Welcome to the North American Subaru Impreza Owners Club Wednesday May 29, 2024
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 03-23-2004, 11:09 PM   #1
Aegon
Member#: 42435
Default Anyone know much about electronics?
First of all, I'm a computer guy. I'm not an electrical engineer and I don't know what I'm talking about with electronics.
I'm considering working on a little project to monitor the duty cycle of an injector, the ambient temperature, and the temperature of charged air at the throttlebody. I have been considering my options and I think this project would need more than a few comparators, op amps, and a 555. I think this project needs a PIC. For a $20 entry fee we can compile C code to do order-n lagrange polynomial integration on analog signals from the devices mentioned above.
The problem is that I have little experience with PICs. I can program pretty well and have a ton of experience with assembly, and I'm pretty good at math. In addition, I have a ton of ideas on how to make this thing work out well. If anyone out there has some experience with PICs maybe we can start work on a little project.
I've already briefly discussed this with MouserWRX and gjhsu. I don't think we need to log data anymore because I've already found a bunch of answers to my original questions.
If you are still reading this, the project goal should already be clear: Determine when to spray water on an intercooler.
Aegon is offline   Reply With Quote
Old 03-23-2004, 11:13 PM   #2
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
I learn nothing in school.
gjhsu is offline   Reply With Quote
Old 03-23-2004, 11:23 PM   #3
mouserWRX
Member#: 48960
2006 TL
Anthracite
Sounds like fun, and water on the IC can't hurt even if you screw it up hehehe
mouserWRX is offline   Reply With Quote
Old 03-24-2004, 12:18 AM   #4
Aegon
Member#: 42435
I'm more excited than ever! Yet nobody else seems to be.
I can't tell if George is serious or not. I bet they have all sorts of PIC stuff setup in the UT labs.
Old 03-24-2004, 12:21 AM   #5
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
No, I'm serious. They don't teach us anything practical (yet, if at all). I'm not very happy at the moment with the way things are being conducted in some classes, and am aiming to get a person fired.
Not in a good mood right now.
Old 03-24-2004, 01:15 AM   #6
LiquidIQ
Member#: 6408
2013 Porsche Carrera
I can have a friend of mine take a look at this thread at work, he's working on a wrist-based sky diving computer
LiquidIQ is offline   Reply With Quote
Old 03-24-2004, 01:20 AM   #7
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
ATX25RS is offline   Reply With Quote
Old 03-24-2004, 01:41 AM   #8
HonduHunter
Member#: 28408
2002 vf48ed WRX
i feel the same way
HonduHunter is offline   Reply With Quote
Old 03-24-2004, 08:21 AM   #9
D_REX
Member#: 8945
MY02 WRX
I'm not exactly a PIC expert but I am an EE and I have done several projects, both hardware and software, with the PIC. I can tell you that trying to do complex math with the PIC is a waste of time, but I don't really see the need for it with this project. Some basic averaging (over power of 2 samples) should be more than adequate.
As far as the other electronics you listed, none should be needed. You should use the ADC in the PIC to accquire your sigals and make all decisions in software, you shouldn't need comparators. The 555 timer shouldn't be needed either. You will need some basic microprocessor support devices, input protection, and an output driver for your sprayer.
BTW, I have a friend who is working on a more complex version of the same thing, similar to the SECS system, with sprayer control, there's a thread about it in the forrester forum.
Later,
Dustin
D_REX is offline   Reply With Quote
Old 03-24-2004, 08:50 AM   #10
Aegon
Member#: 42435
Here is what I'm thinking:
We need to monitor 2 main factors
(1) Aggressive Driving
(2) Temperature Differences
To determine if we are driving aggressively, we need to keep a log of the duty cycle at the last X timeslices. Each timeslice can represent 2 seconds or so. Depending on the capabilities of the PIC, I think 64 data points is a good place to start. Between these points we can keep running tabs on the duty cycle of an injector, but we don't need to save all of this data, just summarize it when the slice is up. Since duty cycle is exponentially proportional to a chosen rev range, it should be pretty easy to determine when we've exceeded our threshhold for aggressive driving. It should be even easier with the WRX since a lot of the time when you want to drive aggressively you floor the pedal, which would make the duty cycle go way up proportionally to acceleration. For the same reason that we run rich a lot of the time we can easily tell when things are getting aggressive.
Once we've convinced the computer that we are driving aggressivly we need to compare the difference between ambient temps and the temp at the throttlebody. If the difference is 10-20 degrees or higher then the temp sensors can approve a spray.
So now we begin a cycle of spraying that should happen in very short order. First, we spray a baseline amount of time, possibly 1 second. At this point we begin rapid checks of the temp delta between ambient air and the air at the TB. In cool weather we should have sprayed plenty of water and the temps will already be dropping. In warm weather we will see that second order derivative of dTemp/dt is lower than expected and we will need another squirt. So long as the sequenced squirts are having a positive effect on the 2nd order temp results (we will need to determine a threshold), keep spraying short bursts.
When this is done we need to start a timer to prevent any spraying over the next X seconds. This would adjust based on ambient temp and the aggressive driving score.
I think we could do this pretty easily with a single pot for sensitivity and an on/off switch. The whole idea is to be frugal with the spray but still get the most out of the sprayer system.
