Welcome to the North American Subaru Impreza Owners Club Tuesday September 25, 2018
Old 03-15-2008, 10:49 PM   #26
garagedefeat
Member#: 101399
2001 Forester L
garagedefeat is offline   Reply With Quote
Old 03-15-2008, 10:56 PM   #27
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Wow, this is an awesome post man! Thanks for doing the legwork on it!
Old 03-15-2008, 11:53 PM   #28
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Originally Posted by garagedefeat View Post
AH! That should work with standard spring perches for camber plates provided the ID of that spring perch you have on there is usable for the camber plate perch.
you're stack height is gonna suck, but it beats a sharp stick in the eye.
What's the ID of the silver aluminum bit you have there?
Old 03-16-2008, 12:01 AM   #29
garagedefeat
Member#: 101399
2001 Forester L
Does this mean the highest setting on the threaded collar will be higher than normal...similar to when some front camber plates are used that add height?
i'll check it out and post up some numbers.
Old 03-16-2008, 09:27 AM   #30
Turn in Concepts
Member#: 93646
Many Track Records
Yes - it's going to increase the stack height.
I have a theory though that if things works out with the ID as I think they will you can gain some of that back, and it won't be too expensive.
Old 03-16-2008, 12:16 PM   #31
garagedefeat
Member#: 101399
2001 Forester L
^^thanks. now i have a new motorsports word to add to the vocabulary^^
actually - i was worried about not having enough stack height with these kw's, so it may just work out for the better. These are going on a Forester which should explain that a bit. The other STi-specific coilovers I had on there really didn't let the car sit high enough to keep the susp. geometry in check.
I have PDE camber plates in the front to add some stack btw..
Old 03-16-2008, 06:18 PM   #32
garagedefeat
Member#: 101399
2001 Forester L
bottom side ID
bottom side OD
top side OD
Old 03-31-2008, 03:31 PM   #33
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
REAR CAMBER PLATES by Vorshlag
We've been waiting a very long time for these, and I'm happy happy happy to announce they are here. I mean seriously, really happy.
So here's the details:
Compatible with 60 mm Coil-Over springs (perches for 2.5" coming soon).
Installs with basic hand tools, no chassis modifications required.
Plates are designed specifically for 02-07 Impreza
Camber is adjustable at the track from the trunk with simple hand tools.
The spherical bearing used in Vorshlag camber plates is the largest used in any Subaru camber plate. The result has much better durability and wear characteristics than the undersized bearings used in some competitors' plates.
Designed using alloy steel, not aluminum, for the minimum stack-up height and maximum suspension bump travel. More than an inch more strut travel than some of our competitors!
100% CNC machined, alloy steel construction - Tough as a German Tank!
All components plated for maximum corrosion resistance and long life.
And a couple of other things:
Camber challenged Wagon guys with sedan coilovers - this is something you really want to think about.
Vorshlag also added a nice little bonus - a single row bearing for the upper perch to allow it to turn freely while compressing and decompressing.
Stack height is ONLY about 31mm. This beats the heck out of the stack height that uses the stock top hats and upper perch adapter as that comes in at over 60mm.
AbACUZ is offline   Reply With Quote
Old 03-31-2008, 03:41 PM   #34
Turn in Concepts
Member#: 93646
Many Track Records
bottom side ID
bottom side OD
top side OD
Ok - I think I've got something that can work for that setup. shoot me an email and we can discuss there - clint at turninconcepts dot com
Old 04-01-2008, 03:52 AM   #35
garagedefeat
Member#: 101399
2001 Forester L
emailed^^^
Old 04-01-2008, 06:08 PM   #36
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
What a great thread! Thanks everyone!!!
Boxer4u is offline   Reply With Quote
Old 04-08-2008, 04:20 PM   #37
AbACUZ
Member#: 101898
BUMP with pictures of myself , ME ME ME ME !!! oh yea, and the camber caster plates on the dspecs
Old 04-14-2008, 07:48 PM   #38
Turn in Concepts
Member#: 93646
Many Track Records
HAHA!!! Awesome pics!!!
