Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2024
Old 06-10-2004, 01:05 PM   #1
Blugin
Member#: 5270
2008 EvoX MR
Red
Default I don't usually ask this stuff, but what do you guys think?
This is going to be one of those 'How much power will my car make?' threads. I just want to get some ideas from others on my setup.
I have a 2002 WRX with an STi v7 full transplant (non spec c). I spun a rod bearing on the 2.0 block so we swapped in an EJ257 bottom end. I just finally got it back and I'm breaking it in but I can tell it's gonna be a beast. FIS just wired up the AVCS too and it feels more responsive. So here are the mods:
EJ207 heads with AVCS and a valve job
EJ257 block with EJ257 headgasket (if I read right it should be around 8.6:1 C/R)
Stock 565cc injectors
Stock VF-30
TXS Hyperflow TMIC
PDE 2" flex uppipe (stock one cracked )
Helix downpipe
Blitz Nur Spec Touring exhaust (no cats anywhere)
Unichip
no silencer on the airbox- paper filter
Everything else is pretty much stock. I know the turbo is pretty small and all but what do you guys think it will make? It's not tuned right now- it's just running 9psi and the stock STi ECU but it feels fast...
Blugin is offline   Reply With Quote
Old 06-10-2004, 01:33 PM   #2
Big Turkey
Member#: 32118
I say 300whp-ish with gobs of torque
Big Turkey is offline   Reply With Quote
Old 06-10-2004, 03:54 PM   #3
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
wcbjr is offline   Reply With Quote
Old 06-10-2004, 04:55 PM   #4
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
I really don't know, I just wanted to put a quote in a quote.
Mattr762 is offline   Reply With Quote
Old 06-10-2004, 05:04 PM   #5
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
I have something along your lines in modifications. Major difference is I am still 2000 cc as I have the EJ207. That and I have a Turbo XS FMIC and an APS exhaust with a cat. AVCS is hooked up and it is a stock 2002 STi JDM ECU as the motor is a 2002 STI engine. All of this is in a 2002 WRX and from my times and trap speeds I got 332 WHP and 431 at the flywheel. I am trying to scrape up some money for a trip to Turbo Trix to get a real dyno run and a printout so I can figure the best shift points
P.S. I have a VF30 but I also just installed a HKS EVC5 and the boost is limited to 21.5 psi
2002WRXSTi is offline   Reply With Quote
Old 06-10-2004, 05:35 PM   #6
Big Turkey
Member#: 32118
What were your times and trapspeeds?
Old 06-10-2004, 08:24 PM   #7
2002WRXSTi
Member#: 58647
02 Exedy Carbon
My best for that night were 12.715 and 12.726 with 107.49 and 107.33 all at 3454 pounds. Had about an 8th tank of ULTRA when I got there and put in $20 worth of 100 Octane Sunoco. All this was with horrid atmospheric conditions and tempatures in the 90s.
Old 06-11-2004, 11:31 AM   #8
Blugin
Member#: 5270
2008 EvoX MR
Red
So you guys think more than 300whp?
Old 06-11-2004, 01:30 PM   #9
Big Turkey
Member#: 32118
With pump fuel.. I don't see why not. Definately on race fuel.
Why don't you get an UTEC and get rid of the Unichip? That's some ole' school stuff right there
Old 06-11-2004, 03:47 PM   #10
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
nutin' rong wif ole' skool stuff
stickman is offline   Reply With Quote
Old 06-12-2004, 09:36 AM   #11
Blugin
Member#: 5270
2008 EvoX MR
Red
I dont have the $$ and does the Utec contol AVCS with a (non US) STi engine and harness?
Old 06-12-2004, 02:20 PM   #12
Big Turkey
Member#: 32118
The normal UTEC doesn't.. but TXS provides a JDM UTEC. At least that's what I'm told.
Old 06-12-2004, 02:24 PM   #13
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
The utec doesn't control avcs ever though, no matter which utec. The reg. 6B will work with jdm ecu's. It will throw inj. codes though. The JDM utec will not throw codes, that's the only difference. I had both, just get whatever they have in stock.
Soon2Bgreat is offline   Reply With Quote
What do you guys think of this wrx can you help me please akazempoor General Community 18 02-10-2008 04:59 PM
What do you guys think a 325is w/ m3 stuff and busted engine is worth? burrito007 Off-Topic 21 06-22-2005 11:44 AM
what do you guys think of puff daddy and his vote or die stuff? David Medina Political Playground - Chaotic Neutral Edition 40 11-02-2004 06:40 PM
Thinking about bidding on this eBay car, what do you guys think? Cjchaps Mid West Subaru Owners Club Forum -- MWSOC 18 01-04-2002 01:42 AM
