Welcome to the North American Subaru Impreza Owners Club Tuesday April 20, 2021
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Non-Subaru Stuff
Old 02-27-2007, 07:29 AM   #1
AspenWhite
Member Sales Rating: (3)
Member#: 137846
2004 STi
Default VA: Home Audio/Video/Game
anyone interested ?
maganavox tv 125 bux
* Product type
* CRT TV - Color
* Technology
* CRT
* Diagonal size
* 27 in
* Image aspect ratio
* 4:3
* CRT type
* Real Flat
* Digital TV Type
* Analog TV
* Width
* 31.1 in
* Depth
* 22.4 in
* Height
* 27.4 in
* Weight
* 88.2 lbs
Video System
* Comb filter
* Digital
* Analog video format
* NTSC
* Analog video signal
* Composite video
Audio System
* Sound output mode
* Stereo
* Audio controls
* Balance, Bass, Treble
* Speakers included
* 2 speakers
Television Features
* Closed captioning
* Yes
* Display menu language
* English, Spanish
Tuner / Channel Details
* Tuner type (qty)
* Standard TV (1)
* TV tuner channel qty
* 181
* TV tuner preset channel qty
* 181
* Parental channel lock
* Yes
* V-chip control
* Yes
Remote Control
* Remote control type
* Remote control (Infrared)
Connections / Cables / Slots
* Input/Output connections
* 1 x Antenna (F connector) - Rear, 3 x Composite video/audio input (RCA phono x 3) - Rear, 1 x Component video input (4 pin mini-DIN) - Rear, 1 x S-Video input - Rear
Sony STR-DE597 Audio/Video Receiver 150 bux
* Product type
* AV receiver
* Width
* 16.9 in
* Depth
* 12.3 in
* Height
* 6.2 in
* Weight
* 17.6 lbs
* Color
* Black
Audio System
* Built-in decoders
* DTS 96/24, DTS Neo:6, DTS decoder, Dolby Digital, DTS-ES Matrix 6.1, Dolby Pro Logic II, DTS-ES Discrete 6.1, Dolby Digital Surround EX
* Surround sound effects
* Digital Cinema Sound EX
* Digital sound processor (DSP)
* Yes
* DSP preset qty
* 11
* DSP presets
* Movie, Music, Cinema Studio Ex. A, Cinema Studio Ex. B, Cinema Studio Ex. C
* Surround system class
* 6.1 channel
* Bass Control
* Yes
* Treble Control
* Yes
* Additional features
* Midnight Mode, A/B/A+B speaker switch, Digital signal format auto detection / auto switching
* Headphone Jack
* Yes
* Coaxial Digital Input
* Yes
* Optical Digital Input
* Yes
* Connector type
* 1 x Headphones (Phone stereo 6.25 mm) - Front, 2 x SPDIF input (TOS Link) - Rear, 1 x SPDIF input (RCA phono) - Rear, 2 x Audio line-in (RCA phono x 2) - Rear, 1 x Audio line-out (RCA phono x 2) - Rear, 2 x Component video input (RCA phono x 3) - Rear, 1 x Component video output (RCA phono x 3) - Rear, 1 x 5.1 channel audio line-in (RCA phono x 6) - Rear, 1 x Monitor output (RCA phono) - Rear, 3 x Composite video/audio input (RCA phono x 3) - Rear, 1 x Composite video/audio output (RCA phono x 3) - Rear, 1 x Subwoofer output (RCA phono) - Rear, 2 x Front speakers output (Banana/spade x 2) - Rear, 2 x Front speakers output (Click-fit x 2) - Rear, 1 x Center speaker output (Banana/spade x 2) - Rear, 2 x Rear speakers output (Banana/spade x 2) - Rear, 1 x Rear center speaker output (Banana/spade x 2) - Rear
Amplifier
* Signal-to-noise ratio
* 96 dB
* Input Impedance
* 50 KOhm
* Input Sensitivity
* 500 mV
* Amplifier output details
* 100 Watt - 8 Ohm - THD0.7 % - 2 channel(s) (Front), 100 Watt - 8 Ohm - THD0.7 % - 2 channel(s) (Rear), 100 Watt - 8 Ohm - THD0.7 % - 1 channel(s) (Center), 100 Watt - 8 Ohm - THD0.7 % - 1 channel(s) (Rear center)
Radio
* Radio type
* Radio tuner - AM/FM - Digital
* Tuning display
* Fluorescent display
* Station preset qty
* 30
* Antenna form factor
* Loop AM / wire FM
* Radio response bandwidth
* 30 - 15000 Hz
* Radio signal-to-noise ratio
* 76 dB
* Total Harmonic Distortion
* Mono: 0.3%, stereo: 0.5%
* Auto preset memory
* Yes
* Additional radio features
* Station naming
Display
* Audio system built-in display
* Fluorescent
* Timer
* Sleep
Remote control
* Universal remote control (Infrared)
* Remote control (2nd) type
* None
Included Furniture / Accessories
* Included accessories
* AM antenna, FM antenna
Power
* Power device
* Power supply - Internal
* Operational power consumption
* 220 Watt
* Operational power consumption (standby)
* 0.3 Watt
Theater Research TR-2830 Floor Speakers 150 bux pair
* 30-400 Power Handling Watts
* 4-8 Ohms
* 107 dB/1W/1m (MAX.)
