07-29-2012, 05:31 PM | #1451 |
Member#: 274895
I get the impression it isn't the physical memory so much as how they've developed the embedded software - it seems like they've set up space for X amount of 2d tables, and once you reach that its all over. It's the only thing that has really left me wanting for more when tuning a G4 Link.
07-30-2012, 02:21 AM | #1452 |
Member#: 179846
NWIC
Vehicle:07 STi Limited EFR 8474 TS EWG |
Its not really a problem for me i have all the tables full, and i got everything i need.
I think if you have quad AVCS that might be a problem and will limit some things... 4 way solenoid Last edited by Bariga; 07-30-2012 at 02:28 PM. |
08-03-2012, 08:41 PM | #1453 |
Member#: 179846
NWIC
On dyno last time we found out hydramist sprays when gauge is off "making pump gas map be in 10.4 afr" , because vipec sends out signal all the time to the trigger wire. So i installed relay that would break trigger wire when gauge is off.
This system cant be more retarded complicated hahaha. Last edited by Bariga; 08-04-2012 at 01:19 PM. |
08-03-2012, 09:50 PM | #1454 |
Member#: 195711
Vehicle:PART OUT. PM ME 02-07 Goodies |
Any way to test it out to make sire you got it right?
08-03-2012, 09:51 PM | #1455 |
Member#: 195711
Dbl post.
08-04-2012, 01:22 PM | #1456 |
Member#: 179846
NWIC
works fine, the only thing i need to check is fail safe system. For some reason we grounded MAP-SW2 connector.
08-04-2012, 01:28 PM | #1457 | |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
08-04-2012, 01:47 PM | #1458 |
Member#: 179846
NWIC
that's what map switch 1 does, when you turn on gauge it turns on fuel map 2. i always thought that map switch 1 should activate only when flow is present and its inside of safe window.
08-04-2012, 02:52 PM | #1459 |
Member#: 32669
SCIC
You have more than one map switch?
08-04-2012, 05:03 PM | #1460 |
Member#: 212509
NWIC
Vehicle:unde your hood makin your **** go faster |
your ****s too ****ing complicated anton
08-04-2012, 10:30 PM | #1461 |
Member#: 179846
NWIC
everything on Subaru is complicated but we make **** work right?
08-05-2012, 01:21 AM | #1462 |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned 573WHP |
I agree with Dave, you over think things Anton. Step back, look at it and take steps out if possible.
08-05-2012, 12:52 PM | #1463 |
Member#: 179846
NWIC
Umm hydramist setup as 5th injector in vipec and Aux inj map is always on, no way to turn it off, and when hydramist gets signal on trigger wire it turns on and starts spraying even with gauge off making AFRs to be in 10s. So im trying to setup a rely that would break trigger circuit when gauge is off.
08-05-2012, 05:02 PM | #1464 |
Member#: 179846
NWIC
i think i need up upgrade my meth kit! Spend 4 hours trying to see why the **** fail safe wont trigger when tank is low, i went online after giving up and found this http://forums.nasioc.com/forums/show...postcount=2347
lol W T F aquamist? |
08-05-2012, 08:49 PM | #1465 |
Member#: 159243
Vehicle:5/01 bugeye Hakt Ecu is back! |
I don't think I wanna go fast anymore.
08-05-2012, 09:02 PM | #1466 |
Member#: 170007
BAIC
Delete
08-05-2012, 09:08 PM | #1467 |
Member#: 32669
SCIC
08-05-2012, 11:50 PM | #1468 |
Member#: 159243
maybe someday ill have a job again and i can "afford" failure.
08-06-2012, 08:45 AM | #1469 |
Member#: 81102
South East
I'm with ya. Life is bigger than always being short cash, for a car... I'm not doing it again, until I can afford to break stuff and not have to sell parts, etc., to sustain my habit.
Btw: with your honest posts and curiosity to find the best, I have much respect for u. /ot, back to Anton's money pit. |
08-06-2012, 10:18 AM | #1470 |
Member#: 170007
BAIC
Delete
08-06-2012, 12:14 PM | #1471 | |
Member#: 32669
SCIC
Why not set up the HSV as a GP PWM output. That way you can set when your meth flows using conditional logic. |
08-06-2012, 05:26 PM | #1472 |
Member#: 195711
I've been toying with the vipec just inputting tables based on the map sensor and IAT sensor I'm getting ... and none of these features are jumping out at me... is this cause I'm just playing with a computer that isn't hooked up to a ecu?
08-06-2012, 05:53 PM | #1473 |
Member#: 32669
SCIC
What features are you talking about specifically? For any Auxillary output you can configure as a PWM output with its own PWM 3D duty cycle table.
08-06-2012, 06:28 PM | #1474 |
Member#: 195711
Ill take it to PM
08-06-2012, 08:41 PM | #1475 |
Member#: 159243
I'm just tipping my hat to Dex for his strength to continue. I feel better safe than sorry. I love my car so much that I actually worry about it. I don't beat on her or drive it like I stole it. I also enjoy understanding the why/how stuff is working and not working...not only for performance but longevity. Again, I applaud dexs persistance and take delight in his success.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band | Maxwell Power | Proven Power Bragging | 634 | 06-11-2016 02:34 AM |
Maxwell Power Services aka GetaDomTune | AwaySooner | Vendor Reviews | 7 | 03-11-2010 03:54 PM |
+1 for Dom/Maxwell Power | Jeff54 | Vancouver Impreza Club Forum -- VIC | 22 | 09-02-2009 02:22 PM |
My new Maxwell Power Services engine is almost in !!! | leonbmx | North West Impreza Club Forum -- NWIC | 13 | 03-23-2009 10:28 AM |
