Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 08-11-2018, 02:37 AM   #1
TRVIING
Member#: 416175
Default Please help!! Car won't start!!
Please help me Subi gurus!!
My car is the 2007 AUDM Subaru Liberty 6 speed MT. The car originally ran well. I decided to put FMIC, replaced turbo, installed parallel fuel system with new DW fuel rails and injectors, did TGV delete, air pump delete, installed a processwest intake manifold, zeintronix flex fuel sensor and a PW surge tank. when all parts got installed in the car, car cranked up 5 times during the testing and stay idling all those time, just running rich and some CELs related to TGV and air pump. No fuel leak, around 3 bar fuel pressure.
I wanted to roll the car out of the garage, put car on reverse but it hesitated to move then shut down and won't start again. I used Romraider to disable all TGV and secondary air pump codes. no CEL code reported on scanner but car does not start. fuses are good. fuel lines have pressure. I can hear pumps primed up. I did search and checked ground cable is connected
I got tuning appointment in 2 weeks time but i wanted to move the car out of my garage. Please give me some troubleshooting clue. Would appreciate your help!!
TRVIING is offline   Reply With Quote
Old 08-11-2018, 12:20 PM   #2
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
Did you pull plugs? Were they wet?
Did you adjust your fueling at all? It's probably running pig rich and flooded the engine.
Old 08-11-2018, 09:56 PM   #3
TRVIING
Member#: 416175
Thanks for the hint mate. I didn't think of this issue. I will check it out. Does the fuel flooding damage the engine/spark plugs? How do i adjust the fuel with the romraider? or should i just wait for the tune so the tuner can sort it out properly
