#1001 | |
Member#: 207263
Vehicle:2019 WRX Limited World Rally Blue |
![]() Quote:
If it's powered, then the inputs should all be taps on speaker level outputs to the door speakers.
#1002 | |
Member#: 491653
Vehicle:2011 Impreza Sti White |
![]() Quote:
Thanks in advance Davide |
#1003 |
Member#: 438216
![]() You could check with the guys at http://autoharnesshouse.com. They have done custom built harnesses for a number of the members on here.
#1004 |
Member#: 492053
![]() Hi. I have a major problem on my BRZ. I have complete no sound on my speakers and i can't select the FM station on the head unit only AM station can be selected. What can be my problem?
I would appreciate your help on this issue. P.S.: sorry for my bad English, English is not my birth language... |
#1005 | |
Member#: 207263
![]() Quote:
Are you using a stock or aftermarket HU? |
#1006 | |
Member#: 492053
![]() Quote:
For exemple, if have selected the CD player and then select the FM, it change automatically to the AM and don't stay in the FM. |
#1007 |
Member#: 491377
Vehicle:2013 Subaru STI Black |
![]() So, on my 2013 STI (US car) I started getting a message on startup saying "check antenna", relating to the satellite radio antenna, was working fine, but finally stopped getting a signal. So now I am without my sat radio, which is really annoying.
Is this a simple problem of needing a new antenna, or has the receiver actually gone bad? |
#1008 |
Member#: 207263
#1009 |
Member#: 492053
![]() Sorry i can't understand the question. The HU is like this
![]() I don't know the exact year of manufacture, i would have to confirm it on the car. P.S.: the car it self is from 2015 so i would say the HU have 3 years. Edit: in relation to the speakers with no sound, anyone knows what could be? Last edited by kirz; 09-29-2018 at 09:11 AM. |
#1010 |
Member#: 492053
![]() Bump. Anyone with knowledge about my topic could please help me...
#1011 |
Member#: 17606
NWIC
Vehicle:2008 STI hatchback Silver |
![]() I am so glad this information was available. I got a 2008 STI with factory Nav, it took a bit of digging to this thread. And its really the only place that has the factory Nav harness info. Still not sure if I was supposed to use illum + or -. Guess i'll find tonight on the drive to work.
#1012 |
Member#: 17606
NWIC
![]() Well I have ran into one problem. One I think I got the wrong Illum wire, that not big. But the real problem is I can't get CAN data. I have installed a JVC KW-M740T with the idatalink ADS-MRR and its getting an OBD2 error using the CAN H and L as labelled here. It says to go to the OBD2 port, but dang it I ran out of butt splices.
#1013 | |
Member#: 497403
![]() Quote:
I would like to upgrade from the base CZ601U1 to the Kenwood NAVI FXDB09EF2. Already send him two e-mail but I have no feedback from him. Or if you know another way to source the cable i would be really thankful. |
#1014 |
Member#: 497099
Vehicle:2007 Outback Sport Urban Gray |
![]() After digging through here for the last couple of days, I can’t find much up to date information for a 2007 Impreza radio (with stock AUX) options for BT or USB integration into the stock HU. I have the unused port for SAT radio, but even if the 2008+ iPod dock would work the 30pin connected wouldn’t. I’ve been there and done aftermarket HU’s before, but this time I want to stay stock.
Any good aftermarket fixes or stock hacks? I just want control over skipping tracks through the radio at this point |
#1015 | |
Member#: 498413
International
Vehicle:2007 Impreza GH7 JDM |
![]() Quote:
Thanks for the guide, was about to give up trying to find a solution! |
#1016 |
Member#: 468210
BAIC
Vehicle:2006 WRX Wagon Blue |
![]() Hoping this thread is still monitored.
