Welcome to the North American Subaru Impreza Owners Club Saturday October 1, 2022
Old 06-06-2022, 08:59 PM   #1
venoza
Member#: 524368
Default 20 Ton Press Couldnít Push Bearing Out
So I rode a bad bearing for easily 4k+ miles across the country. went to replace it when i got home and seals where shot, one ball was missing, it was bad. I removed the entire knuckle to try and press the bearing casing out
but it didnít budge. the adapters we were using to press it out actually warped and broke. like 4 of them, then our press blew a seal. anyways i decided to scrap it and am now looking for a loaded knuckle.
through opposedforces(the website) i found the part number for the knuckle and was able to find a knuckle but itís without i also found that foresters have the same knuckle.
I couldnít find a loaded knuckle for my impreza but i found one for a forester that has the same knuckle.
all the websites state it doesnít fit my model but i donít see what can be so different if the knuckle is the same?
dust cover maybe?
any help is appreciated!
venoza is offline   Reply With Quote
Old 07-15-2022, 09:20 PM   #2
Cujo31
Member#: 19843
2000 2.5 RS Sedan
2016 Base 5MT VRP
I've had good luck finding usable knuckles the local junkyard
Cujo31 is offline   Reply With Quote
Old 09-10-2022, 09:57 AM   #3
Shiloh51933
Member#: 498320
2005 Saab 9-2x Aero
Red
dust cover maybe?
I'm guessing you guys were using a mechanical driven press from harbor freight...they don't last but you should have been able to push a bearing out. I'd start searching the local junkyard in your area so you can visually inspect with your knuckle side by side. Subaru WRX rear wheel bearings can be a PITA!!
Shiloh51933 is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
