up the oil cooler.
https://www.rallysportdirect.com/par...sandwich-plate
jamal is offline   Reply With Quote
Old 02-21-2018, 09:26 PM   #11
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
thatís a nifty piece. good find!
you would need custom lines. the oem lines wont fit those connectors. 4plate isnt that big. it might not cool enough if u drive with a heavy foot.
