Welcome to the North American Subaru Impreza Owners Club Thursday September 29, 2022
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Closed Thread
Old 01-04-2006, 12:04 PM   #26
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
Made it a sticky
Peaty is offline
Old 01-07-2006, 03:24 PM   #27
immortal_suby
Member#: 1711
140 rogue points!
2013 GBS BRZ Limited 6MT
Just did mine and sure enough, both filters were down in the banjo bolt hole. Thanks for the thread, Peaty. She is idling much smoother now.
immortal_suby is offline
Old 01-07-2006, 05:34 PM   #28
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
Just did mine...yup, both had fallen out. Real easy took about 20 min.
IMPORTANT TOOL: 3 prong grabber that comes in those computer toolkits for picking up fallen screws in hard to reach areas.
This tool makes it take only 1 second to grab the fallen filter and get it out w/o worrying about it falling.
Peaty the tool is found in this Basic Computer maintenance tool kit (the yellow one 3rd from the left):
http://www.microcenter.com/single_pr...uct_id=0205824
Not sure the name of the tool...think it is the "parts retrieval claw".
SirWilliam is offline
Old 01-07-2006, 10:50 PM   #29
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
I have a pair of hemostats I used from my Tox. days I also have one of thos small 3 pronged grabbers too in my PC kit.
Peaty is offline
Old 01-08-2006, 10:02 AM   #30
capecod_wrx
Member#: 43277
'08 VDub R32
Originally Posted by Jfrankon
That's true, Peaty. Taking you initial advise, I poked around with the needle nose pliers until I "felt" them and then grasped and pulled. With my naked eyes (don't have great vision) I could NOT see them at all in the banjo (but sure enough they were both in there!)
Moral of this story: Search and you shall find
I went filter fishing this morning - but I didn't catch anything.
I started with the passenger side. Once the bolt was out - I took a look. Very little oil was inside of the banjo - and I could see all the way down into the bolt. I didn't see any filter. I used a small 2mm allen wrench to fish around - but didn't feel or see anything.
The drivers side had a pool of oil inside the bolt. I fished around with my allen wrench - but also did not feel or find anything.
capecod_wrx is offline
Old 01-10-2006, 11:34 AM   #31
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
capecod_wrx:
How far in were you able to insert the allen wrench into the bolt? IIRC, the filter should inhibit you from pobing too deep.. so if you stick the wrench in the bolt, you should be able to hit the top of the filter pretty quickly. The hard part is finding the edges of the filter and bolt (where the side of the bolt ends and the side of the filter begins). This is where you need to insert your wrench and pull up the filter. Perhaps 2mm is too big to seperate the filter from the wall of the bolt??
Jfrankon is offline
Old 01-10-2006, 12:36 PM   #32
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
That is b/c the filters had dropped down inside...all you will see is a flat, round black top of the filter...this is where I used the 3 prong "Parts retrieval claw" from my egghead computer tool kit. I am sure your filters are still in there which is impeding the oil flow.
Old 01-10-2006, 12:53 PM   #33
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
It's very likely the filter is not in the union bolt but in the banjo bolt spot down on the motor, it's tricky to see:
It gets forced out:
Peaty is offline
Old 01-10-2006, 01:39 PM   #34
capecod_wrx
Member#: 43277
'08 VDub R32
thanks for the replies guys... i will take another look this weekend and will post an update - with some pictures if they come out.
i could see well inside the banjo on the passenger side. (there was very little oil in there...) jfrankton - my allen key could go all the way down inside of the banjo and bottom out. i didn't see any black plastic.
now on the other side - there was more oil. it was all pooled up - so i really couldn't see anything. i tried fishing with the allen key - but really didn't poke around that much because i was afraid i could damage the filter screen and then not be able to remove it.
by the looks of peaty's pictures - i take it you use the needle nose, (or 3-prong) , to grab the top of the filter - which is made of plastic. is the diameter of the filter just slightly smaller than the banjo?
thanks again guys.
Old 01-10-2006, 01:48 PM   #35
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
thanks again guys.
I would suggest using the 3 prong b/c the pliers has the ability to scrape some of the plastic/metal off as you try to grab it...and the 3 prong just works better/easier.
Just my 2 cents.
Old 01-10-2006, 05:09 PM   #36
SuperRuWRX
Member#: 4955
2004 FXT
OffRoadSubarus.com
I had good luck using this pair of thin needle nose pliers and a small flashlight.
BTW, Thanks Peaty.
Both of my filters had dropped and idling has now improved.