On the 06 Subwoofer T harness there is a additional 8 pin black connector with one jumper and two leads. Can anyone tell me what this does? I am considering changing the P-133 for a C-124 from an 07 No one breaks in for a stock H/U UPDATE found this post & solved https://forums.nasioc.com/forums/sho...0#post13335030 Last edited by m5gorrf; 07-23-2019 at 10:37 AM. |
#1017 |
Member#: 375267
NESIC
![]() Will updating the grace note database on a '18 WRX stock radio add apple car play like the '19 WRX has?
#1018 |
Member#: 450808
SCIC
Vehicle:2017 WRX Premium WR Blue Pearl |
#1019 |
Member#: 301690
Vehicle:2002 Wrx |
![]() I tried search. This thread is a cluster. Now that it's 2019, anyone able to provide insight on a later model subarus that have a standard double din size that will physically fit into a 04-07 impreza wrx dash?
I know there are wiring harnesses out there that can take care of most of the rest. |
#1020 |
Member#: 93830
![]() Will our headunits receive the recently released Android Auto update?
2019 sti |
#1021 |
Member#: 496163
Vehicle:2018 Forester Pearl White |
![]() Although I don't use AA but CarPlay this is what I found as I usually get beta version of several OS's (win10, Macs Catalina, iOS's). The CarPlay interface changed from using iOS 12 to 13 in layout and features. I am assuming that AA will do the same on the phone when it is updated. I did upgrade the 7" infotainment to a kenwood 9904s using the info on this site.
#1022 |
Member#: 507702
![]() Trying to figure out an intermittent issue with my wife's car. 2010 Impreza, stock as stock can be
Every once in awhile,no pattern that I can figure out, the stock radio and dash clock/MPG display unit will not turn on with the car. Both displays will be blank. Shutting off and restarting usually fixes the issue, sometimes it takes a couple restarts. The memory is not affected, clock is right and presets are still loaded. As far as I know, all the interior lights and other KOER stuff is working like it should, seeming to rule out an ignition switch problem. I have searched and the closest thing I have found is just relating to the clock, with a bad solder point, but that usually was accompanied by the clock resetting, nothing including the radio. The fact that its not a regular thing is making it a little difficult to figure out. Has anyone run into a problem like this? Short of tearing it apart and looking to see if anything looks out of place, what should I check? |
#1023 | |
Member#: 507317
Vehicle:2019 WRX Pure Red |
![]() Quote:
Agree. a 10yo thread does absolutely no one any good. These forums need to be broken down even more either by MY groupings or chassis designator as then people can look for items specifically related to their car/chassis code. I'm here for just a simple (speaker) wiring diagram/pin-out for the 2019 6.5" Starlink found in the base model WRX. It is like trying to find a penny on a soccer field and not knowing where that penny actually is -- lots and lots of (creative) searching required. Subaru has more audio configurations and combos than VW/Audi and it can be a real mess trying to find items in all of these child forums. Example - why are Interior and Exterior modifications combined? Each is a different area of the car and needs to/should be their own separate forums. Same goes for lighting and electrical/car audio...different areas/topics, different forums; not crammed in the same one. [/rant over] |
#1024 | |
Member#: 294027
![]() Quote:
#1025 |
Member#: 511996
Vehicle:2004 WRX |
![]() Hey guys, sorry for the newb question, but it should be an easy answer for someone. I recently bought a 2011 WRX with the stock headunit and the SAT button that does nothing since there isn’t a Satellite radio module hooked up. I found one from a 2007 WRX part #H621SSA101 ... the one I’m seeing for my 2011 is part #H621SSC001 . What’s the difference that would prevent me from using the 2007 one in my 2011. Thanks!
Stock head unit information -- pin-outs, aux inputs, and more | SVXdc | Car Audio, Video & Security | 12 | 01-23-2007 02:27 AM |
Question about factory head units | nsnguyen | Car Audio, Video & Security | 7 | 04-30-2004 02:26 PM |
Question about using head unit to power back speakers | STI-o-MY | Car Audio, Video & Security | 0 | 12-01-2003 03:06 PM |
question about my head unit | creature546 | Car Audio, Video & Security | 1 | 10-03-2002 07:48 PM |
