Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 01-09-2005, 08:53 PM   #1
igalwrx
Member#: 13643
'02 WRX Sdn WRB
'05 Leg GT Ltd Wgn Black
Default Anyone have the Orciari Headlight Install Instructions?
I've recently acquired the bugeye Orciari headlamps. I didn't get any instructions with them. I'm most interested in the wiring portion of the instructions. If anyone has it and can fax or email it to me I'd really appreciate it. If you have the '04 stlye I can use that too since I think the wiring would be similar. Thanks
Igal
igalwrx is offline   Reply With Quote
Old 01-10-2005, 07:45 PM   #2
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
I have the "bug-eye" orciari installation instrs, and would be willing to fax them to you, though I believe a pdf version used to be available from CC-B.
I saw that you posted to the following thread:
http://forums.nasioc.com/forums/show...=edm+levelling
I provided a scan of the wiring part of the instructions there already, and IIRC, that is pretty much all that's provided by ORCIARI as far as wiring goes.
If you're interested in hooking up your orciari's, or even your levelling motors, I can help with that as I have mine hooked up with the levelling motors fully functional.
Question for you though -- is your orciari set new or used? Make sure you have the little black boxes for interfacing with the levelling motors. AFAIK, these are required for the ORCIARI levelling motors to work properly.
-- hope that helps!
Dendrobium
Dendrobium is offline   Reply With Quote
Old 01-10-2005, 09:12 PM   #3
igalwrx
Member#: 13643
'02 WRX Sdn WRB
-- hope that helps!
Dendrobium
PM'ed you.
Yeah, I got them used and CC-b.com's link doesn't work anymore. I'm pretty sure that the lights came with the black boxes for the motors, but I'll have to double-check. I saw your write-up on the leveling switch install and it looked great! My only problem is that I have the 6-pin switch and it looks like there is no way it's going to work with the Orciari's. Looks like I'm going to have to break down and buy the 4-pin switch. Thanks for the offer to fax me the instructions.
Igal
Old 01-11-2005, 01:24 PM   #4
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
not that I would have minded the fax charge -- but I managed to dig up my own copy of the pdf that used to be on CC-B's site. In fact, the instructions that came with the ORCIARI lights seem to be a xerox copy of the following pdf: here (right-click and save as).
Good luck, and congrats on the new lights!
-- Dendrobium
Old 01-11-2005, 04:11 PM   #5
igalwrx
Member#: 13643
'02 WRX Sdn WRB
-- Dendrobium
You are the MAN!!! Thanks sooooo much.
Does anyone have a link to install instruction for the Turboxs FMIC? MattSTi General Community 4 12-25-2005 12:21 PM
Anyone have the Twin headlights from ISR Performance? adam555 Electrical & Lighting 7 12-10-2003 10:35 PM
Anyone have the Boost Monkey install pages? KwanDDS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-13-2002 02:00 PM
Anyone have the new headlights going for $300? dman918 Interior & Exterior Modification 3 05-05-2002 12:58 AM
anyone have the ALK not installed? greg Mid West Subaru Owners Club Forum -- MWSOC 0 11-14-2000 07:04 AM
