05-30-2018, 03:54 PM | #101 |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
I swore I would not buy another Subie if it wasn't a wagon, but the STi roof rack/cargo box combo looks awfully tempting...
05-31-2018, 03:37 PM | #102 | |
Member#: 486595
06-03-2018, 01:10 PM | #103 |
Member#: 486732
will the old 2011-2014 subaru wrx sti roof racks fit on the new 2018 subaru wrx st?
07-11-2018, 07:46 PM | #104 |
Member#: 488218
Measurement between bars?
08-07-2018, 06:01 PM | #105 |
Member#: 488297
so after going from bike shop to rack shop around my area for about half a day I found out Subaru has an hem kit that includes everything for 360 bucks. so went with it and couldn't be happier! Please excuse my dirt car, northern CA is kinda of on fire and its raining ash lol........
[IMG][/IMG] [IMG][/IMG] Last edited by mrconnery; 08-07-2018 at 06:10 PM. |
08-07-2018, 08:02 PM | #106 |
Member#: 466892
SCIC
Vehicle:2018 STi WRB |
@mrconnery
Niceee!!! Fellow WRB STi brother with roof rack What attachments do you plan to put on there? @summitbound Sorry, I haven't been following this thread/forum for a while. I'll measure when I get home. The mounting brackets on the 2018+ have a few holes you can choose from, so you can make it more narrow or more wide, as well as shift forward or back (depending on the hole choice). |
08-08-2018, 10:13 PM | #107 | |
Member#: 395192
Vehicle:2014 WRX Limited 5dr WRB |
And the part of the channel it contacts will get a small dimple in it, on mine it's aft the front foot and fore of the rear foot |
08-08-2018, 11:00 PM | #108 |
Member#: 466892
SCIC
Thanks for the info, but I'm not worried about the paint. The edge of the rubber that touches the paint part doesn't really press against it. It mostly sits on top, lightly, if barely touching. It looks more like a design flow, than an actual part putting pressure on the paint, if that makes sense. I've taken the racks off recently to wash and wax the roof easier, and there was no signs of damage. There may be damaged after years of the rubber shoe mounted on the channel, I get that. Worse case scenario I'll replace that piece, no big deal. What rack did you have?
To answer the measurement question, the center of my bars on the roof are 26.5 inches appart. I forget what holes I used, but I do remember using the more narrow setup so my aerobar channel mounts were more level, so you could add an inch or 2 depending on the mounting position. The bike racks work great and the bars don't seem too narrow for them. Getting good use out of this every weekend, no regrets! |
08-09-2018, 01:45 AM | #109 |
Member#: 489003
that looks great
was thinking about doing that to my car, makes it look 100% times better!
08-09-2018, 08:19 AM | #110 | |
Member#: 228010
NESIC
Vehicle:2019 WRX Limited Crystal White Pearl |
08-09-2018, 04:06 PM | #111 | |
Member#: 228010
NESIC
**bought some 16mm M6 stainless steel bolts from home depot.. problem solved. Last edited by MtnXfreeride; 08-11-2018 at 08:25 AM. |
10-25-2018, 04:45 PM | #112 |
Member#: 491632
Vehicle:2018 WRX |
Any reason why Thule wants over $500 for this, but subaru OEM is only $280? I don't mind paying extra if there are additional form, fit, or function, but comparing pictures, these are exactly the same. What am I missing here? (OEM part is SOA567X050)
https://www.thule.com/en-us/us/roof-...r-sedan-_-xVUs https://www.ebay.com/itm/2018-Subaru...1:pf:0&vxp=mtr |
10-25-2018, 05:24 PM | #113 |
Member#: 450321
Has anyone tried the OEM rack off the 2014 wrx models? Does it work?
10-26-2018, 04:58 AM | #114 | |
Member#: 403893
SCIC
Vehicle:2015 STi Limited WR Blue |
Nope. Same bars and roof limit is 88 lbs. Yakima says they tested theirs up to 165 lbs but Subaru of America said roof limit is only 88 lbs. Thule said their bars can handle more but they use Subaru’s number for the rating. |
04-02-2019, 08:16 PM | #115 |
Member#: 490271
Kinda late in this, but I just got a set of OEM Thule crossbars for my 2018 and getting ready to order a carrier. After doing some digging, I’m seeing that a Subaru posts a limit of 88lbs (including bars) on the roof of the WRX. Have you pushed past that weight with your setup? 88lbs doesn’t seem like much weight (especially when you consider these carriers at 40lbs+). Thanks!
02-18-2020, 01:35 PM | #116 |
Member#: 233053
Can anyone tell me what the thread pitch is for the studs going into the roof rails? Also is the studs included in the rack kits aluminum or some other material? I have a roof rack from an older WRX I want to test fit but didn't want to out the wrong hardware in there and screw something up.
03-01-2020, 10:04 PM | #117 | |
Member#: 403893
SCIC
I’d bet the thread pitch is the same as the old rack but the position on your older rack is probably fixed so not sure/doubt it’s the right width for where the mounting brackets go on the newer models. Not to mention the molding/shape of the footpad is going to be different. |
03-03-2020, 08:02 AM | #118 |
Member#: 511060
Vehicle:2015 Subaru WRX Rally Blue |
Sorry I’m new to this. Anybody have any guidance for fitting to a 2015 WRX?
03-03-2020, 10:13 AM | #119 | |
Member#: 403893
SCIC
15 WRX factory roof rack mount installed, yea I drilled it ! https://forums.nasioc.com/forums/sho....php?t=2643863 ^ if you’re willing to drill through your roof. If not, you need a clamp style rack for 2015-2017.5. |
03-03-2020, 03:09 PM | #120 | |
Member#: 511060
Thanks! |
