Welcome to the North American Subaru Impreza Owners Club Saturday October 1, 2022
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Closed Thread
Old 12-23-2005, 10:08 AM   #1
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
Exclamation 04 and early 05 F-XT owners Please Read
I did post this in the 2.5L turbo forum but in case you have not gotten there. Now that there has been at least one major problem due to the filter I thought I'd post it here too:
http://www.scoobymods.com/forums/showthread.php?p=20694
If you can't view the info on scoobymods it's because you need to register. It's free to do so though.
Peaty
Peaty is offline
Old 12-23-2005, 10:30 AM   #2
Chiketkd
Member#: 71634
In hibernation...
Great info Peaty. I see it can also affect '04 Baja Turbo and STI owners. Glad you posted it in the 2.5L turbo section as well.
Chiketkd is offline
Old 12-23-2005, 10:41 AM   #3
AaronB
Worst Mod Ever
Member#: 369
19 CTS-V, 18 XC90
17 GTI
Thanks for the reminder Peaty I had totally forgotten about this. Ordered up my washers today.
AaronB is offline
Old 12-23-2005, 10:49 AM   #4
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
Forester
About the washers, I agree it's a good idea to change them, however we have had a few people reuse them and just add a few ft/lbs to the torque spec and did not have any leaks. When I did the page I wanted to show people how to do it the proper way so I changed the washers, the TSB does not even say to replace them but still, I wanted to minimize the chance for leaking. At this point because I've seen what can happen, I'd chance not replacing them if it means you are going to not do it because you don't want to bother ordering the washers
Peaty is offline
Old 12-23-2005, 10:51 AM   #5
AaronB
Worst Mod Ever
Member#: 369
19 CTS-V, 18 XC90
17 GTI
Agreed, but I can't stand oil leaks!
AaronB is offline
Old 12-23-2005, 11:37 AM   #6
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
Forester
This is why we do things the right way even if it's more work
As the saying goes, "Not many people take the time to do it right the first time but a lot of people take the time to fix their mistakes" or something like that
Peaty is offline
Old 12-23-2005, 12:45 PM   #7
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
Thanks again Peaty! I'm going to follow your mod write-up this weekend!
Happy Holidays!
Jfrankon is offline
Old 12-23-2005, 11:58 PM   #8
GTP
Member#: 73689
I did this took 30 minutes I re-used the washers because I noticed a rougher idle over the past few days and decided to not wait to do this. Thankfully a little more stank on the torque wrench and no leaks.
GTP is offline
Old 12-24-2005, 12:33 AM   #9
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
Forester
We're your filters still in the bolt or did they drop out?
Edit: never mind I just saw your post on SF.com I guess they did. So far everyone that has checked has had them drop
Peaty is offline
Old 12-28-2005, 02:26 PM   #10
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
Thumbs up
Happy Holidays!
Well, I couldn't wait for the weekend, so I did it this morning. Here are my observations:
1) Took me about 30mins start to finish.
2) I used the original washers, torqued down to 23 ft/lbs...no leakage.
3) Both filters were down in the banjo, but were easily fished out with the needle nose (no damage to either).
4) Car idle is now so much more refined, and dare I say quieter. This is not in my freakin head
Peaty, mucho gracias . You give us the confidence to do these things. Without your write-ups, I wouldn't even think of doing this myself. Plus, they are fun (usually) to do.
Jfrankon is offline
Old 12-27-2005, 09:47 AM   #11
hatake
Member#: 34811
04 Baja T
Thanks, Peaty, for the post. I did this over the weekend, and my driver-side filter was dropped. PAssenger-side was still in the bolt - I pulled it out. Can you tell which way the oil flows on the driver-side? My guess is from the pipe to the engine block, thus meaning the oil passage was partially blocked all these time. Is that right? The rough idle I have had experienced for the last one year seems to be gone. I'll drive around the town to see if I feel a substantial change. Thanks again, Peaty!
hatake is offline
Old 12-27-2005, 09:50 AM   #12
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
AFAIK the oil flows from the lower part in the head into the variable valve system. You are the first person to say that they had one still in the bolt. So far over a dozen people have told me the filters have both dropped out.
Peaty is offline
Old 12-28-2005, 01:45 PM   #13
AaronB
Worst Mod Ever
Member#: 369
19 CTS-V, 18 XC90
17 GTI
Just did mine as well. 20-30 minutes. New washers. Both filters had fallen out of the bolts.
Thanks for the reminder Peaty, I didn't have a rough idle, but the peace of mind of having them out is worth the $2 and 30 minute investment.
AaronB is offline
Old 12-29-2005, 09:52 AM   #14
Keggler
Member#: 70912
2004 Forester XT
TAGXT04
I did this just now in about 20 minutes. I re-used the washers and re-torqued to 22ft/lbs on a cold motor. Hardest part was getting "tweezers" to pull the filters out. I won't know if it leaks until later.
