01-06-2016, 12:55 PM | #1726 |
Member#: 407850
W. Canada
Vehicle:2014 Impreza 2.0i Quartz Blue Pearl |
Would there be any issue having a 7" wheel and 205mm (8") tire? I know the width of the tire is sidewall to sidewall and not necessarily the bead to bead measurement.
01-06-2016, 01:31 PM | #1727 |
Member#: 413825
Vehicle:2015 base Impreza Jasmine Green Metallic |
01-06-2016, 04:07 PM | #1728 |
Member#: 407850
W. Canada
Thanks NubImpreza, looks like there isn't too much difference aside from a minor increase in overall diameter and 7mm more offset from the rotor/suspension. I'm going to put an offer on these and see what the seller comes back with. Man I love forums!
01-06-2016, 04:43 PM | #1729 |
Member#: 431290
NWIC
Vehicle:2013 impreza silver |
01-11-2016, 01:28 PM | #1730 |
Member#: 407850
W. Canada
So I picked up my "New to me" 1999 Subaru Forester Rims and Winter tires on Friday.
They wheels had some old and nasty looking plasti dip on them so I decided to clean them up to a) make them look better and b) inspect for any cracks etc. They are in pretty good shape although the finish has certainly seen better days. Does anyone know how to get these looking new again, or even suggestions for removing some of the corrosion. I don't want to incur a large cost to clean these up and will most likely just paint them but would like to at lease attempt to get rid of the corrosion before painting. Any links to a DIY or instructional thread would be fantastic! |
01-11-2016, 02:30 PM | #1731 | |
Member#: 340297
Vehicle:2013 Impreza 5sp Prm Ice Silver |
01-11-2016, 02:40 PM | #1732 |
Member#: 407850
W. Canada
I have heard that and was skeptical, that would be for the corrosion spots correct? Would using paint stripper help, I have seen videos of people using it and it dissolves the clear coat and bares the metal. Obviously a clear coat would have to go back on after. I would assume with the coke and foil it would still need to be resealed after?
01-11-2016, 03:19 PM | #1733 | |
Member#: 340297
01-11-2016, 03:49 PM | #1734 |
Member#: 380445
Just picked up some 13 WRXs and was wondering what tire size others were running on these wheels. I know stock they came with 235/45. Am looking for size with a bit of comfort since this is a DD. Plus I'm lowered on Eibachs (soon to be Tein coilovers).
01-11-2016, 04:13 PM | #1735 | |
Member#: 431290
NWIC
Why not just wet sand? If you are planning on painting them anyway |
01-26-2016, 04:40 PM | #1736 |
Member#: 431290
NWIC
ImageUploadedByNASIOC1453844367.689588.jpg am i the only one with non dot approved wheels? I went out and tried to get them mounted and got scolded everywhere i went for them not being dot approved...is it really that unsafe as long as i stay on the pavement?
01-27-2016, 09:37 AM | #1737 |
Member#: 407850
W. Canada
What wheels are you running? Also when I had my winters mounted I found a guy on Kijiji to mount and balance them for $60.00. He had a shop with the right equipment but certainly wasn't a tidy establishment. Anyway if you find a guy in your area like this he certainly won't scold your non-DOT-ness.
01-27-2016, 12:07 PM | #1738 | |
Member#: 431290
NWIC
They are xxr 530s..i got them mounted but it cost me $125...just hoping they arent as unsafe as they say |
01-31-2016, 08:47 AM | #1739 |
Member#: 413825
2012-2013 Impreza Rims & Wheels Gallery Thread
Finally got my 2nd summer set. I was liking the black for an alternate look of the gold: 17x9 et35 to be wrapped with 235/40-17 rubber.
ImageUploadedByNASIOC1454263829.646476.jpg Last edited by NubImpreza; 01-31-2016 at 01:10 PM. |
02-01-2016, 01:15 PM | #1740 | |
Member#: 407850
W. Canada
02-01-2016, 05:15 PM | #1741 |
Member#: 408757
02-02-2016, 03:51 PM | #1742 |
Member#: 380445
WRXs on my base model 5door; lowered on Eibachs currently but will be swapped out for Tein coilovers in a couple weeks. Bought SPC rear LCAs but was wondering if anyone was using front camber bolts?
02-02-2016, 04:17 PM | #1743 | |
Member#: 431290
NWIC
What are these i love them! They will look great on your car |
02-02-2016, 04:37 PM | #1744 |
Member#: 438759
Vehicle:2013 Impreza WRX Charcoal Grey |
I am new, those are 17 profile and 8 wide is that correct? I take it there are no rub issues? Can you turn the front's the full range of motion without contacting anything? Don't the WRX and STI have stock fender flares for clearance or are the wheels spaced out further by spacer or otherwise mounting wheels out further than stock impreza.
02-02-2016, 06:37 PM | #1745 |
Member#: 431290
NWIC
02-02-2016, 08:35 PM | #1746 | |
Member#: 380445
That's correct, the wheels are 17x8 +53 with 235/45 tires. No rubbing or contact issues at all. Not using spacers either. I may have to roll my rear fenders when I install the coilovers but I'm only looking for another 1" drop at most so I'll play it by ear. Bought the rear LCAs to correct my camber. |
02-02-2016, 08:41 PM | #1747 |
Member#: 380445
rear side view
front side view Great set up for daily. I just want a little more lower. Hopefully it won't cause me any issues. |
02-03-2016, 09:53 AM | #1748 |
Member#: 407850
W. Canada
Nice Prezy & Kottosen! Those WRX wheels look nice on the impreza.
02-03-2016, 07:53 PM | #1749 |
Member#: 432234
Vehicle:2015 Impreza 2.0i Dark Gray Metallic |
02-03-2016, 07:55 PM | #1750 |
Member#: 431290
NWIC
What kind of mudflaps are those? They look like they sit very low down