Old 04-23-2008, 02:14 PM   #39
AbACUZ
Member#: 101898
Added: the bilstein + camber plate thread
Added: bunch of info on memory steering issues
Old 04-23-2008, 03:54 PM   #40
crashtest sonny
Member#: 78675
2002 white bugeye
04 kawasaki 636
do you know if the tein pillow ball front upper mount (gold) will work with regular springs (tanabe gf210) and also jdm sti version 7 struts? or does it require coilovers? can i use the stock spring perch to make it work? thanks.
crashtest sonny is offline   Reply With Quote
Old 04-28-2008, 07:32 PM   #41
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
I am wondering the same thing Crashtest Sonny is... Will Tein Camber Plates work on OEM Spring/Shock setups? I Have a set of Flex's that need rebuilding, but the extra negative camber of the plates will really help hold me over until I can get the flex's rebuilt
nperkins is offline   Reply With Quote
Old 05-22-2008, 08:13 PM   #42
AbACUZ
Member#: 101898
Bump
highlated the thread about whileline camber plates because of continuing issues.
Old 05-29-2008, 02:36 AM   #43
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
So there are only 2 brands which LOWER the front?":
RaceComp Eng = 3/8"
Ground Control = 3/4"!
any others out there?
djerickd is offline   Reply With Quote
Old 06-12-2008, 12:38 AM   #44
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
anyone?
Old 06-12-2008, 07:07 AM   #45
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
RaceComp Eng = 3/8"
The Vorshlags don't lower the front, I think, but they don't raise it as much as most of them. Other than that I think you're right. And the Ground Controls and the Vorshlags are built for coilover springs, not "regular" springs.
Old 06-12-2008, 07:43 AM   #46
Turn in Concepts
Member#: 93646
Many Track Records
That is correct, but I also know that vorshlag is working on a setup for regular springs and dampers. I will ask about progress on that.
Old 06-12-2008, 09:04 AM   #47
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
ohh thats good info, thanks!
Old 06-30-2008, 08:16 PM   #48
AbACUZ
Member#: 101898
Bump for more info
Old 06-30-2008, 09:52 PM   #49
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Only new info I have is that camber plates work MUCH better with sedan control arms
Old 07-02-2008, 10:37 AM   #50
Richard A.
Member#: 79
1999 2.5 RS
RBP
I now have a set of RCE T2's on order for my 99rs. I currently have a set of Cusco camber plates but want more caster than I can get with them rotated. I want to get new plates for the T2's and it's come down to the Max-C and the Vorshlag.
I would put the Max-C's on the opposite sides, from normal, where they would be basically caster only adjustable but still give a camber gain of -1.5* in addition to what I can get with the OE bolt and lowering, that will be more than enough for my autocross needs. The main reason I'm having a problem with the idea of using these is that a number of people are having problems with them.
The reason I'm considering the Vorshlag's is they are said to give more caster even in their normal position, meaning that they set back the the camber adj. slot from the front of the car more than other plates, which try to maintain stock caster. Does any one know how much the set back is? I would get the plates for the GD but put them on my GC so they would angle back and in like my rotated and flipped Cusco's but their additional set back would help with more caster than I can get with the Cusco's. If I'm figuring it right I could also flip and rotate the Vorshlag's and make them a caster only adj. plate but I need to know how much they are set back to get an idea of how much camber I'd be giving up to the Max-C. I do like the idea that the Vorshlag's may allow me to use a longer spring as well. Also, if anyone has these, how much, if any, room is there to extend the adj. range for more negative camber if I wanted to extend the slots?
edit, 7/3. I e-mailed Vorshlag my ??? an got a response late yesterday. The engineers conferred and checked their technical drawings and said that their GD camber slot sits back .2" and generates an additional +.55* of caster based on a strut length of ~21". They also said the reason they didn't set it back more was to accommodate a future OEM spring perch. They also said that after my ??? that their web site was updated to reflect this info.
Richard A. is offline   Reply With Quote
front camber caster plates with least raising of the car gharari Brakes, Steering & Suspension 17 11-06-2005 11:26 AM
ALK vs. camber/caster plates thebusiness999 Brakes, Steering & Suspension 9 01-29-2003 12:24 PM
The new and improved MRT camber/caster plates & DMS 50s ChrisW Brakes, Steering & Suspension 8 08-17-2002 01:42 PM
front camber/ caster plates (WRX) priebe Brakes, Steering & Suspension 12 01-25-2002 07:56 AM
Front Camber/Caster Plates gumby647 Brakes, Steering & Suspension 5 09-07-2001 12:09 AM
