10-03-2016, 10:16 PM | #1 |
Member Sales Rating: (15)
Member#: 397425
NESIC
Vehicle:2003 Impreza 2.5RS Platinum Silver Metallic |
CT: 2004 Subaru Impreza WRX Part Out
https://www.flickr.com/photos/127983232@N06/
JDM Subaru Impreza WRX STI V8 frame/headlight frame from front clip T-spec 3.0 Farad capacitor (BRAND NEW) Rear calipers Rear Bumper Beam Rear deck lid Door trim panels Door controls Center console Gas door Front seat belts A/C Blower motor transistor Airbag sensor Door handle trim Rear Passenger Rear Hub Rear diff cover Rear trailing arms Cluster Trim Abs system Clutch Master A/C Condenser Starter Brake Booster Wiper fluid bottle Wiper Shroud A/C Line Driver Side Kick Panel W/ Coin Box Passenger side rear quarter Rear window Dash with air vents and trim Dash support Dash panel with vin Steering column Steering knuckle Clock spring Windshield wiper stalk Sun visors Rear view mirror visor Rear view mirror Passenger side rear window Rear sway bar Front sway bar Hvac air ducts under seat Bottom plastic steering column cover Jdm front bumper foam insert Headunit E Brake lever Center console Ash tray Gas tank Gas tank straps Gas filler neck Fuel pump Passenger side rear hub Rear trailing arms Gauge cluster trim Abs wires Clutch master cylinder Wiper arms Ac line Rear diff Crossmember k-frame Front crossmember Rear crossmember Driver side rear axle Front axles Rear bumper support Plastics $10 each and more.... I'll sell everything for $1500 Sold: Engine, TD04, TMIC, intake, transmission, wheels, front bumper beam, front bumper cover, rear bumper cover, hood, trunk, doors, front fenders, skirts, headlights, taillights, 3rd brake light, fog lights, struts, passenger air bag, shift knob, downpipe, power steering pump, power steering, transmission x-member, front u-subframe, throttle cable, headlight stalk, climate controls, passenger front hub, driver front hub, pedal assembly, driveshaft, carpet, radiator, alternator, gauge cluster, wiper assembly, front calipers, compressor, rear seat belts, alternator cover, hood latch, trunk torsion bars, extended arm rest, wiper arms, wiper motor, abs pump, front passenger door trim, ecu and more..
10-19-2016, 05:31 PM | #18 |
Member Sales Rating: (9)
Member#: 328769
NESIC
Vehicle:2005 WRB WRX 2007 UGM 2.5i |
Do you have this cord/wire harness? It's for the spoiler 3rd brake light. Stupid request but I've looked everywhere local can't find one
