Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Old 05-16-2004, 04:02 PM   #1
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Default Emissions and the JDM ECU
Any one solved and potential JMD V7 ECU problems when doing a JDM conversion. I will be using ECU-Tek so I assume I can present the OBDII sensor any thing I want.
I will be using the JDM intake and risers on a 2.5 block with V8 heads and JDM ECU for the AVCS.
ebeck is offline   Reply With Quote
Old 05-18-2004, 11:40 PM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
What problem?
totoherbs is offline   Reply With Quote
Old 05-19-2004, 06:23 AM   #3
AKGC8
Member#: 1305
2000 Impreza
? What kind of emission tests do you have to go through?
If it's anything that they open your hood and check VIN #'s for then you'll have problems. There's nothing you can to to make a swap like that legal. It's just one of those cases where if you live in a place with very minimal or no emission tests you're not going to get caught.
AKGC8 is offline   Reply With Quote
Old 05-19-2004, 01:12 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
this is one of my promary questions for mr cobb at next weekends meet .. weather or not he can make a v7 or v8 ecu respond to the obd-2 queries for emmisiosn testing
Old 05-19-2004, 02:03 PM   #5
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Right on. Well the problems I am refering to is emmissions in general. If you can not plug the new ECU in and tune the car and pass emmissions then that is a problem. If so, what would those problems be. That is the actual question. Are there any problems passing emmissions tests. I would clearly state would the new flux capacitor conflict with the dilithium crystal, causing excessive gamma radation causing me to fliunk emmissions if I knew what I was talking about. Hence the question.
So for the sake of clarity, iIs there any problems with the V7 ECU with AVCs and TGV delete housings passing the obd-2 tests? Most places do not have an AWD dyno so tail pipe tests are out I believe. Just the obd-2 stuff. If there is tail pipe tests would it pass. Sure it varies by State. So, would it pass California standards. OBD-2 and tail pipe if they exist there.
Sure, you can register the car in a county with less strict emmissions and all kinds of crap to get around emmissions tests. I would rather go through them than around them. That's just me.
Old 05-19-2004, 02:20 PM   #6
AKGC8
Member#: 1305
2000 Impreza
There is a good chance you could get the car to pass a sniffer test. The problem is when they open the hood and see the engine VIN doesn't match. In cities that use standards similar to California, you generally need to have any new engine installed pass a referee inspection to be legal, even if it's just the same that came stock on the car. There is nothing you could do to technically make a 2.5 block running V8 heads and a V7 ECU legal. The engine that you swap has to have been offered in the US by the Subaru to be legal.
Old 05-19-2004, 02:52 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
what he said but some states are less strict
idaho for example:
they scan your bar code off the b pillar with a bar code reader verify it is the same on the windshield and plug in the obd-2 .. make sure the mil comes on when you start the car and pull the codes .. no codes = pass
older cars get the sniffer
my early ej20 with no idle air controller and a usdm down pipe passed with flying colors
Old 05-19-2004, 03:39 PM   #8
totoherbs
Member#: 7321
.... 122 IggPoints
The ref is tricky... You may beable to pass it off as a usdm 2.5 motor everything must look stock, no hacked wires. If you must do it under the dash... And your cars title will change if you pass the ref; it wont be a wrx anymore it will be a sti and have the insurance from that. Just because they dont have awd dyno doesnt mean they wont do a sniffer test... mostly they do the idle test.
The ecu itself should pass the test no problems... but once they look at the motor you could have problems. http://forums.nasioc.com/forums/show...ighlight=IM240
Old 05-19-2004, 03:40 PM   #9
AKGC8
Member#: 1305
2000 Impreza
Yea, that's what I'm saying. It will all depend on how thurough the emissions tests are where you're at.
No swap like that will technically be legal anywhere, the EPA sets those regulations. It's just that in places where there isn't strict emissions testing there is no enforcement so you can get away with it.
Old 05-19-2004, 08:46 PM   #10
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Hmm, I wonder if AZ pulls VIN numbers for engine and Pillar? Even if they don't, if they start I would be screwed. Perhaps forged pistons in the stock block with my V8 are in order......
300 whp on Dyno-Dynamics is not asking too much....
Old 05-19-2004, 10:20 PM   #11
totoherbs
Member#: 7321
.... 122 IggPoints
Why whould you be screwed on start up? You would have to run stock like pipes, at least one if not more cats, if you wanted to pass... Are you talking about forged piston slap? Should be much of a problem after the car is warm...?
Old 05-20-2004, 02:47 PM   #12
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
No, no, If they start pulling VIN numbers from the block and A Pillar I would be screwed. Sorry about the ambiguity.
Ha ha, I am vague I see. I a contemplating putting V8 heads on my stock 2.0 block as a performance upgrade and scrapping the 2.5 block do to fear of AZ starting to compare VIN numbers.
How would the V8 heads and cams with AVCS work on the 2.0 block. Would there be a performance gain in lower rpm or just 7000+. I am hoping the higher flowing, longer duration cams means I can flow more air and gain more power below 7000 rp,.
I was saying if the shoddy 2.0 block and pistons fail sometime later, I can just get new pistons and sleeves put in. I just wonder if the V8 heads andECU would be a benifit over stock USDM 2.0 setup.
The idea is a stronger stock block with V8 heads and ecu would pass emmissoins for sure even if they pulled and compared numbers.
Old 05-20-2004, 03:11 PM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
O ok I see. Ya, i wouldnt bother putting the good heads on a crap block... You will see good gains but its just no worth all the time its going to take IMO.
Call you DMV or whatever they have in Az and find out what you need to do to get this swap passed. I realy think at the very least you can pass it off as a 2.5 US STi... and my beable to pass smog with it just fine. People blow motors and replace them all the time... Try contacting people in Az who have done it and see what they say. The guys a kingpin, AZScoobie, ... and see what they are doing.
Old 03-14-2019, 08:53 PM   #14
ZFracing
Member#: 499080
i just bit the bullet and bought a usdm ecu for my jdm swap, took it to the shop and didnt pass, it didnt even read any thoughts?
ZFracing is offline   Reply With Quote
Old 03-15-2019, 06:26 PM   #15
subaru_gc8
Member#: 29292
2004 WRX wagon
what didnt it read? have you tried to plug in a obd2 port reader?
OBD2 emissions and the Bugeyed WRX w/minor mods. GTG! gpd323 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-14-2007 09:45 PM
EasyECU and the JDM STi ecu (drive by cable). Does it work? DoctorNick Commercial ECU Reflashes 0 03-13-2007 07:43 PM
CT Emissions testing & JDM ECU CTKAG New England Impreza Club Forum -- NESIC 8 06-23-2006 01:11 AM
Anyone in NoVA pass emissions with a JDM ECU? Capt Crunch Mid Atlantic Impreza Club -- MAIC 9 04-19-2006 01:05 PM
Emissions and the Aftermarket luck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-20-2002 08:59 PM
