Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Old 01-14-2018, 03:55 AM   #1301
amiexploited
Member#: 251061
2002 wrx sold
garage queen 2015 WRX
Originally Posted by amiexploited View Post
Thanks for the input fellas! The sun is out today so I'll start taking off panels.
Well.....it was my loose airbox. The 10mm bushing bolt on the top was loose. Wow.
amiexploited is offline   Reply With Quote
Old 01-28-2018, 04:24 PM   #1302
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Alright, I need some help. I cannot figure out WTF is making this goddamn squeaking noise.
In the video I'm sitting on a slight hill facing down, just letting off the brake while in neutral, going down a bit and then hitting the brakes to stop.
I've taken the center console up and held the wires and stuff underneath there, but the noise is still present. I've had a passenger in the front seat and back seat. Held the front seats so it can't move, moved the passenger seat all the way up and back and middle and the seat back the same... noise is still there. I think it's possible that it's coming from underneath the car somewhere near the center tunnel.
I did take the car into the dealer and they said that some passenger seat wiring/plugs were loose and they fixed those. Noise is still present - though that may have fixed some other rattling noises, idk - this is the big problem.
Any ideas?
Pantyraider is offline   Reply With Quote
Old 01-28-2018, 11:05 PM   #1303
Cab0oze
Member#: 443914
2015 WRX
That sounds crazy annoying. Unless someone else has already experienced this, better get down to the basics. To rule the underside of the car out, have someone do the same thing while you're outside with the car off.
Since it is so easily repeatable it should be easy enough to have a passenger stick their ear around/touch stuff until they find where it is coming from. Where do you think it's coming from?
Open your glove box, make sure it is nothing in there. Does it do it when you go over bumps? When did it start? (i.e. following some other garage visit?)
Anyway just a thought - if you're convinced it's the pax seat, that seat is pretty simple to remove... yank it out for a day. If you still have the noise, you've at least ruled it out, and it gives your passenger in the rear seat a lot more room to move around to find the source.
Cab0oze is offline   Reply With Quote
Old 02-01-2018, 01:31 PM   #1304
Midnite8
Member#: 430858
2016 WRX Premium
World Rally Blue
Anyone have a custom sound system/SUB like me with a 2017+ rear view mirror(with autodimm, compass, homelink) experience rattling? I have a 2016 and my rear view mirror rattles really bad on crappy roads and when I obviously crank up my volume. Seeing if the new mirrors have a slightly different design that doesn't rattle as much. I took my mirror apart and added CLD tiles in it to hopefully add mass to it but seems like the issue is where the lip around the plastic meets the actual mirror that rattles.
Midnite8 is offline   Reply With Quote
Old 02-03-2018, 04:09 PM   #1305
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Squeaky STI - 2017 Limited - YouTube
Any ideas?
This ended up being shifter stabilizer bushing (35036AA010 - CUSHION RUBBER-GEAR SHIFT) that needed to be replaced.
So far I haven't heard the noise again. Hopefully it stays that way.
Bottom middle
Old 02-05-2018, 01:20 AM   #1306
Subie_pnw
Member#: 437681
2014 Crosstrek 2.0i
Originally Posted by Devilchrist View Post
Seems liek there's a Lot of repeated questions of rattles.
So I'll just list what I got from various threads.
SOLVED
1. Steering column rattle - This seems like it's the Cruize control button.
Solution - Take stalk apart, remove button, spring and ball, stretch spring. reinsert. no more rattle
2. Rear window rattle - This seems to be the seat bracket
Solution - Take the reat seat back out. The center latch on the seat rattles against the hook bolt. Put some dynamat or some durable thick rubber on top of the bolt head. *note* i put dynamat, it worked for a few months.. but it wore through.. and started ratteling again.. next will be piece of thick leather.
3. passenger Door rattle - this seems to be wiring rattleing against the inner door panel or the cover. Use some sticky foam and wrap wires..
4. wagon spare tire rattle thanks "sjl1614" for solution
solution - Where the spare tire "cover" sits down and rests of the plastic trim, right under there, the trim sits on metal tabs. Which is the souce of the rattle. use some foam tape on the metal tabs and the noise is gone - sjl1614
5. Drivers side door handle thanks "Flat4 STI"
solution - Drivers side door handle,where you pull the door closed would rattle. 3m double sided tape on the bottom of it where the screw pokes through.
6. Steering column top plastic rattle thanks "Flat4 STI"
Solution - 3M double sided tape,Once you take off the top piece of plastic, nearest the steering wheel theres a piece of plastic that sticks up,I used two layers to touch the column plastic pieceAlso about the middle of the steering plastic piece i put another piece of 3M there also.Kinda hard to descibe.
7. Rear deck area rattle where third brake light is "Flat4 STI"
Solution - center seat belt plastic cover in trunk was loose,the piece that covers the retract part,Silicone around top edge to hold it in place.
8. high pitch rattle behind ear thanks "gh32"
Solution - Very faint metal-on-metal high-pitched noise that took me a while to identify. Turns out it was the zipper on the passenger seat on the top of the pass-through (roughly behind where your neck is). Easily fixed with a piece of tape.
9. glove box key hole
Solution - try using some thick silicone grease? if the problem is within the lock, if its outside then, remove the unit and add 3M windows seal
10. glove box rattle thanks "hank3"
Solution - I had the glove box rattle and what I did was wrap some black electrical tape around the U-shaped bracket the door latch attaches to. That fixed the rattle
UNSOLVED
1. Seatbelt top cover rattle - I put this on unsolved because to me removing outright is not a solution.
2. Driver side A Pillar, Vent cover - put puressure on the vent cover piece by the A-Pillar and rattle stops. -
Things I tried
- siliconing the white clips..
- taping the vent cover piece to the bottom piece..
- strips of fuzzy side of velcro (helped a bit but still there)
- removing the entire vent cover
*edit you can emulate this sound by pushing down on the vent piece. repeat until you have the right speed and pressure.. the only way i see to solve this it to jam some thick cloth to maintain the pressure, or take the dash apart... i have not done this yet...
3. Steering column rattle - left wheel goes over bumps - when only the left front wheel goes over the bumps the whole steering column shutters... I dont' think there's going to be a solution to this..
4. Rearview mirror - if you have warrenty left then it's all good but what if you don't? any one have a fix for this?
anyone else like to add?
I've got one not listed... 2014 Crosstrek, there is a rattle (well, in mine at least..) right smack dab in the middle of the dash. I got mad at it once and slapped right under the hazards button and it stopped for about 15 seconds. Now I drown it out with music.
Subie_pnw is offline   Reply With Quote
Old 02-16-2018, 09:12 AM   #1307
bobbypty
Member#: 325834
2011 Impreza 1.5R
Sky Blue Metallic
Default Impreza sedan 2008-2011
Hi guys.
If anyone here has a creaking coming from the rear seats I found that the culprit was the striker/latch mechanism so I wrapped duct tape (maybe felt tape will also work) a couple times so it makes the seat thight when it locks into place and boom! no more noise.
bobbypty is offline   Reply With Quote
SF5 forester thread doublej Member's Car Gallery 20 07-26-2012 02:30 PM
Can We Get a DIY Thread Going? STIckySTIfee General Community 17 04-03-2008 01:00 PM
Can we get another ice thread going? forced4 Texas Impreza Club Forum -- TXIC 0 01-17-2007 12:41 PM
Can we get an OT sing-a-long going? BEGIN! snvin Off-Topic 27 12-01-2005 02:15 PM
