Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Old 10-26-2012, 09:26 PM   #1
swpshgnwgn
Member#: 150494
17 WRX Limited
Default 2011 Stock? WRX
Hi all,
Just got back into a WRX and started logging today. I bought the car used and wanted to do some logging to make sure everything looked good. Thought it was stock, then I saw the log and started thinking otherwise.
https://docs.google.com/spreadsheet/...WpIVURqc1QzWUE
First time doing this, so I probably logged FAR too much information, but by the looks of this data, is this a stage 1 map? Dealership I bought it from told me it was stock.
swpshgnwgn is offline   Reply With Quote
Old 10-26-2012, 10:14 PM   #2
TS7XREX
Member#: 287450
2011 Impreza WRX
Most people aren't going to go through that long of a log, including me. But if you want to try again do a single pull from 2500 rpms to redline if you can do so safely, and post that.
TS7XREX is offline   Reply With Quote
Old 10-26-2012, 10:36 PM   #3
swpshgnwgn
Member#: 150494
17 WRX Limited
Apologies. I deleted a lot of the first part of the log to get to the main portion I was talking about.
Edit: Which it looks like I didn't save before uploading. I'll fix that.
Edit2: Fixed.
Old 10-26-2012, 10:24 PM   #4
the suicidal eggroll
Member#: 51961
2005 STi
18 psi? Yeah, that ain't stock
Old 10-26-2012, 10:46 PM   #5
TS7XREX
Member#: 287450
2011 Impreza WRX
You should pull the rom from your car and compare it to the stock rom found on romraider. It would be fun and you can learn a lot about it that way.
Edit* http://www.romraider.com/forum/viewt...hp?f=33&t=5384
Here is some good info on how to make a useful datalog
