Welcome to the North American Subaru Impreza Owners Club Tuesday April 13, 2021
Old 03-26-2016, 11:20 AM   #76
LucasBlack
Member#: 331072
Originally Posted by scby rex View Post
So your keeping the 5mt and adding a r180? I have a drive shaft that will drop right in. Nice swap, was this ever dyno tuned after the initial swap or just Street tuned to get it going?
It's been a while since I looked into the necessities for the swap, but I don't remember the drive shaft being required. Is the length of the R180 housing different than the R160? Or is it a change in the pinion gear mounting flange that your drive shaft accommodates for? Either way, I may be interested.
No dyno time for the car post-swap. And it's actually still inoperative for the time being. Funds got super tight over the course of the past year, but that has just recently started to change, so I'm starting to get hopeful again to be able to get the car running again soon.
LucasBlack is offline   Reply With Quote
Old 03-26-2016, 11:23 PM   #77
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
The r180 companion flange is bigger than the r160. Length of shafts only change depending on 5mt or 6mt.
scby rex is offline   Reply With Quote
Old 03-27-2016, 12:04 PM   #78
tyingju
Member#: 443459
That is an awesome swap! I look forward to more pictures of this build.
tyingju is offline   Reply With Quote
Old 04-04-2016, 09:37 PM   #79
smidge
Member#: 217064
is it time for a built motor yet? we need to get some custom stuff!
smidge is offline   Reply With Quote
Old 06-26-2016, 01:17 AM   #80
Grant
Member#: 36325
Originally Posted by LucasBlack View Post
2.) What I haven't mentioned (in this thread yet), is that the motor got rod knock the very next day after the diff blew. Yay me.
My tech and I have a pretty good idea what all may have led to the destruction (8 trackdays in a month having a bit to do with it)...
Was it oil starvation?
Also, what made you go with an EZ radiator instead of an upgraded GD Impreza radiator?
Grant is offline   Reply With Quote
Old 06-29-2016, 02:33 AM   #81
LucasBlack
Member#: 331072
That's our best guess. We'll be making a couple changes to try and mitigate this going forward w/ the second motor.
And I went with an EZ radiator because it has the dual coolant returns whereas an Impreza radiator has just the single. I didn't want to have to create a 'bridge' of sorts to make an EJ radiator work (like Patrick Olsen did).
Old 06-29-2016, 09:37 AM   #82
Dead Mr.
Member#: 429798
I have an brand new 04 Roush Mustang Eaton MP90 Supercharger that's already reversed to spin the Subaru way if you want to step it up... lol
I have a 3.0r lego with an EZ36D swap, but I'm about to sell it to build an 02 Outback with an EZ30D and 5mt swap and an MR2 that's going to get a 2GR-FE swap so this supercharger has been waiting for a home but I keep passing it by.. Its prolly gonna go in the MR2.
Are you going to mod the oil pan with a baffle and maybe add some capacity with a deeper sump? I only auto-Xed my 3.0R but I had the pan off and could see how high gs could starve the pump, especially with that chain drive and all the oil needed for that.
Best of luck man.
Johann
Dead Mr. is offline   Reply With Quote
Old 06-30-2016, 01:07 AM   #83
LucasBlack
Member#: 331072
Best of luck man.
Johann
Our approach is likely overcomplicated, but it consists of two parts:
1. Overfill a half quart to quart; run a bit heavier oil.
2. Per some research and theory, we're thinking the excessive track usage and regular exposure to high g's was 'storing' oil in the heads (yay boxer motor). We're plumbing the valve covers to twin (one per bank) external high temp oil pumps that will have lines run back to the sump. They're electric driven and the idea is to have a switch in the cabin to run them while on track, and have them force feed oil from the heads back to the sump for track days.
Thanks for the supercharger offer, but I'm actually pretty content with the 250'ish NA power on tap. I'm always a bigger fan of driving slow(er) cars fast.
Old 04-30-2017, 12:32 AM   #84
Sooby Roo
Member#: 466810
How is this project coming along?
Reading your story has inspired me to take on the h6 swap aswell. I picked up an ez30r, and have begun rebuilding it.
Any advice when I get to the wiring?
Kinda new to automotive programming.
Sooby Roo is offline   Reply With Quote
Old 08-11-2017, 12:17 AM   #85
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
You can drill 4 new holes 45* off and then bolt the 5mt driveshaft to the R180. The centering bore is the same size.
eastcoastbumps is offline   Reply With Quote
Old 08-20-2017, 09:04 PM   #86
Samiam1017
Member#: 334068
any updates on this build?
Samiam1017 is offline   Reply With Quote
Old 01-29-2019, 03:01 PM   #87
Floppie
Member#: 384307
As somebody who's thinking about EZ36D swapping our EJ251 Baja in the future, I have a vested interest in this build. Super interested in updates
Floppie is offline   Reply With Quote
Old 02-19-2021, 11:11 AM   #88
banacote
Member#: 522450
6 years later, how is this running for you? is it still going strong, any major issues, etc?
banacote is offline   Reply With Quote
