#51 |
Member#: 275970
Vehicle:04 WRX Wagon 99 Forester 5mt |
![]() This is absolutely phenomenal. Hats off to you, sir.
I'm now even more anxious to convert my wagon to RWD after my engine is built.
#52 | |
Member#: 331072
![]() Quote:
And, if you're at all interested in talking about chassis/suspension setup for the car once it's RWD, just hit me up! I'd be happy to talk about what I've done/learned with mine. |
#53 |
Member#: 275970
![]() I absolutely would. I'm planning on going the route of a mildly built, occasional weekend track toy, so I'd assume you'd be a great person to chat with about it!
#54 |
Member#: 331072
#55 |
Member#: 187727
SCIC
Vehicle:2001 GC6 Impreza BRP w/ dust magnet paint |
![]() What an exciting car! Hats off to you!
#56 | |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
![]() Quote:
#57 | |
Member#: 331072
![]() Quote:
For instance, upon removing the Wilwood brake system later, I found out that I had essentially melted the caliper piston dust boots. I don't know what temperature is required for that to happen, but I know I haven't run into that problem with either the '05 LGT front brake setup or the STi Brembo setup I am now running (and I am for sure as hard, if not harder, on the brakes now than I was then). I don't believe swapping to a pad with a higher temperature operating range would have solved the problem. While I don't have case-specific data for this, it is my belief that the narrow, small diameter rotors did not have the heat capacity (mass) to deal with the conditions they were subjected to, thus the severe heat basically destroyed everything around it. So, I could have maybe switched to the most hardcore pad available to try and cope, but the heat produced by that setup would likely boil fluid and regularly cause me service and brake performance issues. Thus, upgrade. ![]() |
#58 |
Member#: 331072
#59 |
Member#: 192568
Vehicle:2015 Outback 3.6R '18 F150, '21 RAV4 XSE |
![]() How's the car?
#60 |
Member#: 331072
![]() That's a mighty fine question, Doug. Unfortunately, the car is currently down -- for two reasons.
1.) As I had mentioned earlier, the diff blew up. I am switching over to an R180 and will hopefully be able to make the swap soon. 2.) What I haven't mentioned (in this thread yet), is that the motor got rod knock the very next day after the diff blew. Yay me. ![]() My tech and I have a pretty good idea what all may have led to the destruction (8 trackdays in a month having a bit to do with it), so we're working on implementing some upgrades/changes that should help with its longevity given what its intended purposes are. I hope to be able to provide an update here in the next couple of weeks on that progress. Hold tight! ![]() Last edited by LucasBlack; 03-02-2015 at 09:08 PM. Reason: grammar |
#61 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
![]() How are the upgrades coming along?
#62 |
Member#: 331072
#63 |
Member#: 272471
TXIC
Vehicle:2010 WRX FlareObody Red |
![]() Crazy build! Kudos for doing something different, instead of just buying a 370z or leggy or something.
So any plans for the motor while it's apart? I vote valves and springs so you can rev the piss out of it. ![]() Also any thought to relocating stuff to the back to get some weight back there? |
#64 |
Member#: 217064
![]() nice conversion! keep us posted with how you fix this motor
#65 |
Member#: 347279
RMIC
Vehicle:01 Forester CGM/SGM |
![]() interested in the swap! i have an 05 OBS same 253 that your impreza started with. if you dont mind me asking a few questions via PM thatd be awesome!
#66 |
Member#: 426836
![]() This seems like a really practical swap, unsure if it would fit into the 08 impreza 2.5i platform with 5MT. Does anyone know if it would?
#67 |
Member#: 97453
Vehicle:2013 STI Hatch Satin White Pearl |
![]() Mighty Car Mods put a H6 EZ36D in a Legacy wagon. Most have probably seen it.
The ECU company they used has the AVCS working, and they turbocharged the H6 Haltech Elite ECU |
#68 |
Member#: 97453
![]() This is my build and it just received a new motor from Cobb Plano TX.
In 4-5 years when I do this again its getting a EZ36D or an EZ30D with a turbo. http://legacygt.com/forums/showthrea...ts-150039.html |
#69 | |
Member#: 331072
![]() Quote:
![]() It would have been nice to get direct support from an ECU company like they did, haha! |
#70 |
Member#: 3737
NWIC
Vehicle:2007 WRX STi Crystal Gray Metallic |
![]() Kudos for building something very unconventional, which I respect. I hope you're still enjoying the heck out of it.
#71 | |
Member#: 331072
![]() Quote:
#72 |
Member#: 306719
Vehicle:2003 Sti Wagon @jn_garage |
![]() This swap or an EZ30 into a GC or old legacy wagon would be most excellent
Haltech Elite supports everything too ! |
#73 |
Member#: 442888
![]() I plan on doing this swap into my 05 5MT RS, just curious as to anything you weren't expecting that i should be ready for. also if you could help me at all with the ecu process that would be much appreciated!
#74 |
Member#: 328787
Vehicle:1998 Impreza 2.5RS Black Diamond Pearl |
![]() Did you ever end up dynoing the car? I am really curious as to what you were able to pull out of it with a tune.
#75 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, MPS 2.34 breaking in |
![]() So your keeping the 5mt and adding a r180? I have a drive shaft that will drop right in. Nice swap, was this ever dyno tuned after the initial swap or just Street tuned to get it going?