Old 03-24-2004, 08:58 AM   #11
Aegon
Member#: 42435
The best part about the math is that it isn't that complex. The derivation of a quadrature is pretty complex (not really complex, but not something people other than Gauss or Newton would think of), but I know enough to make it reality even if I had to use assembly or machine code.
I listed those electronics because I claimed I could make a circuit with only a couple op amps and a 555. This thread was created to say that I want more than just those when I can use something like a PIC. I have no intention of using a comparitor when I have AD converters C code.
Later,
Dustin
I'll check that thread out. Thanks for the input.
Old 03-24-2004, 08:59 AM   #12
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
stay away from the 555 if you are using them as timers....they suck.
Wheeler Bement is offline   Reply With Quote
Old 03-24-2004, 09:11 AM   #13
Aegon
Member#: 42435
Oh boy. I have no intention of using a 555. When I say that this project needs more than 555s, I mean that I want to use something else.
And for my needs, I think a 555 would have been adequate for a simple project. Precision timing isn't very important in this application.
Old 03-24-2004, 09:14 AM   #14
D_REX
Member#: 8945
MY02 WRX
You need to be proactive with the sprayer to be effective. If you wait until the temperature rise happens then you are really wasting your time with the other inputs. You want to predict the temperature rise and spray before it happens. One simple way to do this is with boost. You know if you are making boost beyond a certain point you are driving aggressively and temperatures are going to rise. You also want to prevent heat soak from idling, so monitoring intake temps and post ic temps would be helpful for that.
Old 03-24-2004, 09:16 AM   #15
D_REX
Member#: 8945
MY02 WRX
The 555 is pretty much just as accurate as your RC time constant. unfortunately capacitors have pretty bad precision, unless you buy something specifically targeted for precision applications. Most caps are +/-20%.
Old 03-24-2004, 09:18 AM   #16
Aegon
Member#: 42435
I am not using temperature rise to trigger spray. I am using aggressive driving to trigger spray.
The temperature test will only veto a move to spray when there is no need for it.
Old 03-24-2004, 09:23 AM   #17
D_REX
Member#: 8945
MY02 WRX
Multiplication and division are complex math in the PIC. Just as an example a 32 bit divide can take more than 1000 cycles and a 32 bit multiply nearly 900. 16 bit operations aren't as bad but still ~250 cycles. You can see where it doesn't take much of an algorithm before you eat up a lot of time.
Old 03-24-2004, 09:23 AM   #18
Aegon
Member#: 42435
Also, monitoring boost is not a good idea for this situation. By the time we are boosting we are too late. Think of how often and for how long you actually drive in boost.
This part of the discussion has been beat to death in other articles. My first reaction was to look at boost too, but I'm convinced that the injector duty cycle is the key.
Old 03-24-2004, 09:25 AM   #19
D_REX
Member#: 8945
MY02 WRX
So you're saying that if there is no temperature rise but there is aggressive driving, you won't spray?
Old 03-24-2004, 09:26 AM   #20
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
i have built and rebuilt many 555 timers....just to have them quit working after a couple of cycles....but maybe i was doing it wrong...just a thought though.
Old 03-24-2004, 09:28 AM   #21
Aegon
Member#: 42435
Cool, thanks for the info. Like I said, I don't know much about PICs. The last time I did processor design was on a CISC chip for IBM (Z900), which could do damn near anything in one cycle. Come to think of it, I remember looking at the VHDL for the multiply instruction and I was completely baffled by its operation, which is to say that I shouldn't expect a PIC to do it very well.
Old 03-24-2004, 09:29 AM   #22
D_REX
Member#: 8945
MY02 WRX
I'm not convinced of this at all. Boost is what creates the heat. Heat is a product of the inneficient compression. The intercooler will have some thermal mass and won't gain temperature for some delta-t after the onset of boost. In addition water spray is only really effective if it evaporates from the intercooler.
Really how far apart can the exponential increase in injector duty cycle and the onset of boost be?
Old 03-24-2004, 09:31 AM   #23
D_REX
Member#: 8945
MY02 WRX
It's really a mute point, a timer is not needed if you have a microcontroller.
Old 03-24-2004, 09:31 AM   #24
Aegon
Member#: 42435
No, I'm saying that if you drive aggresively in the middle of winter and the I/C is doing one heck of a job getting charged air close to ambient temperature, I won't spray.
I'm not looking at temperature rise over time, I'm looking at temperature difference between ambient air and air at the TB.
Old 03-24-2004, 09:33 AM   #25
Aegon
Member#: 42435
Check this out:
http://www.autospeed.com/cms/article.html?&A=0527
Then check this out:
http://forums.nasioc.com/forums/show...hreadid=173605
Does anyone know much about RX7 Cata Vancouver Impreza Club Forum -- VIC 20 05-29-2006 01:31 AM
Does anyone know much about www.jdmenginescorp.com? eddie1982 Vendor Reviews 2 05-17-2006 04:22 AM
Anyone know much about the new coupe? LinusRebar News & Rumors 36 07-20-2004 06:53 PM
Anyone know much about Bowie, MD? MidnightScooby Mid Atlantic Impreza Club -- MAIC 7 06-13-2002 07:07 AM
Anyone know much about the jdm AVCS? iceweazel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-02-2001 02:02 PM
