Welcome to the North American Subaru Impreza Owners Club Sunday June 24, 2018
Old 02-22-2018, 05:47 PM   #1
Leosfo
Member#: 420968
2015 WRX
CWP
Default 2015 WRX replace wheel studs
Hi
This tool from Amazon https://www.amazon.com/dp/B01JYFCLXK...ink_convert-20
will make your stud removal on the front hubs much less violent. No banging your precious WRX with a mini sledge, just crank down on the screw with your ratchet. cant vouch for rear studs yet.
Leosfo is offline   Reply With Quote
Old 02-23-2018, 12:51 PM   #2
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
I'm having a hard time visualizing how a ball joint seperator helps with removing wheel studs.
Suba_Roo is offline   Reply With Quote
Old 02-23-2018, 01:02 PM   #3
Leosfo
Member#: 420968
2015 WRX
CWP
You place the y shaped arm on the rear of the hub. Position the solid arm that opposes the y shaped arm on the threaded side of the stud, turn the screw and as the arms close, the stud is forced out of the hub, through the y shaped arm.
