10-28-2012, 08:45 PM | #1 |
Member#: 287469
Vehicle:2007 Impreza Wagon Urban Gray |
runs rough when wet
2007 2.5i wagon. I have this issue only when the car sits outside in the rain for a couple days without being started. usually when I leave the car at the outdoor airport parking lots due to my business travel. I come back to the car after it sitting for 3 days (it rained one of those days) - fire it up and it idles ROUGH, RPMS drop down, shakes like it wants to stall and strange sounding exhaust. i can give it a little gas, sounds normal and then RPMS drop down, idles rough and sounds horrible. Check Engine Light will flash a couple times - then about 5 minutes runs fine, CEL goes off.
Last time it occurred, P0303 misfire was found, but dealer didn't find any problems. Suggestions? From what i read, seems it could be 1) coil pack and spark plugs 2) harness behind battery might be getting wet 3) Mass air flow (MAF) Before Hurricane Sandy comes tomorrow, I would like to see if i can figure it out. Thanks, |
10-28-2012, 10:33 PM | #2 |
Member#: 271928
Vehicle:2014 WRX Limited Crystal Black Silica |
It might be moisture building up, when I did my friends timing belt on his legacy it had a lot of moisture buildup from not being ran for a while I'm assuming, after about ten minutes of idling most of the moisture was gone from the tail pipe and clear exhaust, the car was running a little rough at first but now is running fine
10-29-2012, 03:31 PM | #3 |
Member#: 287469
UPDATE well, lucky for me - my office was closed due to Sandy. About 11 am, i ran out to fire her up and the same problem occurred... Drove about 2 miles, with noise, lack of power, flashing CEL and then it stopped and car drove OK. I live about 5 minutes from dealership. Took her in, P0303 code -- they replaced the coil pack and wires. However, wasn't covered under warranty. Lets see if she fires up later tonight or tomorrow morning..
10-30-2012, 08:24 PM | #4 |
Member#: 177721
Vehicle:1995 Impreza L ABP |
This happened to me when I had my NA....turns out it was a ripped spark plug wire
11-11-2012, 08:21 PM | #5 |
Member#: 141433
Vehicle:2006 Impreza 2.5i Obsidian Black |
Check plug wires and knock sensor
11-13-2012, 03:40 PM | #6 |
Member#: 158150
Vehicle:2007 Impreza 2.5i Newport Blue pearl |
Old plug wires can dry up, and not seal allowing moisture into the coil pack connections and the spark plug wells, both bad places to have moisture.
11-17-2012, 06:37 PM | #7 |
Member#: 318411
South East
Vehicle:17 WRX CWP |
mine does the same thing! exhaust sound and everything...and sometimes, even white smoke comes out my exhaust which means water. but after 5 minutes like you said she runs fine..
