12-31-2003, 11:09 AM | #1 |
Member#: 20612
NESIC
Vehicle:2012 Impreza Sedan Black |
From EJ22 to EJ25 on 95 Legacy, Is it Possible?
With the Legacy getting a new engine anyway, can anyone tell me what is involved to go from 1995 MAF Eqipped EJ22 to any year EJ25? Is it possible with just a computer and engine?
12-31-2003, 11:36 AM | #2 |
Member#: 4496
Vehicle:2009 Forester red |
i had asked this of my mechanic. he said for the amount of money involved in redoing the electrics it would be more feasible to stuff a wrx drivetrain into it and be happy
otherwise, early obd electrics in the 95 require a lot of reworking. getting a 2000-up ej25 motor is worse because almost all the sensors on the engine are not compatible without lots of work. and he dosen't trust the ej22 tranny either... it goes on. |
12-31-2003, 01:10 PM | #3 |
Member#: 11858
NWIC
Vehicle:1998 Silver Legacy |
Isn't the EJ22 tranny(auto assuming) the same as the EJ25..........
//M |
12-31-2003, 02:54 PM | #4 |
Member#: 4496
when i asked, he said no
is the final drive the same? i never checked... |
12-31-2003, 03:30 PM | #5 |
Member#: 20612
NESIC
Its a 5 speed so no worries there. Just the issue of whether or not this is a worthwhile upgrade for a sleeper-type 95.
01-01-2004, 12:59 PM | #6 |
Member#: 4021
NESIC
Vehicle:1999 Legacy GT Ltd Quick Silver Metallic |
You will need a 2.5 crossmember, to replace your current 2.2's crossmember. This is the easy part, however.
Given that the EJ25 engine didnt appear untill after the OBDII diagnostics were released in 1996 you will need some rather extensive re-wiring, along with the donar cars ECU. Perhaps someone has some tips on how you can simply swap out a post '96 EJ25's entire wiring harnass with your current cars exsisting harnass ? In the long run I suspect you are better off sticking with the 2.2 liter engine. |
01-01-2004, 02:16 PM | #7 | |
Member#: 30727
South East
01-01-2004, 09:51 PM | #8 |
Member#: 4496
someone correct me if i'm wrong but my 1996 legacy brochure says only ej22... even the GT model (the one w/o the hood scoop and only had 15" wheels)
01-01-2004, 10:59 PM | #9 |
Member#: 25516
NWIC
96 GT had a 2.5 it took premium. biggreeen96 has a 96 2.5 gt.
01-02-2004, 08:00 PM | #10 |
Member#: 11620
Vehicle:1997 GF4-STiV3 clone |
The long awaited supercharger is near completion. That is likely the way to go.
01-02-2004, 08:09 PM | #11 |
Member#: 25516
NWIC
2.2 is da bomb, as long as its the ej22T
01-02-2004, 10:35 PM | #12 | |
Member#: 4496
01-02-2004, 10:47 PM | #13 |
Member#: 25516
NWIC
i would not put a super/turbo on a n/a 2.2 or even a 2.5. over in the aftermarket forced induction forum there are always guys posting about how they blew their number 3 piston. wrx swap is the best road if you want power. sti is good if you can afford it. ej22T is good if you have lots of money to upgrade the motor so that its better then the wrx.
01-02-2004, 10:50 PM | #14 | |
RIP 1/19/64 - 7/23/11
Scooby Guru Member#: 24654
NESIC
Vehicle:1957 Taggart Comet atlasshruggedpart1.com |
01-03-2004, 09:21 PM | #15 |
Member#: 30727
South East
Anything 95-up was OBDII...
I wouldn't mind putting a low-boost turbo on an N/A EJ22. Those aren't exactly wussy engines either. The only problem is the 9.5:1 compression of the N/A, that's why I'd go real low boost, maybe 7 tops... |
01-07-2004, 06:11 PM | #16 | |
Member#: 4496
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452886036 |
Wagon handling on a budget. Is it possible? | Superorb | Brakes, Steering & Suspension | 69 | 06-06-2007 11:06 AM |
JDM STI V7 suspensions on 06 WRX, is it possible? | Lam | Brakes, Steering & Suspension | 2 | 04-28-2006 02:38 PM |
Got 2nd to last on Sun. autox... is it me or the car? | Andrman | Motorsports | 24 | 07-25-2005 09:19 PM |
is it possible to change dashlights from green to orange (wrx to sti) | M32WRXin3seconds | Interior & Exterior Modification | 8 | 12-11-2003 12:36 AM |
Is it possible to put a EJ20's turbo on EJ25? | IBO | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 07-01-2001 03:30 AM |
