Welcome to the North American Subaru Impreza Owners Club Tuesday April 20, 2021
Old 02-12-2017, 10:14 AM   #5351
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Hybrid 6MT Swapped WRB
04 WRX wagon with 2 inch strut spacers and general grabber A/T need to get the saggy butt spacers now
Valarius Starchaser is offline   Reply With Quote
Old 02-13-2017, 10:34 AM   #5352
powder007
Member#: 130729
2004 WRX
JBP
Post lift. Still have to get my trailing arm spacers that i just ordered. My tires will probably rub so i'll just get them mounted and balanced and at least test fit and if there's rub i'll install them after i put the trailing arm spacers on.
King Springs
KYB GR2
powder007 is offline   Reply With Quote
Old 02-13-2017, 02:34 PM   #5353
powder007
Member#: 130729
2004 WRX
JBP
Originally Posted by theoutbackdream View Post
Gotcha...
So it's not really used as a preventative measure? I read somewhere that the multilink spacer was either 1) only for recentering the wheels 2) A must to prevent CV damage.
This is without trailing arm spacers. I installed my lift and measured then ordered the one i thought would center it best. If i'd gone with ADF recommendation it would be the opposite of this pic and too far back and look awkward. I got 1".
Old 02-13-2017, 03:46 PM   #5354
theoutbackdream
Member#: 301179
2013 WRX Limited
Gotcha.. So on my GP/GJ gen, I would just need a multi-link spacer kit, and that would suffice?
theoutbackdream is offline   Reply With Quote
Old 02-13-2017, 04:48 PM   #5355
powder007
Member#: 130729
2004 WRX
JBP
Honestly i'm not entirely sure what a GP/GJ is lol. I just know my WRX is a GD GG. ADF calls the spacer i bought a trailing arm spacer. But a trailing arm being one of multiple links in the suspension, I'd guess it's the same thing, or at least similar duties. Sorry i can't answer definitively on that.
Edit: just went back and saw you have a newer Impreza and took a look on ADF's website. Yeah i'd guess that's what you need based on what they offer, is the Multi-Link spacer kit.
Old 02-13-2017, 05:48 PM   #5356
theoutbackdream
Member#: 301179
2013 WRX Limited
Gotcha! thanks for that information!
Old 02-18-2017, 04:29 AM   #5357
SnowKing
Member#: 282260
2002 WRX Sedan
Have an 06 WRX wagon. About to pickup forester xt Struts and springs from off an 04 or have to go rip some off an salvage 07. Both same price and haven't decided which to go for. I am wanting to do the 3/8" saggy butt spacers. Do I need longer studs for those to fit?
Then I'm trying to find 97-99 outback trail arm brackets and rear sway bar brackets still. Might have find them new.
Then eventually will get smaller rims with bigger tires.
SnowKing is offline   Reply With Quote
Old 02-18-2017, 04:36 AM   #5358
Chuckls
Member#: 280696
sway brackets - Get the forester ones. off the salvage
Dont get the outback trailing arm bracket. Get 2inch spacers from ADF.
Chuckls is offline   Reply With Quote
Old 02-18-2017, 04:51 AM   #5359
SnowKing
Member#: 282260
2002 WRX Sedan
From what I've read on here I feel the 2 inch trailing arm spacers would set it back to far for just doing xt suspension with 3/8 rear spacer.
Drive a lot on the highways in the mountains and still want decent handling being my daily
Old 02-21-2017, 08:50 AM   #5360
Jack Stilts
Member#: 452140
2012 Impreza
I'm planning to get the ADF 2" lift for my impreza. Do I need to buy the multi link spacer kit as well?
Yes. ADF recommends getting the multi-link spacers with the 2" lift. Anything less than 2" and you can probably get away without the multi-link spacers.
Doing the same thing to mine
Jack Stilts is offline   Reply With Quote
Old 02-21-2017, 11:04 AM   #5361
Chuckls
Member#: 280696
They sell 1inch trailing spacers too.
Old 02-21-2017, 09:49 PM   #5362
two_point_5RS
Member#: 343220
2005 WRX
white and green!