I haven't had the rough idle in a while and found both filters in the banjo fitting. I'm guessing we all had rough idles until the filters fell out of the bolt and into the fitting.
Keggler is offline
Old 12-29-2005, 11:32 AM   #15
WRacerX
Member#: 4365
2004 Forester XT
Just did this on my car. Took about 20 mins. Both filters had fallen out of their bolts. The passenger side filter was cracked (the metal screen part) and seemed like it was on it's way to disintegration! Man, I'm glad I did this.
When I was working on the passenger side, I also found that the dealership monkies hadn't properly reinstalled the air filter cover. The two tabs at the bottom of the cover towards the engine were not in their slots. Idiots...
Thanks for the invaluable info Peaty !
Scott
PS: I re-used the washers with a couple more ft-lbs of torque. No leaks.
WRacerX is offline
Old 12-29-2005, 11:44 AM   #16
pleiad7
Member#: 71056
MY04 Forester XT
Still have to do this as well; so far the weather hasn't cooperated and I don't have a garage. More rain ahead this weekend...
pleiad7 is offline
Old 12-31-2005, 05:19 PM   #17
ForesterXT04
Member#: 42249
Same here, both filters fell in both banjos. Took about 5 min to get to the bolts and another 10 min to fish out the filters with tweezers. Re-torqued original bolts and washers to 23 ft pds and let the car idle for about 5 min...no leaks so far.
Thanks Peaty!
ForesterXT04 is offline
Old 12-30-2005, 06:16 PM   #18
sleepy22
Member#: 87711
'05 Forester XT
as always, thanks a million/zillion/trillion, Peaty!
sleepy22 is offline
Old 01-04-2006, 09:54 AM   #19
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
New year bump...I can't say enough how this made a huge difference in the FXT.
Jfrankon is offline
Old 01-04-2006, 12:04 PM   #20
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
Made it a sticky
Peaty is offline
Old 01-07-2006, 03:24 PM   #21
immortal_suby
Member#: 1711
140 rogue points!
2013 GBS BRZ Limited 6MT
Just did mine and sure enough, both filters were down in the banjo bolt hole. Thanks for the thread, Peaty. She is idling much smoother now.
immortal_suby is offline
Old 01-07-2006, 05:34 PM   #22
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
Just did mine...yup, both had fallen out. Real easy took about 20 min.
IMPORTANT TOOL: 3 prong grabber that comes in those computer toolkits for picking up fallen screws in hard to reach areas.
This tool makes it take only 1 second to grab the fallen filter and get it out w/o worrying about it falling.
Peaty the tool is found in this Basic Computer maintenance tool kit (the yellow one 3rd from the left):
http://www.microcenter.com/single_pr...uct_id=0205824
Not sure the name of the tool...think it is the "parts retrieval claw".
SirWilliam is offline
Old 01-07-2006, 10:50 PM   #23
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
I have a pair of hemostats I used from my Tox. days I also have one of thos small 3 pronged grabbers too in my PC kit.
Peaty is offline
Old 01-10-2006, 11:34 AM   #24
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
capecod_wrx:
How far in were you able to insert the allen wrench into the bolt? IIRC, the filter should inhibit you from pobing too deep.. so if you stick the wrench in the bolt, you should be able to hit the top of the filter pretty quickly. The hard part is finding the edges of the filter and bolt (where the side of the bolt ends and the side of the filter begins). This is where you need to insert your wrench and pull up the filter. Perhaps 2mm is too big to seperate the filter from the wall of the bolt??
Jfrankon is offline
Old 02-05-2006, 09:56 AM   #25
capecod_wrx
Member#: 43277
'08 VDub R32
capecod_wrx:
I tried again this morning...and tried the driver's side first. This time there was very little oil visible. Again - I could see all the way down into the inside where the bolt goes. I used my allen key for starters to see if I could 'feel' the top of the filter. I felt nothing - and was able to put the key all the way down inside.
I put my finger on top of the banjo against the allen key to measure how far down the key went.
Originally Posted by SirWilliam
That is b/c the filters had dropped down inside...all you will see is a flat, round black top of the filter...
I was expecting to hit the top of the filter. Is it possible that my FXT never got these filters?
capecod_wrx is offline
Closed Thread
04 XT owners FYI Peaty Forester Forum 0 11-19-2005 05:38 PM
Any NJ XT owners Ibizan Forester Forum 0 06-07-2003 12:05 PM
It's official, I'm an XT owner! Ibizan Forester Forum 33 06-03-2003 11:03 PM
('93-'01) Calling all XT owners Kevin Thomas Impreza Forum 3 05-21-2001 06:41 AM
Any XT owners out there? I have a [Q] Peaty General Forum Archive 0 10-22-2000 06:39 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