* 2-4" aluminum finish cones
* 1-10" silver long-throw subwoofer
* 2-1" silk fiber domes
* HxWxD: 43.7"x6.3"x14.5"
* Weight: 41 LBS (each)
MTX 12" Subwoofer (SW2) 145 bux ( 3 days old )
• 12" woofer
• Bass-reflex design
• 100-watt RMS amplifier
• 35Hz-160Hz freq. response
• Line-level inputs
• Speaker-level inputs
Sony® SS MB150H Left/Right Channel Speakers 30 bux
Featuring a 5 1/4" improved H.O.P. cone bass driver, a 1" nano-fine balanced dome tweeter, sound reproduction to 50 kHz (for high-resolution audio), 120 watts of maximum input power, and a Frequency Range of 80Hz-50kHz, this 2-way, 2-driver book shelf speaker will definitely enhance your audio experience.
Increased resistance to heat and humidity
Avoids interference
Black Ash matches your other audio components
pair-12" pioneer floor speakers 50 bux
Frequency Response: 30-20 kHz
Impedance: 6 Ohms
Max Power: 120 Watts
sounds great
Sony Center Channel 15 Bux
Pair-Emerson bookshelf speakers 10 bux ( used for rear center )
8-Ft. Monster® THX Ultra V1000 Component Video Cable 50 bux
Monster's Ultra Series component video uses advanced video technologies sucha as nitrogen gas-injected dielectric insulation and silver-content solder connections to deliver the clearest, sharpest picture possible with maximum color saturation and ultra-low attenuation.
Color-coded bands for simple, error-free hookup
Heavy-duty double shielding protects against outside EM and RF interference
24k gold-plated contacts provide maximum conductivity and resist corrosion
Exceeds THX certification standards for proper system performance and reliability
Monster LightWave 10-Ft. Fiber-Optic Cable for Xbox/Xbox 360 20 bux
xbox 360 , wireless net adapter , battlefield 2 , FF11 , Sneak king , pocketbike racer , big bumpin , 1-wireless controller , 1 controller plug and play charge kit , component cable , 1-nyko intercooler . no hd . 350 bux
rca cables 2 bux
fiber optic cables 3 bux
AspenWhite is offline   Reply With Quote
Old 02-28-2007, 03:08 PM   #2
jmaluso
Member Sales Rating: (11)
Member#: 6616
'05 Forester X
how much for the xbox 360 wireless adapter shipped to Fairfax, VA 20330?
jmaluso is offline   Reply With Quote
Old 02-28-2007, 04:38 PM   #3
AspenWhite
Member#: 137846
2004 STi
won't seperate the list so it would be 350
Old 03-01-2007, 10:16 AM   #4
jmaluso
Member#: 6616
'05 Forester X
expensive wifi adpater!
Old 03-04-2007, 08:08 PM   #5
AspenWhite
Member#: 137846
2004 STi
bumppers
Old 03-06-2007, 09:43 AM   #6
JCampbell
Member Sales Rating: (14)
Member#: 25159
2015 BrAkes stop you
BrEAks make you broken
I'll take the 360 optic cable.
What type of RCA cables are you selling?
JCampbell is offline   Reply With Quote
FS Home - Audio/Video/Game Pieces For Sale 4x4STi MAIC Private Classifieds 2 08-26-2007 10:49 AM
My home audio video equipment rules! L Bo Off-Topic 6 04-13-2007 08:33 PM
WRX parts, home Audio/Video stuff, and more... NicFunkadelic NESIC Private Classifieds 6 02-15-2007 10:38 AM
Home audio/video wiring gurus, need a bit of help. trail*of*dead Off-Topic 16 12-23-2006 02:25 AM
Home audio/video goodies for sale! Tivo! Replay! Pronto! BiggSean Private 'For Sale' Classifieds 7 02-26-2006 11:15 PM