So has anyone on here gone beyond the normal struts and spacers lift with there impreza/wrx? I wanna get higher and i know I have to lower the driveline, extend shift and steering linkage, and other stuff but im not exactly sure on what needs to be lowered... I know I have seen some really high WRX's but haven't gotten ahold of them
two_point_5RS is offline   Reply With Quote
Old 02-21-2017, 10:15 PM   #5363
two_point_5RS
Member#: 343220
2005 WRX
white and green!
My turd
Old 02-21-2017, 10:29 PM   #5364
Spun Bearing
Member#: 435312
2002 Wrx wagon
my 2002 wrx, KYB GR2 struts, King springs, stock wheels/tire sizes. I want to step up to 265/65/16's but I think it will need trailing arm spacers.
Spun Bearing is offline   Reply With Quote
Old 02-22-2017, 10:40 AM   #5365
two_point_5RS
Member#: 343220
2005 WRX
white and green!
Yea you will, im running 215-70-16 and theyre really close to the body and I have 98 obs trailing arm brackets. Going to add spacers when I do my brakes here soon.
Old 02-22-2017, 02:18 PM   #5366
powder007
Member#: 130729
2004 WRX
JBP
265/65-16 will definitely not fit with your lift. That's a 29.5" tire diameter and nearly 10.5" wide. I have same exact lift and 215/65-16 i have rubbing in front and 1/8th in rear w/o trailing arm spacers so i haven't put my tires on yet. Once i do i'll still have only about half to 3/4 inch on either side of the tire in the rear and in the front where i'm gonna cut the splash guard. You'd likely need fender work for those 265/65's to clear, maybe even more lift.
Old 02-22-2017, 03:29 PM   #5367
Spun Bearing
Member#: 435312
2002 Wrx wagon
Oh yea sorry I don't know why I said 265/65 I meant 215/65 haha
Old 02-22-2017, 04:19 PM   #5368
Chuckls
Member#: 280696
Old 02-22-2017, 09:20 PM   #5369
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Nice lights and megaphone^
Might as well share too!
http://i.imgur.com/ok1urqtl.jpg
Blingstrom is offline   Reply With Quote
Old 02-26-2017, 10:50 PM   #5370
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
I got Dirty today
Reverend_ is offline   Reply With Quote
Old 02-27-2017, 10:22 AM   #5371
powder007
Member#: 130729
2004 WRX
JBP
Finally got er done!
Old 02-27-2017, 10:56 AM   #5372
goob_os101
Member#: 173185
2005 Saabaru
wheels and tire specs please
goob_os101 is offline   Reply With Quote
Old 02-27-2017, 12:01 PM   #5373
powder007
Member#: 130729
2004 WRX
JBP
Wheels are 16x7 38mm offset. They are Vision 425 Bane gunmetal.
Tires are BF Goodrich All-Terrain T/A K02 in 215/65r16.
Old 02-27-2017, 07:16 PM   #5374
03SubyWRX
Member#: 200767
2006 WRX TR
2013 Crosstrek
Looks great! Any rubbing? What suspension are you running?
03SubyWRX is offline   Reply With Quote
Old 02-27-2017, 11:06 PM   #5375
ferrettank
Member#: 389423
2003 WRX Wagon
Sonic Yellow
How my car looks now. Forester lift with 265/65/16.
http://i.imgur.com/1rvkVJY.jpg
and the best part, I did a CG render of what my car will look like when spring comes around
http://i.imgur.com/4PVZYLz.jpg
ferrettank is offline   Reply With Quote
Chamois, or just plain Sham? Lifino Interior & Exterior Modification 8 10-02-2013 08:01 PM
SOA gotta love 'em or just plain hate 'em kalbo-1 Warranty Issues & SOA Problems 1 01-19-2004 08:29 PM
Hot or Not or Just Plain Ok.... n20x3whitewrx Member's Car Gallery 28 07-29-2002 10:05 AM
McRae: Dedicated or just plain nuts? SubaruStu Motorsports 2 03-20-2002 09:55 AM
Jinxed? Or just Plain UnLucky??!! silverSurfer General Forum Archive 6 06-30-2000 10:27 PM
