Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Old 09-02-2018, 11:30 AM   #30776
Pelco
Member#: 435599
2016 Impreza Sport
Originally Posted by flyboy1100 View Post
I get enough vibrations and noise from my group n engine and transmission mount, i dont need more from a pitch stop. Dont get me wrong the amount of vibration isn't annoying or distracting at all, but i dont need more
Do you find the group n mounts help with power transferred? Do you have to pull the motor to install those bits?
I really like the pitch stop. Super easy install. Benefits are noticable.
Pelco is offline   Reply With Quote
Old 09-04-2018, 07:59 AM   #30777
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I did them when I swapped motors, so yes, but others have done them w/o
I feel like it has helped, especially with a clutch/flywheel setup that is 13.5-14lbs lighter than stock
Old 09-05-2018, 12:36 PM   #30778
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Default Longest tank of gas
I took the 2012 Impreza on my usual backpacking trip but this time decided to not worry too much about having the tank run near empty and i got my biggest range ever. this drive included some in town driving on both ends of the trip, some steep mountain driving (up to nearly 10k with grades at 25-28% over Highway 108), and 65-70 MPH driving on straight/flat highways, and then a little stop and and go for the last 20 miles home. AC was on for most of the driving.
the end tally:
Odometer: 461.4miles
Google Maps: 475 miles (right at the ~3% i expect it to the odometer to be off)
12.97 gallons
36.6 MPG
not bad at all, considering the steep mountain driving. the low fuel light came on at about 445miles (odometer), and when i filled up, the distance to empty was at 50 miles. [seems pretty spot on for the 14.5 gal tank]
so, close to 500mile range. as we all know though, driving this car at 75-80MPH would shorten that range appreciably.
nubsub is offline   Reply With Quote
Old 09-05-2018, 01:00 PM   #30779
Pelco
Member#: 435599
2016 Impreza Sport
the end tally:
12.97 gallons
36.6 MPG
This is grand! I am able to get pretty good mpg on longer trips. That is some impressive range!
Old 09-05-2018, 07:35 PM   #30780
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I think the people complaining about low mpg are doing mainly short trips in city or running the ac constantly and going 75ish which affects it.
I usually get like 32-35 average at 65mph and mainly cooler weather but since I have been doing more city driving it's gone down closer to 27.
DieselDorf is offline   Reply With Quote
Old 09-05-2018, 07:37 PM   #30781
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Also anyone ever have trouble with their climate control not going all the way to defrost? All the other modes work fine, I can get it all the way to where it should end on only defrost but it slides back up out of the notch.
I'm guessing the mechanical slides in the dash are catching maybe?
Old 09-06-2018, 04:06 PM   #30782
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I have issues on both ends, i can usually get it to stay but it doesn't lock in hard like the other positions, i have looked at it and there really isn't any adjustment due to it being a hard mechanical wire, if you lengthen or shorten it the problem gets worse
Old 09-06-2018, 05:23 PM   #30783
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Yea I'm not going to mess with it unless it doesn't work, actually I will probably then just use the leg/defrost.
The other side of mine is fine though, so far.
Old 09-06-2018, 09:28 PM   #30784
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Defrost is better at staying in position than the vent position on mine....
Most if the time i use the split settings anyway
Old 09-08-2018, 06:21 PM   #30785
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
ordered some Cerakote Glacier Green paint today to repaint my winter wheels. going to get some Nokian Hakkapallitta 9's after they are painted for winter. studded crappy firestone transforce tires were amazing last winter on my Excursion (this year will be Nokian Rotiiva AT Plus) so I am excited to try studded Nokians on my Impreza!!!
for reference, here is what my winter wheels looked like the last 4 winters, Michelin xIce3's and chameleon painted wheels.
and this is the new color
Old 09-08-2018, 07:47 PM   #30786
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I've heard hakas are an amazing tire. I've only ever run blizzaks and have been more than satisfied with them.
How did you like the X ices? They seem to be pretty similar tread patterns to my blizzaks.
Old 09-09-2018, 09:49 AM   #30787
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
They still have 6-7/32 left with 45k on them. I really liked them, would probably push through one more season but I had a screw in the sidewall this past spring. Patched and still holding air....
the xIce are normally a very highly rated tire, usually beat by a Hakka.....I don't have any other winter tire experience to compare them with but I was more than satisfied
Old 09-09-2018, 03:01 PM   #30788
Angelus911
Member#: 89967
2012 Impreza Sport
Checking my winter tires this weekend, I noticed a couple of tires have a small leak around the valve stem, where the stem comes out from the wheel, not where you put the air in at the top. Remains to be seen how bad the leak is - is there any way to fix this? From what I've read the only solution is to remount the tires and put a new valve stem in?
Old 09-10-2018, 08:09 AM   #30789
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
yup, remount and new stems. i like the schrader metal tpms stems, i plan to use them w/o sensors like i did on my excursion.
Old 09-10-2018, 03:53 PM   #30790
Angelus911
Member#: 89967
2012 Impreza Sport
Wonder if my wheels are corroded enough that it can't get a tight seal. These are 03/04 WRX Aluminum wheels and were in somewhat rough shape when i got them.
I filled all of them up with air to 35psi to see how fast they leak, may be ok with watching the PSI if it isn't too big a leak?
Old 09-10-2018, 08:33 PM   #30791
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
refilling daily or every other day is super annoying. could be a bead leak.
Old 09-11-2018, 09:04 AM   #30792
Angelus911
Member#: 89967
2012 Impreza Sport
Yeah the leak seems to be pretty bad, lost about 5 psi in a day. Sigh
Old 09-11-2018, 07:04 PM   #30793
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Fix it.
Old 09-19-2018, 05:51 PM   #30794
niiu82
Member#: 491672
Default Rear struts seepage
Hi, I have 52k miles on my 2012 Subaru impreza and was told by my mechanic that both my rear struts have seepage. He recommended I change them. I'm just wondering if this is normal? My car does feel a little more bumpy them before but I'm not sure if it's really needed. Any help will be appreciated. Thanks!
niiu82 is offline   Reply With Quote
Old 09-19-2018, 07:31 PM   #30795
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Unless you really drive over rough roads a lot or they are starting to rust out then they are probably fine.
Also if you frequently load up the back with weight/passengers that will probably help to wear them quicker.
If they are really bouncy you will notice and they will need replacing. Use your best judgement with ride quality I would say.
My 2012 has 91k and mine still seem to be working fine.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
