Welcome to the North American Subaru Impreza Owners Club Tuesday September 25, 2018
Old 09-26-2017, 04:25 PM   #1
Oleg B
Member#: 215933
2007 FXT, 6MT, UTEC
APS DR65 Rotated,FMIC
Default Bypass oil filter: pros & cons
Hello Suba fans,
What do you think about topic?
Please mark your comments as "Pros" or "Cons"
Oleg B is offline   Reply With Quote
Old 09-26-2017, 04:31 PM   #2
ATMINSIDE
Member#: 455092
2015 WRX Limited 6MT
ISM
Your car already does this automatically when giving higher percentages of throttle.
ATMINSIDE is offline   Reply With Quote
Old 09-26-2017, 04:53 PM   #3
jamal
Member#: 71875
What possible "pro" could there be for not filtering the oil?
Although yes, there is a bypass, in the filter. When the oil pressure across the filter is high enough (20-30psi) it opens. That's not engine oil pressure, but the pressure from one side of the media to the other. This probably occurs on cold starts especially with a higher viscosity oil, and after the filter has been on for awhile.
jamal is offline   Reply With Quote
Old 09-26-2017, 05:53 PM   #4
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
He is probably asking about an additional filter system (bypass the stock system) that has much better filtering than the stock system. The pro I see is better filtering, con being expense, and extra plumbing / failure points down the road.
http://www.amsoil.com/shop/by-produc...?code=BMK23-EA
http://www.amsoil.com/lit/databulletins/g2552.pdf
cnstman is offline   Reply With Quote
Old 09-27-2017, 02:06 AM   #5
Oleg B
Member#: 215933
2007 FXT, 6MT, UTEC
Yes, exactly.
How-it-works
Strange, that such systems are not popular in Suba world.
Old 09-27-2017, 07:58 AM   #6
bluesubie
Member#: 767
04 FXT
This is probably the most detailed thread about installing a bypass system in a Subaru I've seen. I haven't checked lately but the OP was running fairly thin Amsoil SSO 0W30 at 15,000 mile intervals in his Legacy GT and also gained two quarts additional capacity.
Have fun!
http://legacygt.com/forums/showthrea...ons-81741.html
Old 09-27-2017, 09:08 PM   #7
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
In their terrible diagram, how do they restrict the oil pressure drop from the filter teeing into the oil system?
I'm familiar with this from diesel truck things, where they are inline (but parallel) with the system. It allows it to passively clean the oil.
Old 09-28-2017, 08:53 AM   #8
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Im interested in the idea....
Old 10-09-2017, 09:55 AM   #9
Oleg B
Member#: 215933
2007 FXT, 6MT, UTEC
Recently I had Manley H-Beam connecting rod broken in my Forester, so the engine built is in progress.
Config will be similar to my previous engine (Darton sleeves, JE pistons, nitride treated crank) + Manley I-Beam rods, APS DR-65 BB turbo (Garret 3582 CHRA), Kelford 272, Manley valves/springs/retainers, 12 mm oil pump, etc.
I bought Frantz Bypass filter with Frantz Synthetic Filter Media and will try to install it (as minimum planning to keep it for break in period).
Regarding pressure drop: Frantz bypass filter has input orifice of 0.9 mm and output orifice of 0.4 mm, so pressure drop should be not an issue with 12 mm oil pump, however, I have oil pressure Defi sensor in the gallery plug and can monitor oil pressures after install.
Old 11-05-2017, 08:46 PM   #10
Oleg B
Member#: 215933
2007 FXT, 6MT, UTEC
Finally installed Frantz bypass oil filter in my Subaru Forester:
Old 11-05-2017, 08:47 PM   #11
Oleg B
Member#: 215933
2007 FXT, 6MT, UTEC
Old 11-07-2017, 07:31 AM   #12
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Where da pics at?
Old 11-07-2017, 11:33 AM   #13
Homemade WRX
Member#: 33782
96 3MI Racing LLC
Ron, I see all the pics.
Old 11-07-2017, 12:52 PM   #14
Oleg B
Member#: 215933
2007 FXT, 6MT, UTEC
Anybody else can't see the pictures? Please let me know.
@Unabomber, I uploaded them and even some more to Google Drive (no registration required for view and/or "download all"): Bypass oil filter installed (Oleg B)
Old 11-07-2017, 03:38 PM   #15
Homemade WRX
Member#: 33782
96 3MI Racing LLC
I hate photobucket. The forums are now jacked because of them.
Does anyone else have a good pic server option?
Old 11-07-2017, 04:24 PM   #16
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
CON
Unnecessary cost and complexity (increased probability for issues).
The OEM filters go down to 5 microns. My personal opinion is the difference between 2 and 5 microns in regards to a Subaru oiling system, performance, and longevity are meaningless. If there were ever evidence of small particulate issues on these engines, I'd be fully on board with your cause. I just don't see a measurable benefit.
Although, I am definitely in to be proven wrong with a back-to-back oil analysis
Old 11-07-2017, 06:18 PM   #17
Oleg B
Member#: 215933
2007 FXT, 6MT, UTEC
Originally Posted by KillerBMotorsport View Post
CON
...The OEM filters go down to 5 microns.
Do you have any proof of this info?
Which Beta Ratio/Efficiency do you mean?
The best Beta Ratio (declared by manufacturer) which I found was for reusable Pure Power 8415, K&N SS-1008, K&N-SS1004 and K&N SS-1010 - 100% @ 22 microns.
Purolator PSL14612 - 99.0% @ 25 microns
K&P Engineering S1 - 100% @ 35 microns
Purolator Pureone PL14612 - 99.9% @ 40 microns
Source: Subaru oil filter comparison
Old 11-10-2017, 05:02 PM   #18
Oleg B
Member#: 215933
2007 FXT, 6MT, UTEC
CON
Do you have any proof of this info???
Old 11-10-2017, 09:12 PM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Proof of a phone conversation with someone in the know? No. I have several pages in my engineering notepad detailing specs from conversations with several manufacturers. SAE data as well. You being a spectator of the internet don't have to believe a word of it. I have no dog in this fight as we're not profiting from OEM filter sales, but our reputation is based on at least giving somewhat decent knowledgeable advice.
Old 11-10-2017, 11:47 PM   #20
Oleg B
Member#: 215933
2007 FXT, 6MT, UTEC
What is Beta Rating/Efficiency of OEM filtering to 5 microns?
