Brakes & Suspension Forum sponsored by The Tire Rack |
11-15-2004, 05:52 PM | #1 |
Member#: 48589
SCIC
Vehicle:2003 911 Carrera 4S 2020 Ascent *Lifted* |
GC suspension on a 2004
Yes I searched...
I have the chance to get the full suspension setup from a 2001 RS sedan. But I'm really skeptical it will work. I was told that I could change out the tophats and get new camber bolts and then it should work. The set up is: "KYB AGX Adjustable 4 way front 8 way rear shocks, 5 Zigen R-Rate Springs! " It would come with everything even the top hats, basically he is gutting the car to make a race car and he would give me everything. Any ideas? Should I pounce on this, its local and only 350 bucks. -Jeff Edit: I have an 2004 RS
11-15-2004, 08:09 PM | #2 |
Member#: 48589
SCIC
bumpage.
11-15-2004, 08:17 PM | #3 |
Member#: 40617
since its local you could try it out and then see if it fits...
11-15-2004, 08:26 PM | #4 |
Member#: 48589
SCIC
thats true, but I was just curious to see if anyone has tried this or had any feedback.
-Jeff |
11-16-2004, 01:36 PM | #5 |
Member#: 3887
Vehicle:08 Taco, 98 M3/4/5 '00 RC51, '08 KTM |
You should be using new-age impreza parts (wrx, sti, its all compatible) in your 2004. You need to be worried that anything for the other generation will not have the proper lengths, stiffness, damping and strut geometry for your car. While stuff will potentially bolt in, thats where the compatibility really ends.
11-16-2004, 01:41 PM | #6 |
Member#: 48589
SCIC
thanks, thats what I was worried about.
-Jeff |
11-16-2004, 07:11 PM | #7 |
Vendor
Member#: 37584
Vehicle:2002 WRX Sedan Silver - STX #81 or #18 |
At the very least the rear of the car would sit lower with the old style struts. There were many people that put pre 2002 AGX's on their 2002+ Imprezas and "made them work", but since properly fitting parts are out now you should probably skip them.
Matt |
11-16-2004, 09:41 PM | #8 |
Member#: 18978
SCIC
Vehicle:96 brighton 05 AP2 ,09 GE8 |
to fit the older suspension on a 02-03 wrx, all thats needed to change is the rear top hats
11-17-2004, 12:43 AM | #9 |
Member#: 48589
SCIC
I am getting conflicting info from all over the place! LOL I dont know whats right...
Some say "No it wont work" or "you just need to change tophats or get camber bolts" Anyone confirm this? -Jeff |
11-17-2004, 01:36 AM | #10 |
Member#: 18978
SCIC
I've personally used coilovers for the gc on my gd chassis. The top hats in the rear are different. The mounts for the brake lines and other things are a little off as well
GD Suspension on a GC | Turn in Concepts | Brakes, Steering & Suspension | 53 | 05-28-2019 12:49 AM |
GC Suspension on 99 Forester? | Local_Skater | Brakes, Steering & Suspension | 0 | 01-23-2009 10:57 PM |
Aftermarket WRX suspension on GC? | A Guy with a STi | Brakes, Steering & Suspension | 9 | 09-10-2007 09:17 AM |
Searched, can't find it, GC suspension on a 2005 wagon | Marcin | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 08-31-2005 08:16 AM |
2002 WRX suspension on a 2004? | SSTINGER77 | Brakes, Steering & Suspension | 2 | 02-08-2005 08:01 PM |
