Welcome to the North American Subaru Impreza Owners Club Sunday April 22, 2018
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Private Classifieds
Old 12-09-2011, 04:16 PM   #1
573
Member Sales Rating: (8)
Member#: 144821
1994 LS1 Miata
2015 white WRX
Default 07 WRX wagon. Salvage title. Fix it and have a great car or use it for a swap.
SOLD
For sale here is my beloved 2007 WRX wagon, which unfortunately was totaled in a front end impact with a deer. This car has a little over 55,000 miles on it, and is in excellent condition(aside from the obvious). I took very meticulous care of this car and as a result, it has been perfectly reliable and has no rust. The car also has an extensive list of quality aftermarket and OEM parts that will be included in the sale for the right price. If you're skilled with body work, this car could be fixed up without too much effort and I'm sure it would serve you as well as it has served me. As best as anybody can tell, the frame is perfectly straight. If you want to use it for a swap, the drivetrain has always been strong, powerful, and reliable.
As tempting as it would be to fix it or swap the guts into my daily driver, I'm too tied up with school and other stuff to take on another project. Since I can't do something with it myself, I'd like to see this car go to a good home where it'll either be fixed or put towards something awesome.
I'd like for somebody to buy it for $7500. That'll include all of the parts that are currently on it. I'm open to offers so long as they're reasonable.
If you have any question or would like additional photos, please inquire.
As nasty as it looks, the most difficult part will be welding in a new inner fender and core support. The rest of the stuff will just bolt on.
The cover is broken, but the timing belt stayed in tact. The engine ran normally until I got to the side of the road and shut it off.
Here are some photos from before the incident to give you an idea of how well the car was cared for.
A few additional damage photos can be seen here: http://cgbagne.com/photos/sale/wrx/
Here's the mod list. Everything is there except for what may have been damaged and the light weight battery and Hallman boost controller. Both of those went into my Miata.
Power:
VF48 turbo
3″ HKS downpipe(wrapped)
3″ Dual Tip Maddad Whisper cat back
44mm Tial EWG
Grimmspeed 3 port BCS
Hallman Pro RX MBC (hybrid boost control)
Turboxs EWG up pipe(wrapped)
Process West top mount intercooler
TGV deletes
Modded STi intercooler splitter
DIY intercooler water sprayer
Catch can
Short ram intake(APS MAF housing with big K&N filter)
Intake duct from fog light bezel and cold air box
Walbro 255 fuel pump
Engine Management:
Tactrix Openport 2.0 cable
Road tune by Brian
Launch control and flat foot shifting
Suspension:
Perrin 22mm rear sway bar w/ Perrin heavy duty mounts
Whiteline 24mm adjustable front sway bar
Kartboy end links, front and rear
Whiteline rear strut tower brace
TIC fender braces
Tokico D-Spec struts
OEM STi springs
STi aluminum control arms with “free caster mod”
STi aluminum lateral links
Camber bolts, front and rear
Aligned to 2.5* front, 2* rear, 0 toe, 4.5* caster
Brakes:
Goodrich stainless steel lines
Centric semi-metallic pads
AET Superblue equivalent(it’s amber, not blue)
Drivetrain:
Kartboy short throw shifter
Kartboy urethane shifter bushings(front and rear)
Interior:
OEM Subaru clock pod modified to fit 52mm gauges.
