Welcome to the North American Subaru Impreza Owners Club Saturday December 16, 2017
Old 11-24-2017, 11:45 AM   #1
racesubi123
Member#: 449510
Default Hpx Maf 05 Sti
I am trying to find out if anyone has used a blow through HPX MAF on an 05 STI. I would like to keep my factory ecu and tune through ECU FLASH or something similar. Can this be done, if so how? Has anyone done it?
racesubi123 is offline   Reply With Quote
Old 11-24-2017, 12:15 PM   #2
motorbykemike
Member#: 273868
more details on the setup/combo would help
I used a fmic perrin blow through maf tube briefly with not so great results
but why not just go sd or hybrid maf/sd?
motorbykemike is offline   Reply With Quote
Old 11-24-2017, 02:54 PM   #3
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I haven't seen it tried before but I'm curious now. The 0-5v signal should be compatible with the stock MAF. If the IAT signal isn't compatible, you could just use a GM IAT sensor - that's a fairly common swap for Subarus and wouldn't be much extra work.
I also tried blow-through with the stock sensor, also with poor results. But HPX is available with a sensor+housing combo that might fix the issues that have come up with so many blow-through setups.
