Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 07-26-2006, 07:43 PM   #1
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Wirelessly posted (Treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
As the title says:
Is Delta Dash a stand-alone or an add-on option to the basic EcuTek license?
The reason I ask: I currently don't have EM and I have an opportunity to buy a Delta Dash new from someone here for a good price. I'm not sure if I get it if I'll still need to get my ecu flashed or if I can just load the Delta Dash and go. I looked on their website but it didn't really answer my question. Will I still need to purchase a license above and beyond what comes with the new Delta Dash? If not, can I tune with it or will I still need to go to an EcuTek tuner and just use the Delta Dash for logging and real-time analyzing/diagnostics?
chrisarella is offline   Reply With Quote
Old 07-26-2006, 07:50 PM   #2
teiva-boy
Member#: 22825
Get the new Ecutek system that comes with the Delta Dash license included in the package. /Thread
You can't really tune with it, it's primary purpose is for logging. Granted you can change a few values, but they are not saved once you turn off your car.
The Delta Dash is licensed by a USB or parallel dongle that plugs into your laptop (end-user supplied)
The Delta Dash is independent of an Ecutek tune.
teiva-boy is offline   Reply With Quote
Old 07-26-2006, 08:07 PM   #3
JRSCCivic98
Member#: 67080
There's no package of such for non-DBW cars. Only available for 04+STI or 06+WRX as of right now.
JRSCCivic98 is offline   Reply With Quote
Old 07-26-2006, 08:37 PM   #4
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
DeltaDash is not specific to any particular car - the same software works on all cars it supports.
HOWEVER, you should know that it can only be used with three different ECU types. For instance, if it was already used on a 2002WRX, a 2003RS, and a 2005 STI, that means that you will forever have to use it with those three types of ECUs and nothing else, unless you pay ECUTek to reset your license.
I can't read the FS thread cause it's a WAP link and it doesn't seem to work in my browser, but make sure you have it cleared up what you're buying.
nhluhr is offline   Reply With Quote
Old 07-26-2006, 09:46 PM   #5
Freon
Member#: 88322
2009 BMW 135i
I'd also recommend just getting a tactrix cable and ecuexplorer for basic logging. Maybe not as fancy as DD, but it works and only costs $80 for the cable.
Freon is offline   Reply With Quote
Old 08-03-2006, 10:57 AM   #6
jkbrand
Member#: 107118
'02 STi Wagon
After buying this cable, I gotta say: I should be looking at getting into the cable-making business. At best, about $10 worth of connectors; $5 of wire.
jkbrand is offline   Reply With Quote
Old 08-03-2006, 12:56 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
Go for it.
Jon [in CT] is offline   Reply With Quote
Old 08-03-2006, 04:34 PM   #8
Gethin
Member#: 2998
And a shed load of R&D. Feel free to make your own cable and get the drivers and protocols working.
p.s. There is also electronics inside the connector ensuring proper baud rates and voltage.
Gethin is offline   Reply With Quote
Old 08-04-2006, 01:26 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
walk around compusa ... then a discount computer store .. you might say the same thing
+1 for taxtrix
Old 08-03-2006, 11:50 AM   #10
chuckdez
Member#: 120187
2005 STI Blouch Dom
Obsidian Black Pearl
Check out the lastest version of ecuEdit. With nice logging features.. Works with Innovate Widebands.
Screenshots here.
http://www.epifansoft.com/phpBB2/viewtopic.php?t=3
Logger
- Innovate Wideband Lambdas support (Innovate ActiveX component)
- SSM (Subaru Select Monitor) support, DTC reader, Custom Memory Logger
- Custom graphs quantity (2 parameters on each graph)
- Custom dash item quantity (grid X by Y)
- Scheme saver/reader. Save/restore all selected log parameters
- Warnings (set Max,Min values for each Log parameter)
- All Logger parameter's description in XML
Log Viewer
- Functions
- Calculated Custom Parameters
- Graphs, Custom 2D,3D graphs
- RPM and Speed based road dyno
- Custom log table with graph (surface, bar plot)
- Logs overlay (shifting, hiding)
- Range selector, quickly select log data by range. Example: select full throttle range for custom 2d,3d graph analysis.
chuckdez is offline   Reply With Quote
V4 stand alone or open source tune? Rei_Akira Pre-2002 Factory Turbo Powertrain 20 05-04-2009 04:10 PM
what is DELTA DASH??? 2002bugeye Car Audio, Video & Security 1 12-13-2005 08:49 PM
Management for a strange swap - stand alone or carbs? mranlet Engine Management & Tuning 7 10-08-2004 11:58 AM
2005 Sti. Radio standard or add-on option? Naka General Community 10 05-03-2004 04:46 PM
are you still using delta dash with stand alone utec ect? Turbo Tin Can Engine Management & Tuning 2 10-01-2002 06:10 PM