52mm green/white Maddad Clarity Ultra series gauges(boost, egt, oil pressure)
Innovate LC-1 wideband
Innovate DB series gauge(modified to fit into custom housing)
Grey suede headliner
Plastidipped trim
“JDM” red hazard button
Exterior:
Vinyl wrapped hood scoop
Painted headlights
Spec-C roof vent
Rally Armor UR series mud flaps
DIY aluminum under tray
Debadged
DRL’s disabled
Hella Supertone horns
Rear fog light(rewired backup lamp in drivers side tail light)
Wheels/tires:
Summer-
16″ 6 spoke 2.5RS
Dunlop Direzza Z1 Star Spec 225/50/16
Other:
Air pump delete
ABS disable switch
CXRacing aluminum radiator
Odyssey pc680 under passenger seat
Misc weight reduction
573 is offline   Reply With Quote
Old 12-09-2011, 04:40 PM   #2
ssyellow
Member#: 243316
Bump for a good guy and quality car. I don't think meticulous even begins to describe how good he took care of it. Best of luck Curt.
ssyellow is offline   Reply With Quote
Old 12-09-2011, 04:57 PM   #3
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Thanks man. Tis appreciated.
Old 12-09-2011, 05:01 PM   #4
tcooper
Member#: 195468
2005 9-2x saabaru
sliver
Bump for a friend and I have seen this car in person before the crash. One of the cleanest I have seen and with a great owner.
Wish it didnt end like this
Good luck!
tcooper is offline   Reply With Quote
Old 12-11-2011, 09:16 AM   #5
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Thanks Toby.
TTT
Old 12-11-2011, 10:27 AM   #6
hoffmanEstates
Member Sales Rating: (33)
Member#: 122043
04 wagonier
psm
Pm sent
hoffmanEstates is offline   Reply With Quote
Old 12-11-2011, 10:41 AM   #7
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Replied.
I'm not going to part the car out just yet. If I can't sell the car whole, I'll do that as a last resort.
Old 12-11-2011, 01:17 PM   #8
hoffmanEstates
Member#: 122043
04 wagonier
psm
Cool really need pump
Old 12-12-2011, 07:31 PM   #9
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Bump.
Old 12-13-2011, 05:46 PM   #10
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Make me an offer.
Old 12-13-2011, 07:36 PM   #11
hoffmanEstates
Member#: 122043
04 wagonier
psm
No parting out yet huh
Old 12-13-2011, 08:13 PM   #12
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
No, it'll be a few weeks before I resort to that.
Old 12-17-2011, 12:34 AM   #13
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Bump for a lower price. $7000
Old 12-18-2011, 01:01 AM   #14
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
bump it up.
Old 12-21-2011, 08:50 AM   #15
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Ttt45
Old 12-21-2011, 09:21 AM   #16
av3ng3r
Member Sales Rating: (6)
Member#: 133195
1998 Impreza RS
Open Light Rally Car
If this is still available in a month, there's a VERY good chance I'll take it off your hands.
av3ng3r is offline   Reply With Quote
Old 01-04-2012, 01:46 PM   #17
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
I didn't see this until now. The car is still available and it seems like you'll be in luck. If you would like any more details on this, please shoot me a PM. I'd be happy to answer questions, take more photos, or to arrange for you to come see the car in person.
Old 01-04-2012, 05:58 PM   #18
av3ng3r
Member#: 133195
1998 Impreza RS
PM sent
Old 01-04-2012, 11:14 PM   #19
rpdwrx
Member Sales Rating: (4)
Member#: 92904
2002 PSM WRX
1998 RBP WRSX
Is the car in Troy, MI?
rpdwrx is offline   Reply With Quote
Old 01-05-2012, 10:52 AM   #20
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Yes it is. If you're familiar with the area, it's near the intersection of Long Lake and Adams.
2003 WRX with Salvage title for sale tripaddle Newbies & FAQs 5 02-04-2011 10:37 AM
FS : CA: 2002 subaru wrx sport wagon salvage title dhernandezjr Private Vehicle 'For Sale' Classifieds 2 07-06-2010 04:34 AM
Going for an 02-03 wrx swap...Buy a full Parts car or piece it together? GmRally95 Subaru Conversions 4 04-16-2009 05:35 PM
Do I get winter tires for both cars, or use the spare cash to fix up the white RS? AcquaCow Mid Atlantic Impreza Club -- MAIC 33 11-03-2006 09:31 PM
