Welcome to the North American Subaru Impreza Owners Club Sunday July 12, 2020
Old 12-05-2019, 12:07 PM   #126
Not-EWRX
Member#: 158043
2013 Wrx Hatch
I had a 2013 with a leak @~ 70k. I pulled the rack and replaced the seals. I'm not sure what I did wrong but the steering assist is jacked up now. It wonders off center and have varying amounts of assist as the wheel is turned. I'm back to looking at replacing the whole rack.
Not-EWRX is offline   Reply With Quote
Old 12-31-2019, 02:25 PM   #127
shoots808
Member#: 370541
2008 Subaru WRX
did you make sure you tied the steering wheel down with whatever you had ie seatbelts, tension straps etc before tearing down the rack?
shoots808 is offline   Reply With Quote
Old 04-08-2020, 04:01 PM   #128
maxplanck
Member#: 255498
2011 wrx with 115K on it... leaking at the pinion valve. I'm playing "make a wish" with Lucas stop leak now... not particularly hopeful of success.
maxplanck is offline   Reply With Quote
Old 06-25-2020, 10:59 AM   #129
Stealthbmbr
Member#: 13823
The wifes RnP is going up on her 09 WRX with 80k miles. Turning lock to lock, it binds up and starts to bounce. Not sure if I should replace the rack or get new lines and pump as well.
Stealthbmbr is offline   Reply With Quote
2002 wrx power steering leak HELP vettedriver986 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-12-2010 10:53 PM
Power Steering Leak, where at those loose fittings? 275Performance Service & Maintenance 0 05-03-2003 11:46 PM
Power Steering Leaking!! waezsn Service & Maintenance 2 02-09-2003 06:12 AM
power steering leak thng Service & Maintenance 2 10-19-2002 04:04 PM
