05-02-2009, 12:02 AM | #51 | |
Member Sales Rating: (212)
Member#: 136396
Vehicle:2020 STI, 2022 WRX |
The hose fittings should be tight so you do not have leaks. Just take a wrench and give them a tightening if need be. Get them hand tight in the position you want them. NOTE: All BCS's are now being shipped with a 90 degree hose fitting on port 3 so there should be no more issues with the middle port getting close to the strut tower on the older wrx's. Justin
05-02-2009, 04:55 PM | #52 |
Member Sales Rating: (4)
Member#: 96267
Vehicle:'06 20G-XT'd STI CGM & NT03+M |
Vaccum tubing size and type?
Hey guys, is 5/32 vacuum tubing the correct size?
I also saw 'hard' (more rigid) vacuum tubing at the store, as opposed to the normal tubing material. |
05-04-2009, 04:48 PM | #53 | |
Member#: 136396
Yeah the 5/32 is the correct size for the tubing. I would probably just use the standard tubing since i'm sure its more flexable. Mike |
05-04-2009, 05:54 PM | #54 |
Member Sales Rating: (6)
Member#: 193616
Vehicle:06 WRB WRX |
hey guys, i have a question regarding bcs......i have a 06 wrx, a/t.......ive just put in vf43, sti tmic, walbro pump and gms inlet.......car is running absolutely fantastic......i have about 20 lbs of boost midrange and 17 up top......do I need a bcs or my stock one is good enough......though i was told u need bcs if ur running higher boost like 21-22 lbs or over.......just looking for some advise. thxxx
05-05-2009, 05:37 PM | #55 | |
Member#: 136396
Mike |
06-10-2009, 01:18 PM | #59 |
Member Sales Rating: (49)
Member#: 128269
My BCS from you guys works flawless. I will probably be needing a new mounting bracket here soon if my plans go through and I can get into another Subaru
Grimmspeed EBCS = |
06-10-2009, 07:05 PM | #60 | |
Member#: 136396
PM us if you'd like a list of dealers who have them available. Mike |
06-10-2009, 07:45 PM | #61 |
Vendor Sales Rating: (617)
Member#: 79304
South East
Vehicle:CALL 941-257-9618 www.ImportImageRacing.com |
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Open Daily To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. #1-941-257-9618 AIM= importimagerace To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Best Deals on To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. !!! Let us Beat your Lowest Price Quote!!!!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. <> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
06-10-2009, 10:45 PM | #62 |
Member#: 129231
Vehicle:2005 wrx cgm |
tial 44 ewg diagram please?
btw grimmspeed uses a mac solenoid in these. lots of honda guys have been using mac solenoids for year. and the aem truboost uses the same solenoid too. |
06-10-2009, 11:21 PM | #63 |
Member Sales Rating: (19)
Member#: 88912
Vehicle:2014 Impreza Sport White |
Have one of these sitting in my room, should be installed & tuned within a week or so. I'll update once that happens but I'm sure it will be positive just like every other GrimmSpeed product.
06-10-2009, 11:35 PM | #65 | |
Member Sales Rating: (2)
Member#: 192147
NESIC
Vehicle:2007 STI EfiLogics 422whp 421wtq fpgreen |
i used this and it worked great http://forums.nasioc.com/forums/show....php?t=1744450 |
06-16-2009, 10:30 PM | #71 |
Member#: 134565
HIIC
Vehicle:2006 STi Black |
I love my 3port. Matt from 555 was the one that recommended it. He also tuned my car and it came out great!
+1 grimmspeed for plug and play quality! |
06-18-2009, 04:36 PM | #73 |
Member#: 113940
E. Canada
Vehicle:2006 WRX Steel Grey Metallic |
Does anyone have any tips on how to re-tune my map using the Grimmspeed 3-Port BCS? I know the website says to "reduce WGDC by 30% and to go from there", but I'm not sure of "where to go" after doing that.
06-18-2009, 05:15 PM | #74 |
Member Sales Rating: (12)
Member#: 173321
E. Canada
Vehicle:2007 SWP WRX dom2.5xtr w/ meth & 6spd |
I have a question regarding the EBCS, I picked one up for my VF48 and got a e-tune from ClarkTuning. I installed it as per the website on the 06-07 WRX and boost is slow (19.72psi @3300 rpm on the stock BC/ 20psi @ 4700rpm on the grimmspeed). I can remove, put the stock on back on, reflash back to my old map and have quick spool again. Any ideas?
06-18-2009, 06:53 PM | #75 | |
Member#: 136396
Mike |
WTB - GrimmSpeed 3 port BCS | 2slow | Private 'Wanted' Classifieds | 3 | 07-07-2009 02:53 PM |
fs- grimmspeed 3 port bcs | badmutha | Engine/Power/Exhaust | 0 | 06-28-2009 06:40 PM |
Tuning Grimmspeed 3-port BCS | bdon22 | Open Source Reflashes | 5 | 06-18-2009 08:02 PM |
FS: NJ Grimmspeed 3 Port BCS (02-05 WRX Bracket) | SpoolinWRX4 | Tri-State Area Private Classifieds | 12 | 05-03-2009 08:08 PM |
FS: Grimmspeed 3 Port BCS | SpoolinWRX4 | Engine/Power/Exhaust | 14 | 05-03-2009 05:11 PM |
