Welcome to the North American Subaru Impreza Owners Club Saturday November 17, 2018
Old 08-04-2003, 03:24 PM   #1
Dr. J
Member#: 31009
2002 impreza wrx
Default egr valve
how you you know if you need a new egr valve and how hard is it to repalce?
Dr. J is offline   Reply With Quote
Old 08-05-2003, 01:25 AM   #2
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Start with a cold engine.
Start car and let idle to normal temp
The operating shaft if visible thru the cutout in the egr housing. Watch the shaft while a helper sits in the car and raise the rpm to 3000 rpm and hold, (don't let it drop below 3000 rpm). If it's operating correctly you will see the shaft slide open.
If you end up removing it, best to use a new flange gasket, and the torque is 18 ft/ lbs.
Albert is offline   Reply With Quote
Old 08-05-2003, 10:32 AM   #3
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Also, make sure that you use some throttle body/air intake cleaner (not carb and choke) and clean out the passages that the EG runs through.
cavymeister is offline   Reply With Quote
Old 08-10-2003, 12:11 AM   #4
SubaruImpreza_power
Member#: 13910
2005 Legacy GT
blue
What is the egr valve used for?
SubaruImpreza_power is offline   Reply With Quote
Old 08-10-2003, 08:47 AM   #5
jlevy
Member#: 15696
2015 WRX 6 speed
Default emissions
I believe the exhaust gas recirc valve is used to control NOx levels.
-JL
jlevy is offline   Reply With Quote
Old 08-10-2003, 09:09 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Correct, to expand on that-
A small amount of exhaust gas is returned to the intake. This gas, being non-combustible, has the effect of lowering combustion temperatures which results in lower NOx emissions. There is another positive benefit, the lower temp also reduces the tendency for detonation so more aggressive timing can be used when EGR is present. Unfortunately there is a negative effect on throttle response as well as carbon buildup in the engine over time. As engine control technology has improved EGR regulation has gotten better but it is still something of a "necessary evil" on those engines that have it.
I'm very happy that the WRX does not have EGR.
Mulder is offline   Reply With Quote
Old 08-10-2003, 01:43 PM   #7
SubaruImpreza_power
Member#: 13910
2005 Legacy GT
blue
WTH... the Wrx does not have one? So does that mean I can take mines off?
I bet the stupid little part costs $$$ to replace
Old 08-10-2003, 08:04 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You can't just take it off. Well, you could physically remove it and block off the passages, but the ECU would know it is missing and you would have a constant CEL. The engine may also begin to knock without it because the engine management is designed for the EGR being in place.
Old 08-11-2003, 01:02 PM   #9
dsc
Member#: 15559
Do any of the Subaru engines have EGR?
dsc is offline   Reply With Quote
Old 08-11-2003, 02:21 PM   #10
SubaruImpreza_power
Member#: 13910
2005 Legacy GT
blue
My Forester 2.5L Has one and my 95 Impreza has one.
As mulder stated His 2.0L wrx turbo does not have a EGR.
Old 08-11-2003, 09:46 PM   #11
svx_commuter
Member#: 41373
1997 Impreza
My 1997 EJ22, 5spd does not have one.
svx_commuter is offline   Reply With Quote
Old 08-18-2003, 02:44 AM   #12
sick1.8t
Member#: 22345
2003 RSX
black
my '93 impreza with the EJ18 has it.
i cant seem to track where the feed for the exhaust gas comes from. does anbody know?
sick1.8t is offline   Reply With Quote
Wanted: Knock Sensor, EGR Solenoid, EGR Backpressure Sensor, Egr Valve Quix VIC Private Classifieds 2 07-09-2008 05:09 PM
EGR valve? ciper Legacy Forum 2 10-14-2002 08:49 PM
Does your Legacy have an EGR valve? The Real Oaf Legacy Forum 1 06-29-2002 01:53 PM
"Check Engine" and EGR valve TortoiseAWD SVX Forum Archive 3 07-20-2001 06:13 AM
EGR valve Blindeye_03 Normally Aspirated Powertrain 16 07-06-2001 06:32 PM