SuperRuWRX is offline
Old 01-23-2006, 06:21 AM   #37
zhe wiz
Member#: 7943
2011 Silver OBS
92 Eclipse 11.8 @ 119
Default One Dropped, One Didn't
I changed the oil in my 32,000 mile '04 XT yesterday and decided to yank the filters while I had the hood open. The passenger side filter actually had NOT dropped out, until I pried it out that is. It was in there pretty good and wasn't easy to extract.
The driver's side had fallen out and was much easier to remove. Both filters were in excellent condition, fortunately.
Jack Z
zhe wiz is offline
Old 01-26-2006, 11:47 AM   #38
s. tyrone
Member#: 57752
2013 Legacy Limited
Ice Silver
BTW, Thanks Peaty.
Hey Richard, any chance we could talk about this, I'm a little fuzzy from the post. Please PM me if you would. Best, Stephen
s. tyrone is offline
Old 01-30-2006, 12:38 PM   #39
ez bturbo
Member#: 56048
2004 baja turbo 5spd
black/dark gray
I dont have rough idle (although I may not be able to judge that well since I also drive a pair of modified camaros that both idle really rough), but I do have severe hesitation and, well see this post:
http://forums.nasioc.com/forums/show...5&goto=newpost
I will do this, but would that actually be a likely cause of my problem?
ez bturbo is offline
Old 02-03-2006, 02:52 AM   #40
rim3
Member#: 62494
2004 Forester XT
That sounds a bit like what I'm experiencing with my FXT. It's been really.... slow... lately. I don't have a boost gauge, but it seems to be lacking boost. The rough idle is a random, yet frequent, occurance. I noticed it, but dismissed it, because it didn't feel or sound bad. My engine started to suffer at about 25k and now seems to really be suffering at 33k. I'll be pulling those things out this weekend!!! We'll see what it does.
rim3 is offline
Old 02-03-2006, 09:12 AM   #41
Corkfish
Member#: 39503
If you haven't already done it, changing your spark plugs might help as well.
Corkfish is offline
Old 02-03-2006, 09:26 AM   #42
ez bturbo
Member#: 56048
black/dark gray
sparkplugs were changed 3k miles ago, didnt fix the problem.
Old 02-03-2006, 02:57 PM   #43
dads_cruizzzer
Member#: 61724
04 FXT
I did mine during the Christmas break - both have dropped.
What other model cars/year have these filters? I know a few suby owners who don't surf the forums and I would like to inform them if it applies to their motor.
dads_cruizzzer is offline
Old 02-03-2006, 03:45 PM   #44
pleiad7
Member#: 71056
MY04 Forester XT
All MY04 2.5L turbo engines (STi, FXT, Baja).
pleiad7 is offline
Old 02-03-2006, 04:06 PM   #45
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
and some 05's
Peaty is offline
Old 02-05-2006, 09:56 AM   #46
capecod_wrx
Member#: 43277
'08 VDub R32
capecod_wrx:
I tried again this morning...and tried the driver's side first. This time there was very little oil visible. Again - I could see all the way down into the inside where the bolt goes. I used my allen key for starters to see if I could 'feel' the top of the filter. I felt nothing - and was able to put the key all the way down inside.
I put my finger on top of the banjo against the allen key to measure how far down the key went.
I was expecting to hit the top of the filter. Is it possible that my FXT never got these filters?
Old 02-05-2006, 10:36 AM   #47
dads_cruizzzer
Member#: 61724
04 FXT
Excuse this stupid question - Did you check the banjo bolt? Yours might not have dropped yet.
Old 02-05-2006, 10:41 AM   #48
capecod_wrx
Member#: 43277
'08 VDub R32
That was the first thing I checked - on both sides... No filters were there either.
Old 02-05-2006, 11:35 AM   #49
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
If you went in that far I don't think you had them, mine were right up by the top of the hole. Since your car is running well I don't think they are in the system anywhere.
Peaty is offline
Old 02-05-2006, 11:54 AM   #50
Hondaslayer
Member#: 4562
2014 Electric Datsun
2005 Adventure van
Mine was done about 2 weeks ago and the idle still has the Suby shake but it is not as viloent.
And at 33k just let the dealer do it. You are still under warranty.
Hondaslayer is offline
Closed Thread
04 XT owners FYI Peaty Forester Forum 0 11-19-2005 05:38 PM
Any NJ XT owners Ibizan Forester Forum 0 06-07-2003 12:05 PM
It's official, I'm an XT owner! Ibizan Forester Forum 33 06-03-2003 11:03 PM
('93-'01) Calling all XT owners Kevin Thomas Impreza Forum 3 05-21-2001 06:41 AM
Any XT owners out there? I have a [Q] Peaty General Forum Archive 0 10-22-2000 06:39 PM
